"Stiff" TV EQ mount
4 replies to this topic
#1 Don Trinko
Don Trinko
Posted 27 February 2011 - 12:51 PM
I have an old TV EQ mount. It was made by Carton for them.
It worked fine in the warm weather but now (winter Ohio) it is very stiff and I don't think my clock drive will drive it. It is actually hard to turn the slow motion controls by hand.
Anyone have any drawings or directions as to how to disassemble? I think it need different grease for Ohio! Is there any way to adjust the clutches?
It came from California. It would probably work fine there. Thanks; Don T.
#2 Nippon
Nippon
Posted 01 March 2011 - 10:01 PM
I have a Vixen Polaris that acts the same way. It has very fluid motion but gets a little stiff when it is cold. I'm in Florida so it is not a big issue. It uses what looks like a thick silicone based lubricant and with mine the stiff in the cold issue has become worse with age. I would call Tele Vue and see what they remember about these mounts which may include instructions on disassembly and recomandations for a proper lubricant to use to relube. They are wonderful people to talk to.
#3 Don Trinko
Don Trinko
Posted 02 March 2011 - 05:11 PM
I have talked to TV a long time ago abought this mount. No one remembers much abought it and they do not have a manual or drawings. Thanks; Don T.
#4 Pat G.
Pat G.
Posted 03 March 2011 - 12:44 PM
probably won't show you a lot, but if it will make your day, send me a private email and I will send you a copy of this;
[Moderators edit: deleted scanned copy of copyrighted image - please review TOS and provide LINKS to images for which you do not hold copyright]
#5 Don Trinko
Don Trinko
Posted 04 March 2011 - 02:32 PM
Well it is not stiff anymore.
I took it partway apart and sprayed a light oil into both ends of the declination and RA and then worked them by hand.
I did not remove the shafts. That was probably the best way but what I did worked. Don T.
