iOptron iEQ45 and mewlon 250
2 replies to this topic
#1 AlienRatDog
AlienRatDog
Posted 19 March 2011 - 09:34 AM
For purely visual work, would this mount be adequate?
#2 Trev
Trev
Posted 19 March 2011 - 02:33 PM
Well the Mewlon wieghts 27lbs and the EQ45 is rated for 45lbs I don't see a problem with it.
#3 mak7
mak7
Posted 19 March 2011 - 03:57 PM
My Mewlon 250s with rings, dovetail, diagonal and EP comes close to 38 lbs. With proper balance on my HyperTuned CGEM, I seem to be acceptable for visual. Run it at reduced slew rate to help save motors and gears.
Biggest problem I had on the CGEM was the spindly CG5 tripod. Fixed that with a TPI leg spreader and damping time is about 1.5 seconds, from 5 or 6 seconds before the spreader.
The iOptron has 5 lbs more rated capacity than the CGEM.
Toss a coin, but I want a bigger mount.
Brad
