CG-5GT : Setting declination in User Database
2 replies to this topic
#1 RenoNV
RenoNV
Posted 04 April 2011 - 12:53 AM
HC firmware 4.16 (don't have an upgrade cable yet)
I wanted to add some objects to the hand controller via the user database found under Menu. I was able to select the database slot, add the Right Ascension, but with the Declination, I couldn't get the hand controller to stop blinking the "+". None of the numbered keys worked, and the arrow keys just stopped the blinking, but didn't advanced to the numeric value.
So what key selects "+" or "-" declination in a user defined goto?
TIA
#2 RTLR 12
RTLR 12
Posted 04 April 2011 - 01:38 AM
Press the up and down key to select '+' or '-' then press the 'Enter' key to lock it in. You can then proceed with entering the rest of the numbers.
Stan
#3 RenoNV
RenoNV
Posted 04 April 2011 - 06:08 AM
Thank you Stan,
I should have tried that, I could have always pressed Undo if it didn't work. :o
