GM-8 and TMB 130 SS
4 replies to this topic
#1 Mike Holland
Mike Holland
Posted 21 April 2011 - 09:53 PM
For anyone is using this combination, how much counterweight do you use to balance the tube? It seems like the standard weight would be too little. Thanks!
#2 BRCoz
BRCoz
Posted 21 April 2011 - 10:43 PM
I have the APM/TMB 130/1200, I added an 11 lb weight. The scope is 15 lbs. I am not sure what the SS is.
#3 Mike Holland
Mike Holland
Posted 22 April 2011 - 04:40 AM
It is listed as 18.5 pounds, and the rings are another 3 pounds. Add in a finder, and I think that 22 pounds is a good number.
I'd just get 22 pounds in counterweight, but with the weights sitting at the end of a shaft and the scope closer in I know that it doesn't have to be 1:1. Thanks!
#4 drksky
drksky
Posted 22 April 2011 - 05:56 AM
I was using mine on a CGEM with one 23lb CW about halfway down the shaft. The 21lbs losmandy weight should be enough as long as you don't any heavy accessories.
#5 Mike Holland
Mike Holland
Posted 22 April 2011 - 03:20 PM
Ok, thanks!
