CG5 / LXD75 CW Shafts
3 replies to this topic
#1 mrowlands
mrowlands
Posted 14 March 2011 - 01:48 PM
Does anyone know if a CG5 CW shaft is interchangeable with an LXD75 shaft including the locking collar?
Mike R.
#2 Trev
Trev
Posted 14 March 2011 - 01:56 PM
As far as I can remember both are 20mm shafts but I can't remember if the threads up top are the same or not.
Celestron uses a 6mm bolt for the toe saver and Meade uses an 8mm.
#3 EFT
EFT
    Vendor - Deep Space Products
Posted 15 March 2011 - 09:05 AM
Mike R.
Mike,
Yes, they are interchangeable. In fact they are interchangeable with other mounts such as the CGEM and Vixen mounts as well. They also all use the same ID counter wieghts.
#4 mrowlands
mrowlands
Posted 15 March 2011 - 08:58 PM
Thank you gentlemen.
Mike R.
