Counterweghts for GIRO III
14 replies to this topic
#1 ckwastro
ckwastro
Posted 05 May 2011 - 01:37 PM
Now that Teton has closed, does anyone know of another US-based source for GIRO III counterweights?
If not, will Losmandy weights work on the GIRO counterweight shaft? Thanks.
#2 ad701xx
ad701xx
Posted 05 May 2011 - 07:01 PM
I've been using some Orion Skyview Pro counterweights on my Giro 3. They fit perfectly.
#3 ckwastro
ckwastro
Posted 05 May 2011 - 10:22 PM
Thanks Dave!
I came across those earlier today & contacted Orion so I could get the bore i.d. The weights looked exactly like what came with the mount but I figured I'd better make sure. Thanks for confirming those work.
#4 Jeff in Austin
Jeff in Austin
Posted 05 May 2011 - 10:39 PM
My CW's from my ASGT and Atlas mounts both work fine. They are basically the same but the Atlas version has a small plastic insert that can be popped out of the hole.
#5 ckwastro
ckwastro
Posted 05 May 2011 - 10:58 PM
Thanks Jeff.
Can either you or Dave verify if the 11 lb. counterweight fits as well? If you could confirm either way I'd appreciate it.
Orion gave me an i.d. of 0.7" for the 11 lb. and 0.8" for the 7.5 lb. cw. Not sure why they would be different but that's what the on-line tech support gave me. The GIRO counterweight shaft o.d. is 0.785", so by Orion's numbers only the 7.5 will work. That's the weight I have now, and would like to get an 11 lb if possible, but perhaps I'm stuck with going with multiple 7.5s. Thanks! :bow:
#6 Jim7728
Jim7728
Posted 06 May 2011 - 06:24 AM
Celestron 11lb cw fit fine on the cw bar I purchased from Teton for a GIRO III.
#7 ckwastro
ckwastro
Posted 06 May 2011 - 08:32 AM
Thanks Jim, appreciate it!
#8 dscarpa
dscarpa
Posted 06 May 2011 - 11:24 AM
I use two 11 lb Celestron weights on my Giro 3 with a C9.25 on it. Good balance is needed to keep the alt axis action smooth. David
#9 Krish Mandal
Krish Mandal
Posted 06 May 2011 - 11:46 AM
Jim, nice red color. I just ordered a GIRO2, can't wait to try it.
#10 NHRob
NHRob
Posted 06 May 2011 - 02:47 PM
Hi Krish,
Where did you order it from?
#11 ckwastro
ckwastro
Posted 06 May 2011 - 03:15 PM
Thank you David. That's the configuration I figured I would need to balance the Mewlon properly. Looks like I will be ordering a couple of them.
Thanks again to all for the input.
#12 Jeff in Austin
Jeff in Austin
Posted 06 May 2011 - 07:43 PM
My comment on the ASGT and Atlas CW's were for the 11 lb weight.
#13 Jim7728
Jim7728
Posted 07 May 2011 - 08:24 AM
You'll like it, Krish.
Unfortunately, I sold mine off to fund other stuff. I miss it, but it keeps me from buying another large refractor. :grin:
#14 Krish Mandal
Krish Mandal
Posted 10 May 2011 - 08:24 PM
Hi Krish,
I called up the guys at Tech2000 : http://www.tech2000astronomy.com/giro/
It got here, and boy is it hefty. I'm waiting on the ADM saddles, they should be here in a couple of day -- I can't wait to try it out with my frac.
#15 Krish Mandal
Krish Mandal
Posted 10 May 2011 - 08:26 PM
I will let you know how I like it soon enough. It's not the pretty red that you have, it's the normal silver, but then what's to stop me from spray painting it a custom color?
