Parallax 250 HD Installed and Working!
28 replies to this topic
#1 Jeff B
Jeff B
Posted 07 March 2011 - 07:07 PM
Man this thing is a beast. Had to install it in several pieces with only a minimum of bodily injury.
It's a Parallax 250 HD Observatory mount. Solid. Solid. Solid. I've finally a mount to do the D&G 11" justice. So far the AP GOTO system seems fine but true to the "curse" , there have been clouds ever since installation last weekend so it's not exactly dialed in yet.
Jeff
#2 Jeff B
Jeff B
Posted 07 March 2011 - 07:08 PM
Another view.
#3 Jeff B
Jeff B
Posted 07 March 2011 - 07:09 PM
Finally, down low and thru the door.
Jeff
#4 Don Allen
Don Allen
Posted 07 March 2011 - 07:21 PM
:bigshock:
#5 Steve Fisher
Steve Fisher
Posted 07 March 2011 - 07:27 PM
Jeff:
Beautiful! :bow:
#6 richardlowney
richardlowney
Posted 07 March 2011 - 07:29 PM
Now THAT is a telescope. Beautiful!
#7 dothead
dothead
Posted 07 March 2011 - 07:43 PM
Congratulations, Jeff.
Is it f/12 ?
What's the damping time of the set-up ?
Clear skies,
Ralph
#8 David Pavlich
David Pavlich
    Transmographied
Posted 07 March 2011 - 09:57 PM
Now that is a nice looking mount!!
David
#9 frolinmod
frolinmod
Posted 07 March 2011 - 10:12 PM
Now that's a telescope! Drool...
#10 Jeff Morgan
Jeff Morgan
Posted 07 March 2011 - 10:41 PM
Incredible.
#11 skybsd
skybsd
Posted 08 March 2011 - 02:53 AM
AWESOME!!!!!!!
Congrats on the new mount.,
skybsd
#12 Max Lattanzi
Max Lattanzi
Posted 08 March 2011 - 04:16 AM
Is it f/12 ?
Clear skies,
Ralph
Jeff,
Congrats on this side as well.
Yes, what's the damping time?
And what have you be using before?
-- Max
#13 TxStars
TxStars
Posted 08 March 2011 - 09:11 AM
Several years ago I got to use the "field" model of the same mount.
That thing is barely moveable as one piece.
And that scope makes the mount look small.
"WoW"
#14 Jeff B
Jeff B
Posted 08 March 2011 - 08:52 PM
Thanks everyone, it really is a neat looking mount.
Ralph and Max, I really don't know the damping times yet as I've not had time really to use it due to weather. However, by just nudging it, RA seems very well damped, at least as good as the Byers Series II is. There is a bit too much backlash in DEC right now so that when DEC is balanced it can bounce around a bit. I need to snug the worm up against the gear a bit more. Adjustments like that seem easy. I can turn the RA very easily with my finger tips on the spur gears (It always amazes me to be able to move the 370 + pounds of scope, DEC castings, shafts and counter weights with just my finger tips). I'll adjust the worm on the DEC axis so that there is little backlash but still easily moves with the fingers as well and I'll probably leave a small imbalance in DEC to always load the gear train.
Jeff
#15 Mel M
Mel M
Posted 08 March 2011 - 10:47 PM
How tall is the pier? F/12?
#16 Mike Clemens
Mike Clemens
    Frozen to Eyepiece
Posted 09 March 2011 - 04:49 AM
Looks proper. Super!
#17 Max Lattanzi
Max Lattanzi
Posted 09 March 2011 - 05:43 AM
Hi Jeff,
Thanks. Pls let us know its behaviour when properly meshed in Dec.
May I ask what have you been previously using to handle that OTA.
-- Max
#18 Jeff B
Jeff B
Posted 09 March 2011 - 10:38 AM
Before was a Byers Series II, which is now sitting on the observatory floor covered. For a moment the Parallax RA unit was sitting next to the Byers mount on the floor prior to me hoisting it up to the pier. I should have taken a picture as the Parallax RA assembly is bigger and weighs more than the entire Byers mounts...and the Byers is NO slouch, just lacks goto capability.
The lens is a D&G 11" F12. The pier is a two piece pier, with the lower, concrete pier 29" tall and the steel, upper pier bolted to it 60" tall. There is now an adapter plate/wedge that goes between the top of the steel pier and the bottom plate of the Parallax mount that lets me adjust the alt/azimuth of the mount. It adds 2" overall.
Jeff
#19 Max Lattanzi
Max Lattanzi
Posted 09 March 2011 - 11:08 AM
Mmm, currently I have on the drawing table a 300mm f/10 (to be also stopped-down as a 250 f/12), and I had been considering a mount with 70mm solid steel axes (60mm in Dec) and 270mm wheels in both axes... 4.1 teeth/cm (sorry for the metrics)...
Maybe I am underestimating the torque.
You have there 15" in RA and 11.3" in Dec, right? How many teeth, if I may ask?
And your axes...?!
-- Max
#20 jrbarnett
Posted 09 March 2011 - 12:08 PM
Now *that* is a serious "mad scientist" setup!
That mount is beautiful.
I've been thinking about an off-the-grid observatory with a permanent pier myself, and had been thinking Mathis Instruments because they are local, but that Parallax is a thing of beauty.
#21 Mike Clemens
Mike Clemens
    Frozen to Eyepiece
Posted 10 March 2011 - 01:56 AM
11" f12 GOTO refractor... that's obscene! I look forward to your pointing results. I imagine such a setup would benefit from a pointing model. I wonder what errors meridian flip will introduce on such a massive OTA.
#22 Jeff B
Jeff B
Posted 10 March 2011 - 06:02 PM
Thanks Jim and excellent questions that have been on my mind Mike.
I fully suspect there is some flex and non-orthogonality in my scope, almost certainly some from the rotating rings alone. I guess I'll see about the pointing accuracy. If anything, I can use the "Tour" mode since everything will be visual but I would like fairly accurate go-to's without having to fiddle around.
I'm prepared, if necessary, to go to third party pointing and modeling software. Any suggestions?
Jeff
#23 clintwhitman
clintwhitman
    Caveman
Posted 11 March 2011 - 05:53 AM
Awesome Jeff so is the series II for sale?? :roflmao:
#24 Jeff B
Jeff B
Posted 11 March 2011 - 09:02 AM
Not yet Clint. I'm keeping it in "reserve" until I complete my evaluation of the Parallax mount.
So, have you hoisted your Series II up on to your new pier yet?
Jeff
#25 frolinmod
frolinmod
Posted 11 March 2011 - 12:24 PM
I'd recommend TheSkyX Professional Edition for Mac or Windows plus T-point Add On to TheSkyX. Use the new supermodel feature. It's fantastic.
