Paramount MX vs Astro-Physics AP900
46 replies to this topic
#26 Mike Clemens
Mike Clemens
    Frozen to Eyepiece
Posted 20 March 2011 - 01:46 PM
"Old style" RS232
versus
USB
Means "Works Every Time, Always"
versus
WHY WONT my COMPUTER LOAD THESE DRIVERS
#27 Peter in Reno
Peter in Reno
Posted 20 March 2011 - 02:23 PM
Lodestar is for autoguiding, not for imaging. Why would an autoguider be used for plate solving?
I'll ask Starlight if they are working on X2 camera interface. That would be nice if it would work with SkyX.
Thanks for the valuable information.
Peter
#28 JAT Observatory
JAT Observatory
    NOT a Wimp
Posted 20 March 2011 - 03:27 PM
"Old style" RS232
versus
USB
versus
I agree. I'll take RS-232 over USB any day.
#29 morten
morten
Posted 20 March 2011 - 05:03 PM
Can the MX be taken apart in RA and DEC parts that are managable weight wise - the head weighs 23kgs. The Ap900 splits in two nicely managable parts
#30 skybsd
skybsd
Posted 20 March 2011 - 05:10 PM
Hello,
No - the SB Paramount MX product page describes the mount assembly as "Unibody mount design weighs 50 lbs (23 kgs)"
skybsd
#31 JAT Observatory
JAT Observatory
    NOT a Wimp
No it can't be taken apart.
#32 Alph
Alph
Posted 20 March 2011 - 05:26 PM
If you can’t lift 50 lbs then you probably need a walking stick :lol:. That’s the whole beauty of this mount. It was designed for portability – no need take it apart. It weighs 50 lbs and it can carry up to 90 lbs of payload!!!
#33 Peter in Reno
Peter in Reno
Posted 20 March 2011 - 05:59 PM
I am wondering whether the advertised 90lbs payload applies to visual use or imaging?
Astro-Physics advertised payload is for imaging and it's higher for visual use but it not advertised for visual use.
I also really like AP900 mount. It's a difficult decision.
Peter
#34 Alph
Alph
Posted 20 March 2011 - 06:49 PM
It is easy for me. The tripod is pricey but it can rotate the mount head 360 degrees around the azimuth. There is a cheaper version ($500 or so ) of this tripod made by another vendor. You can find his ads on Astromart. The cables are routed internally. The Paramount MX has high precision laser based homing switches. It also has the superior control software, probably the best there is. It can be remotely operated. The only problem I have is if it is worth spending $10,000 on a mount. This is just a hobby after all and the stars don’t have to be perfectly round.
#35 jog
jog
Posted 20 March 2011 - 06:56 PM
I agree.
#36 frolinmod
frolinmod
Posted 20 March 2011 - 07:07 PM
Oh my gosh, all this time I thought stars were points. Now that I know they're actually little arcs, I can go back to using an alt-azimuth mount with spindly little fork arms. :grin:
#37 morten
morten
Posted 21 March 2011 - 04:42 AM
I don't need a stick, 50lbs is IMHO not portable.
On of the things with my AP900 that really impressed me was
the true portability of that mount.
If you want to lug 50lbs around why not get the AP1200 where the RA part weighs exactly that, and which has a vastly larger carrying capacity.
#38 frolinmod
frolinmod
Posted 21 March 2011 - 10:05 AM
The advertised Paramount MX payload is for imaging. Software Bisque does not over estimate the carrying capacity of their mounts.
Last fall I had an opportunity to lift the Paramount MX mount and carry it around a bit. As your proverbial 90lb weakling, I had no trouble carrying the mount. It was delightfully compact, light and easy to carry. :jump:
#39 Scott99
Scott99
Posted 21 March 2011 - 10:07 AM
have not been able to lift over 25 pounds since I was 14 years old, congenital spine defect
this new mount looks awesome to me, it looks like the 900 might be a little more versatile but the Paramount looks extremely refined & I'm sure it's going to be perfect for a lot of imagers
#40 Scott99
Scott99
Posted 21 March 2011 - 10:11 AM
actually I'm not laughing out loud. I've had a congential spine defect since age 14 that means I can't lift over 25 pounds.
Fortunately AP looks out for people like me and all their mounts split to give you the lightest possible weight.
To me the Paramount looks extremely refined but the AP 900 is more versatile.
#41 gillmj24
gillmj24
Posted 21 March 2011 - 11:20 AM
I think the AP900 breaks down into 30lb and 15 pound components (give or take). If 25lb is a hard NEVER EXCEED limit, you might be pushing it.
The Mach1 is not as easy to disassemble and reassemble as the bigger mounts but it is possible. Those halves would probably be under 25lb.
#42 skybsd
skybsd
Posted 21 March 2011 - 11:24 AM
Has this been confirmed anywhere on their forums as yet? I asked for the photography capacity of the PMX before and was given the "it depends" answer.
The context of my question was the fact that my intended mount payload included a C14-XLT-Fastar + piggy-backed APO refractor package.
I don't disagree - it'd be great to actually see it written somewhere.,
Thanks.
skybsd
#43 Paul G
Paul G
Posted 21 March 2011 - 11:50 AM
For the 900, the RA is 26.5 lbs and the Dec 17 lbs. The entire Mach 1 is 28.5 lbs. None fit under a hard 25 lb limit unless you separate the Dec and RA on the Mach 1 which give you 11.5 and 16 lbs respectively.
#44 DeanS
DeanS
Posted 21 March 2011 - 11:52 AM
The way the Mach1 is designed makes it feel light since it is easier to hold.
My 1200 RA is a bear because it really does not have any built in 'handles' to grasp. The 900 RA is not nearly as bad as it doesn't weigh to much.
#45 Alph
Alph
Posted 21 March 2011 - 12:59 PM
That's right. It depends on your APO package. It could be an 8" APO, right?
#46 gbarolak
gbarolak
Posted 22 March 2011 - 10:07 PM
Sorry if I missed it earlier in the thread but why do you need a mount with this much capacity? If you max lift for a mount is 25 lbs, would that not also me your max lift for an OTA?
Sounds like you could get by with a lot smaller than a MX or AP900 and still have an excellent AP setup.
#47 Mike Clemens
Mike Clemens
    Frozen to Eyepiece
Posted 22 March 2011 - 11:56 PM
I found the 900 to be easier to move whole than the 1200 RA section is alone.
