Celestron CG-4 Mount only $199.00 at Astronomics
45 replies to this topic
#1 meteorite
meteorite
Posted 11 March 2011 - 01:01 AM
Astronomics is having a great sale on the Celestron CG-4 Omni mount. Only $199.00 (plus shipping). I purchased one recently. It's a great mount for small scopes. I love the white color as it goes well with my AT72. The 1.75 inch stainless steel legs are far superior to the Orion Astroview version (which costs more). The motions are very smooth. The CG-4 is advertised as having roller bearings. I don't know what type bearings the Astroview has but I have owned that mount as well and the CG-4 seems smoother (maybe just my enthusiastic imagination :jump:
I would like to replace the slow motion cables with some solid aluminum knobes. Anyone know where they can be had?
Anyway, it a good deal.
http://www.astronomi...product_id/CG-4
-Walter
#2 Trev
Trev
Posted 11 March 2011 - 10:04 AM
Check these out
http://www.focusknobs.com/
#3 meteorite
meteorite
Posted 11 March 2011 - 10:16 AM
I have already emailed him. Never got a reply but I will try again. Thanks.
-Walter
#4 Don Trinko
Don Trinko
Posted 11 March 2011 - 10:29 AM
Radio Shack has knobs for old radios that should fit. They are cheap compared to the Astronomy ones. Look for the ones with brass inserts. You want the ones with a 1/4" hole.
If your slow motion is slightly smaller than 1/4" it will still work, if slightly bigger you may have to drill the insert slightly larger. ( some slow motion are 1/4" but some are metric but close to 1/4") Don T.
#5 dandabson
dandabson
Posted 13 March 2011 - 06:16 AM
I have the aftermarket focus knobs as shown in the link above. Go for the extended version. These are extremely high quality and are a really nice addition.
#6 AlienRatDog
AlienRatDog
Posted 13 March 2011 - 09:14 AM
How do people think a 100ed f/9 scope would sit on that? Or am I better with cg5 type mounting?
#7 Bart
Bart
Posted 13 March 2011 - 10:33 AM
What drive will fit the CG-4?
#8 Jim7728
Jim7728
Posted 13 March 2011 - 10:49 AM
This one fits:
http://www.telescope...delcg4mount.cfm
#9 meteorite
meteorite
Posted 13 March 2011 - 11:05 AM
Thanks for the link for focus knobs. I ordered them from Lou yesterday.
-Walt
#10 Bart
Bart
Posted 13 March 2011 - 11:33 AM
It should work just fine. The CG-4 has a 18lbs rating. The should be enough to work with the 100ED. If you were thinking about imaging it probably won't be big enough.
#11 AlienRatDog
AlienRatDog
Posted 13 March 2011 - 11:37 AM
I am using a Portamount II and would like some tracking and better stability...
#12 Bart
Bart
Thanks for the tip Walter, I just ordered one. Oh boy, oh boy, oh boy, another toy!
#13 lfforte
lfforte
Posted 13 March 2011 - 07:20 PM
This one fits:
The Celstron dual axis-motor drive takes 4 D or C batteries. In the long run it will cost a fortune in batteries. Is there any dual axis drive that can run off AC?
#14 AlienRatDog
AlienRatDog
Posted 14 March 2011 - 12:25 PM
Use rechargeable batteries...I used to have a dual axis drive on the SKyview Pro way back when...the batteries easily lasted months...you aren't slewing...they really don't take that much juice...
#15 Doug76
Doug76
    Long Achro Junkie
Posted 14 March 2011 - 12:53 PM
This one fits:
Replace the battery pack with a 6V ac/dc supply. Radio Shack sells a variable output 1A supply.
#16 Nippon
Nippon
Posted 14 March 2011 - 10:06 PM
The single axis drive that Orion offers for their AstroView also works perfectly on the CG4. I bought one for my CG4 because it is just simpler and there are less wires. When polar aligned my CG4 will keep an object centered for hours. The controller has 8x slew speed in both directions plus 2x and stop. The mount is quite steady with my TV85. I paid about $269 a year or so ago. At $199... well what is not to like.
#17 lakeorion
lakeorion
Posted 15 March 2011 - 07:21 AM
Total torture. And I spent this months budget on a finderscope already...
#18 eric_zeiner
eric_zeiner
    Phoenix's Dad
Posted 15 March 2011 - 07:33 AM
This really is total torture as I am so broke that I cannot even pay attention :bawling: :bawling: :bawling: How long are they on sale for?
#19 Gargoyle
Gargoyle
Posted 15 March 2011 - 12:45 PM
I'm usually not a sucker for these low price impulse purchase opportunities, but this just makes sense.
Jerry
#20 Doug76
Doug76
    Long Achro Junkie
Posted 15 March 2011 - 05:57 PM
http://www.jimsmobil...altaz.htm#Vixen
#21 Doug76
Doug76
    Long Achro Junkie
Posted 15 March 2011 - 06:04 PM
Until they are gone. It was a special buy, like the Omni XLT102ED kit they also have on sale.
#22 N1ghtSc0p3
N1ghtSc0p3
Posted 16 March 2011 - 10:37 PM
I see the pic at the start of this thread with an AT72ED, and I'm wondering if that combo, when the mount is motorized, would make a decent budget imaging setup? Im considering the AT72, and would run either a CCD or my light DSLR. Thanks!
#23 Starhawk
Starhawk
    Space Ranger
Posted 17 March 2011 - 08:13 AM
Don't replace the battery pack. In periodic use, you'll go through a set if D cells in 6 months. The instant you set GOTO aside, power requirements drop to nothing. The controller has no voltage or current protection. It is safe on D cells. The replacement drive costs a lot of D cells.
-Rich
#24 meteorite
meteorite
Posted 17 March 2011 - 01:50 PM
GOTO? This mount isn't GOTO.
-Walter
#25 N1ghtSc0p3
N1ghtSc0p3
Posted 17 March 2011 - 04:57 PM
I think the point is simply that GOTO consumes a LOT of power, and that this mount is 'aside' from GOTO, and therefore the drives will run much longer on D batteries...
