CPC 1100 making a "knocking" sound while tracking
23 replies to this topic
#1 Fzwicky
Fzwicky
Posted 03 March 2011 - 12:23 PM
Hi--
I have a CPC 1100 that's about two years old. (It's a replacement Celestron sent me for my original one that began leaking lube oil down the OTA!) Recently, the scope's begun making a "knocking" sound while tracking an object. It's somewhat regular, sort of: "Knock... ...knockknock... ...knock... ...knock... ...knockknock..." And it's coming from the base, and as far as I can tell from the side closest to the front of the tube. Also, it doesn't make the sound all the time, just when the scope's pointing in certain directions.
Any suggestions?
Greg
Florida
#2 Peter in Reno
Peter in Reno
  • Loc: Reno, NV
Posted 03 March 2011 - 12:52 PM
Maybe it needs new bearings at the base. See this link:
http://www.nexstarsi...earingBalls.pdf
Peter
  • jackofalltrades likes this
#3 Koen Dierckens
Koen Dierckens
  • Loc: Antwerp, Belgium
Posted 03 March 2011 - 01:25 PM
Sometimes my scope also makes those noises (you call it knocking, I'd rather call it ticking or the cracking sound metal can make when it bends).
But I've never experienced any side effects from it. Even during imaging, the pictures do not show any signs of mistracking while the sound occurs...
Might be the bearings. Peter is a smart guy and knows what he is talking about when he posts comments in this forum.
But it could also be that it has something to do with the balancing of the scope. Do you have heavy accessories riding on the scope? Do you use counterweights?
#4 Fzwicky
Fzwicky
Posted 03 March 2011 - 02:09 PM
No, I just have a Televue 2-in. diagonal and SCT adaptor sleeve. I use a 24 mm Panoptic and 13 mm Nagler. I recently bought a 2-in. Orion 38 mm eyepiece, but use it only on the moon. Yeah, come to think of it, I would describe the sound as more of a "ticking" than a knock-like sound. And, it's only periodic.
#5 KerryR
KerryR
  • Loc: Mid-West Coast, Michigan
Posted 03 March 2011 - 03:08 PM
Mine does this too, did out of the box, but I've never seen any effect at the eyepiece, even at highest powers. Careful balancing with counterwieghts had no effect on it. I've been ignoring it, and hoping it doesn't become visible at the ep over time.
#6 Fzwicky
Fzwicky
Posted 03 March 2011 - 05:17 PM
Thanks, Kerry! Makes me feel better! Yeah, the visual performance is not effected during the knocking, or "clicking," sound. I've been tending to ignore it myself, but you know how a small discrepancy can nag at you. I love using my 1100, and the very last thing I want to have to do is return it to C--been there, done that! Thanks again!
Greg
#7 la200o
la200o
  • Loc: SE Michigan, USA
Posted 03 March 2011 - 05:22 PM
Mine does it too, sometimes, not always.
Bill
#8 antimorris
antimorris
    Vendor (Enterprise Astronomy)
  • Loc: Clayton, NC
Posted 03 March 2011 - 05:47 PM
My CPC800 did it when I first got it but it has since stopped and not come back.
#9 Peter in Reno
Peter in Reno
  • Loc: Reno, NV
Posted 03 March 2011 - 05:48 PM
I would agree with what others said not to worry too much. If I move the tube up an down pretty quickly, it makes a clunking sound at Dec/Alt axis but that does not affect the images I have been taking. See images in my Gallery in signature.
Peter
#10 trumpetjazz
trumpetjazz
  • Loc: Surrey, B.C. Canada
Posted 21 August 2011 - 04:25 PM
Hello Fzwicky:
I had the same problem with my CPC1100... the dreaded ticking sound. I put up with it as I wasn't thrilled with the thought of sending it back to C for service. After my warranty expired, and after some research I decided to see if I could fix this myself. The fact that the ticking sound seemed fairly steady re-affirmed to me that it was gear-train related. The sound seemed to be coming from the base, so I removed the top of the "saucer" to see what I could see.
In my case it turns out the factory had adjusted the tension of the worm gear against spur gear way too tight. You will notice that there is a spring that pushes the worm gear against the teeth of the spur gear.... mine was adjusted as tight as it would go. I simply backed off the tension on the spring and using trial and error was able to get the dreaded ticking noise to stop. This was an incredibly easy fix even for someone as UN-mechanically inclined as me! While I was at it, I removed the *BLEEP* factory grease and re-greased the gears with a high quality lithium grease.
I would try this very simple adjustment first before messing around with bearing replacement. Replacing the bearings, though possibly a worthwhile upgrade in its own right, requires you to go deeper into the scope and IMO is not the cause of the ticking sound. Hope this helps.
