GPS FOR EQ5
6 replies to this topic
#1 hongxu chen
hongxu chen
Posted 14 March 2011 - 10:37 AM
Can my celestron cn16 gps unit be used to HEQ5?
#2 hongxu chen
hongxu chen
Posted 14 March 2011 - 10:33 PM
Is there any one know?
#3 Trev
Trev
Posted 15 March 2011 - 10:10 AM
The CN-16 is only compatible with Celestron mounts, different programming than the Skywatcher mount.
#4 hongxu chen
hongxu chen
Posted 16 March 2011 - 12:32 PM
They are both made by same manufacturer. Have you test that before?
#5 Trev
Trev
Posted 16 March 2011 - 02:08 PM
The programming that Skywatcher uses is not compatible with the Celestron programming even though they are made by the same manufacturer now, until Synta bought Celestron a few years ago the programs were developed independently.
#6 mega256
mega256
Posted 16 March 2011 - 02:24 PM
Check out EQMOD...may work with ur gps,,
#7 Phil Sherman
Phil Sherman
Posted 18 March 2011 - 09:29 PM
If your GPS outputs a standard NMEA (I think that's the correct acronym) data stream; then you can use it with EQMOD.
I have an old DeLorme GPS that uses a serial port and was, after making a little hardware box to initialize the unit, able to use it with EQMOD. The initialization box has a pushbutton that jumpers the unit's output into its input. Once initialized; the data stream is used by EQMOD to set your location and a "time offset" to correct the PC's clock.
I used the USB to serial adapter I use for my Canon camera's shutter control. Once EQMOD has set things up; I disconnect the GPS so the serial adapter is available for the camera. I rarely need the time correction because my PC's clock is set using NTP (Network Time Protocol) or my GPS corrected clock and is normally within a couple of seconds of the correct time.
Phil
