Balance problems
5 replies to this topic
#1 Hellow533
Hellow533
Posted 14 March 2011 - 10:42 AM
My mount wont stay perfectly balanced, no matter how slight I made the ajustments. Anywhere in any potition, it is perfect, but if you put it in the 5 O'clock potition*as if you where holding a watch or clock next to it, facing vertical* it falls to straight. what do i do?
#2 LLEEGE
LLEEGE
    True Blue
Posted 14 March 2011 - 11:41 AM
By "falls to straight" do you mean counter weights down?
#3 eric_zeiner
eric_zeiner
    Phoenix's Dad
Posted 14 March 2011 - 02:40 PM
What kind of mount and what kind of scope are we talking about here?
#4 Eddgie
Eddgie
Posted 14 March 2011 - 05:38 PM
If it is a GEM mount, then the balance does not have to be perfect. It doesn't have to be close to perfect.
If it is Alt-Az, even changing an eyepiece will cause it to be out of balance, and there is little you can do.
But if it is a GEM, just keep it close and that is perfectly fine.
#5 Jawaid I. Abbasi
Jawaid I. Abbasi
Posted 14 March 2011 - 10:08 PM
If it is Alt-Az mount then you van still balance the scope. However, we need to know the mount specification and the scope you are using.
As an example: If the weight of your scope is 15# and the mount capacity is 10# then the scope will not stablize even tightening the Alt-knob.
#6 Hellow533
Hellow533
Posted 15 March 2011 - 10:27 AM
same scope as in sig, and it's equatorial.