Terry (trumpetjazz)
#11 JoeR
JoeR
  • Loc: Columbus, OH
Posted 21 August 2011 - 08:42 PM
I get the same thing sometimes with my NS11 too. I noticed it when it was setup in the grass and not in my usual flat pavement areas so I speculate it might be a leveling issue. The worm gear is probably the culprit.
#12 rookie
rookie
    Good Night Nurse
  • Loc: St. Petersburg, FL
Posted 23 August 2011 - 10:43 AM
Hi Greg,
No one takes care of their scope better than you. Hope your problem resolves.
Shirley
#13 Digital Don
Digital Don
  • Loc: Manteno, IL
Posted 23 August 2011 - 09:25 PM
I agree with Terry.
When I only heard the dreaded "clunks", I ignored them. Eventually however, I could see the image in the eyepece move when I heard the sound so I figured it was time for a little detective work. I examined both the altitude and azimuth drives on my CPC 1100 and wound up backing off the worm assembly slightly. It removed about 99.5% of the problem. With the scope in some orientations I still here a knock once in a while, but nothing like before the adjustment. Plus the image in the eyepiece no longer moves even if the sound is there.
As far as the azimuth bearings, here's my experience. I have both a CPC 1100 and a CPC 800. From the first day, the 11 has been silky smooth in both altitude and azimuth. It's been installed in my observtory for over 3 years with temperatures swinging from near 100 to below zero.
I normally use the Hibernate function when I finish observing, but periodically realign the scope to maintain GOTO accuracy. To this day, the scope is still smooth as silk.
On the other hand, if my 800 sits for a day, it sounds like it has 'square bearings' when you rotate it manually. My solution has been to simply spin the scope around a few times. The 'clunk' sound goes away after a spin or two.
Both scopes have always had excellent GOTOs and tracking so I'm not convinced it's worth the effort to replace the stock bearings.
Don:usa:
#14 proton314
proton314
Posted 08 January 2013 - 04:51 PM
I have same problem with ticking only. But last night I noticed image is jumping when it's "ticking" so now it's worse. I guess I will loose warranty if I will open cover?
#15 mclewis1
mclewis1
    Thread Killer
  • Loc: New Brunswick, Canada
Posted 09 January 2013 - 08:04 AM
There can be a few reasons for ticking but the most common this time of year is cold weather affecting the clearance of a worm gear. The quickest way to prove if this happening is to setup indoors, do a fake alignment (solar system, one star, or last alignment, doesn't matter) and see how the mount tracks when it's warm. Be sure to replicate the same setup that you used outside as closely as possible (same diagonal/eyepiece, etc. and pointed in the same part of the sky).
There can be other reasons for the ticking, things like an edge of the plastic cover that rubbing a bit, or if the tripod mounting bolts have been changed the new ones may be going into the base just a little bit too far. Here it can be very useful to notice exactly where the ticking sound is coming from.
If you are careful Celestron can't tell you've been inside the mount. If the ticking sound is still heard while indoors it might not be a bad idea to take a peak inside the base or the arm with the Alt motor and see if you can hear exactly where the sound is coming from. If you do this also be careful with any loose wires when you are putting the covers back on, it can sometimes be easy to pinch one.
If you find it's a cover or something like that then it's usually easy to fix yourself (or someone at a local club who's familiar with the scope). It it's a gear or motor that's binding and releasing in the cold then the scope should go back to Celestron for adjustment (if you are in the US ... anywhere else it's best to contact your dealer first ... or some local if you can find someone who's comfortable doing the adjustment).
#16 Motokid600
Motokid600
  • Loc: Berlin, New Jersey
Posted 09 January 2013 - 03:20 PM
I agree with Terry.
When I only heard the dreaded "clunks", I ignored them. Eventually œhowever, I could see the image in the eyepece move when I heard the sound so I figured it was time for a little detective work. I examined both the altitude and azimuth drives on my CPC 1100 and wound up backing off the worm assembly slightly. It removed about 99.5% of the problem. With the scope in some orientations I still here a knock once in a while, but nothing like before the adjustment. Plus the image in the eyepiece no longer moves even if the sound is there.
Don:usa:
This! My cpc11 does this too. I store it on the mount ( which I will not be doing in the future ) and after it sits for awhile I'll roll it around just to get things moving. And dude I can't get over the sound. Its on a hardwood floor so the sound resonates through the whole house. Its that significant. The bearings really do feel square. But as you said I'll spin the scope around a few times and it becomes smooth as butter. My guess.. its from having the scope set on my wedge when imaging ( I store it in alt/az ). The plastic bearings just can't take the hundred or so pounds ( fully loaded ) concentrated on the backside. After awhile they flatten. But it seems once you work the grease around things get free'd up.. so to speak.
