Atlas vs. Sirius - Height dimensions w/o tripod?
4 replies to this topic
#1 mcbbcn
mcbbcn
Posted 20 March 2011 - 12:50 PM
I'm trying to figure out the height dimensions difference between the Atlas (EQ6 Pro) and Sirius (EQ5 Pro) mounts. I thinking about replacing my Sirius mount with an Atlas mount in my observatory. My Sirus mount is currently mounted on a pier and there is little tolerance between the rolling roof and the telescopes. I believe the Atlas is bigger (and taller) but I don't know by how much. Does anybody know? I've tried to look in the web but there is very little informationa about it.
Thanks for your help,
Miquel Casas
Portland, OR
#2 rigel123
rigel123
Posted 20 March 2011 - 04:35 PM
I can tell you that the Atlas set at 38 degrees is about 20 inches tall. I don't know the size of the Sirius.
Warren
#3 Phil Sherman
Phil Sherman
Posted 20 March 2011 - 10:47 PM
I can't give you an exact measurement because I no longer have my Sirius mount. The Atlas should be 3-4" taller than the Sirius. This is based on the increase in the height of the boxes I built that they fit into.
Could you change the park position of your scope when you close up the observatory? You might get some extra headroom that way.
Phil
#4 RogerRZ
RogerRZ
    Whatta you lookin' at?
Posted 22 March 2011 - 11:01 AM
I have both, but the Sirius is easier to get to (basement)--it measures just under 16 inches from base to the top of the saddle, set for 46 degrees dec.
Hope this helps...
#5 Ad Astra
Ad Astra
Posted 22 March 2011 - 12:37 PM
Don't know what your budget is, but you might consider an adjustable pier from Pier Tech - they allow you to raise or lower your entire scope about 2 feet - plenty to help you clear the enclosure and raise back up to ideal height.
Dan
