Polar scope alignment
11 replies to this topic
#1 James Cunningham
James Cunningham
Posted 08 March 2011 - 10:14 PM
If you can center Polaris in your finder scope and main scope, will it be the same in a polar scope?
#2 Peter in Reno
Peter in Reno
Posted 08 March 2011 - 10:28 PM
If you are talking about polar alignment, you want your mount to be pointing to North Celestial Pole, not Polaris. Polaris is about a degree off from true North Celestial Pole. So centering Polaris with finder scope or main scope is not a good idea. Polar scope in mount is a better instrument to line up your mount to true North Celestial Pole.
Good reading material: http://en.wikipedia..../Celestial_pole
Peter
#3 James Cunningham
James Cunningham
Posted 08 March 2011 - 11:34 PM
So is true north east of Polaris, north of Polaris, south of Polaris or West of Polaris by that one degree?
#4 Peter in Reno
Peter in Reno
Posted 08 March 2011 - 11:40 PM
I am not exactly sure but if you have a planetarium software, it should tell you. Polaris is always rotating around true NCP because of earth's rotation and orbit around the sun so it depends of time of the year where Polaris is currently at.
Peter
#5 Peter in Reno
Peter in Reno
Posted 08 March 2011 - 11:55 PM
Hi Jimmy,
This neat Polar Finder might help you understand better how to find exactly where Polaris is relative to NCP. Just enter your Longitude and it will display what it would look like through a polar scope.
http://myastroimages..._by_Jason_Dale/
Click on "Small download (polar204.zip) only 49K." link. Unzip the file and run "PolarFinder".
Peter
#6 jrcrilly
jrcrilly
    Refractor wienie no more
Posted 08 March 2011 - 11:59 PM
All are true within any 24 hour period.
#7 James Cunningham
James Cunningham
Posted 09 March 2011 - 12:01 AM
Thank you. So, if I get Polaris through the polar scope and move the crosshair just a little bit in the direction of true north, I am better polar aligned.
#8 Peter in Reno
Peter in Reno
Posted 09 March 2011 - 09:37 AM
Simply screw the polar scope into the mount. Adjust mount's Latitude and Azimuth until Polaris looks exactly like the PolarFinder software. When you rotate the RA axis, Polaris should remain the same distance from the center of crosshairs. In other words the crosshairs should rotate while RA axis is rotating but Polaris should remain at the same spot and same distance from center crosshairs. Once there, that means the center of crosshairs is pointing to true NCP.
Peter
#9 Steve OK
Steve OK
Posted 09 March 2011 - 09:52 AM
The North Celestial Pole is nearly on the line between Polaris and Kochab (Beta Ursae Minoris), just under 1° from Polaris. If you can easily remove the polar scope from the mount, take a look at the Moon with it. The moon is close to 0.5° across in the sky, so the NCP would be about "two moons" away from Polaris.
#10 rdandrea
rdandrea
Posted 09 March 2011 - 10:32 AM
Actually, any way you go from the North Pole is south.
So true north is north of Polaris :)
#11 John Carruthers
John Carruthers
    Skiprat
Posted 10 March 2011 - 03:33 AM
Hi Jimmy, just to add to the muddy waters, make sure your polar scope is concentric with your mount's polar axis first. I may be already but if it's mis aligned you will be fighting it forever more, see;
http://galacticfool....align-eq-mount/
or
http://www.awrtech.c....htm#POLARSCOPE
If you use a planetarium programme to find the time of the highest or lowest point of Polaris you can set north on that, then 6 hours later when it's 'beside' the pole you can set the altitude.
#12 avarakin
avarakin
Posted 10 March 2011 - 08:33 PM
I agree with Steve OK - the best polar alignment is done using Kokab method - no need for messing with programs, entering time of day ,figuring out if you need to use ST or DT , just look at where Kokab is and make a correction.
Works like a charm
Alex