My scope also makes said knocking sound. Idk if its related, but my scope does have tracking problems. I'll notice a star just randomly starts drifting away then stops. So this is no good. I plan on doing a complete overhaul of my CPC soon. Bearings, whatever cheap, plastic gears ( or cheap plastic anything rather ), carbon fiber tube, flocking, corrector cleaning, built in heaters, custom mirror lock, everything! Can't wait.. hopefully I can get this scope running and looking better then new.
#17 albert1
albert1
  • Loc: Southern New Jersey
Posted 13 January 2016 - 10:16 PM
CPC1100 owner here. No problems with this example, yet. Love the scope. Had it for some time and all seems well. I did have the lube leak issue among other things but, no biggie. On one occasion the dew was so heavy it wet the control panel ports. Suddenly, the electronics went haywire - the code 16/17 thing. Did some tests and it was clear the problem was in the electronics boards directly under the ports due to moisture. Took a day or two to dry out and problem solved. Now, I keep all the ports sealed when not in use. I thought telescopes are made to be outside. Last thing I'd ever want to do is send it back to C.
Sorry for you guys. Just doesn't make sense to cut corners by using plastic bearings. Just silly. Real stainless steel bearings are cheap as h**l. Maybe Celestron has a legitimate reason other than saving a nickel? If they do I can't figure it out :smirk: .
Edited by albert1, 14 January 2016 - 12:27 PM.
#18 jackofalltrades
jackofalltrades
Posted 13 January 2016 - 11:08 PM
I used to own a CPC800 back in 2007 and it did that brand new out of the box, and worse when I mounted it on the wedge and put it into polar EQ mode.  Usually, you can attribute the knocking, and associated jumps in the image which are noticeable when imaging, to the nylon bearings they use in the base for the azimuth axis.  IIRC, you can replace them with stainless steel bearings, but I don't remember the source any longer.
As I said, it messes with images, but if you're just a visual observer and keep the scope in alt/az mode, there's really no problem and doubtful you're going to see any damage.  Still, it wouldn't be hard or expensive to change out for stainless bearings.
#19 herrointment
herrointment
  • Loc: North of 64
Posted 13 January 2016 - 11:29 PM
If you do decide to play with the worm mesh in regards to that infernal clicking noise, make sure to photograph or document the factory settings before you start.
Ask me how I know this!
#20 Peter9
Peter9
  • Loc: Yorkshire - Born & Bred
Posted 14 January 2016 - 09:09 AM
I made some plugs to fit the ports in order to prevent moisture getting in. I made the first two, pictured, for the 8se. I how have them in all the ports on the CPC1100.
Attached File  Plugs 1(S).jpg   23.03KB   17 downloads
Be well.   Peter
  • albert1 likes this
#21 KC9EDN
KC9EDN
  • Loc: Indianapolis, IN
Posted 30 January 2016 - 09:06 PM
Since this thread has continued to stay alive, I wanted to add that I discovered the problem on my cpc1100 while doing the bearing upgrade...
The main shaft bearing housing was slightly mishapen which caused the rollers to rub the bottom of the housing when the scope was tracking. At some point I will dig back in and replace the bearing, but the quick and easy fix was to simply slightly bend the offending part of the bearing housing to eliminate the rub. Ymmv, but did the trick for me and is something else you can verify if you have the "tick", "rub", "grind", etc... :)
#22 orion61
orion61
  • Loc: Birthplace James T Kirk
Posted 30 January 2016 - 09:36 PM
You know if this was a Meade issue, there would probably be a 500 hit Thread about it, with less than love filled posts.
But my old Sandcast C8 and my Meade 10" LX3 2120 keep working as sweet as the day they were new both have great optics.
I hope we aren't getting to an acceptance mode for Celestron putting out sub-par equipment. I had actually thought of replacing my
Meade with a CPC11 but not now, no way.
I hope the worm adjust fixes the issue for you.
Edited by orion61, 30 January 2016 - 09:40 PM.
#23 Peter9
Peter9
Posted 31 January 2016 - 05:27 AM
And my CPC1100 keeps working as sweet as the day it was new, and the optics are first class.
So are you going to buy one now??  :grin:
Be well.  Peter.
#24 Larry Hansen
Larry Hansen
  • Loc: MIchigan - Nevada in winter
Posted 01 February 2016 - 04:23 PM
My CPC800 did the same thing right out of the box.  I ignored it until the warranty was up.  The solution to stop the noise was fairly simply on my scope.  The tension nut for the bearing  was too tight. I simply backed it of a little bit and the noise went away.   I now oen to cPC's and the newer one does the same thing.  I suspect it is also the tension nut being too tight.  When the warranty expires on that one I will fix that one also.    From what I understand my older CPC has nylon bearings and the newer one has 50% steel ones  And I would note that the newer one does not tick as loud or as easily as the older one did.  One more note the amount that I had to back the nut off was very minimal, maybe only 1/8 th of a turn.
  • herrointment likes this
