I want to mount my Meade 10" OTA on an equatorial
29 replies to this topic
#1 Maxedout
Maxedout
Posted 06 May 2011 - 10:38 PM
Want to keep it under a grand.
The GG5 has a weight capacity of 38 lbs. The OTA is 28 lbs.
I plan on only doing astro work with my canon dslr.
Is this mount a good one for the price?
#2 gillmj24
gillmj24
Posted 06 May 2011 - 10:49 PM
That's a visual capacity. You won't be getting good pictures at 2500mm focal length on a CG5. Even with a focal reducer it is a stretch.
Look for a used Atlas even that is borderline. $1000 won't buy you much quality at the payload you need to carry.
#3 Bowmoreman
Bowmoreman
    Clear enough skies
Posted 06 May 2011 - 11:46 PM
yep. wrong scope (too long focal length) and not enough mount to start AP with... will be massive frustration...
#4 mistyridge
mistyridge
Posted 07 May 2011 - 10:56 AM
You will need a Losmandy G11, Celestron CGE(used) or Celestron CGEM-DX at a minimum.
#5 rmollise
Posted 07 May 2011 - 12:47 PM
All those are nice mounts, but a Meade 10 will ride _quite_ nicely on an Atlas EQ-6, too.
#6 gillmj24
gillmj24
Posted 07 May 2011 - 02:23 PM
Oh yeah it'll ride ok but imaging with that mount and tube will be a challenge. If he said he were visual only I'd recommend the atlas without hesitation. Unfortunately he wants his cake and to eat it too.
#7 rmollise
Posted 07 May 2011 - 04:03 PM
It's more than possible to image with this OTA on an Atlas. Yes, it would be easier with a larger mount...but substantially easier in this case would need to be the next step up from a G11...Titan, AP, etc. ;)
Frankly, I don't think a 10-inch Meade is a very good imaging solution for most folks. It is heavy, and the major "gain" over a C8 is a narrower field...which ain't much of a gain.
#8 meademan4
meademan4
Posted 07 May 2011 - 08:46 PM
The Meade 10" ACF is an excellent choice for imaging CAT man. Nice Wide Field also.
#9 Bowmoreman
Bowmoreman
    Clear enough skies
Posted 07 May 2011 - 09:33 PM
NOT for a noob to AP, it isn't...
between that focal length (can you say spend at least $5 k on a mount)? and it's sheer weight (can you say spend at least $3k on a mount for visual?), it is NOT a scope for AP for the faint of heart... and a CG5?...
:lol:
fuggedaboudit
not gonna happen...
Meade 10'ers are nice scopes, but for AP, one has to know what one is getting into... they are heavy for their aperture...
#10 Gargoyle
Gargoyle
Posted 07 May 2011 - 10:32 PM
The Meade 10" ACF is a good scope for AP, but its challenging and is not easy. I've had a long love-hate relationship with my LX200 and we've been on speaking terms only since its been sitting on a GEM. And even with that it still is a challenge.
For AP you'll need a mount that can handle the weight (28 lbs naked, and there's a whole mess of other stuff that goes on there too - camera, finder, rails, etc.). You'll also need to respect the focal length constraint.
I'd say you'd be at a disadvantage with a CG5, and should re-think that first.
Jerry
#11 jgraham
jgraham
Posted 07 May 2011 - 10:48 PM
Hmmm, for a smallish CCD a 10" is a big scope, but for a DSLR it should work fine. A CG5 is probably a tad light unless you're careful. I've been imaging with an LXD75 AR-6 and a DSI Pro III and this is a fairly heavy scope (about 28+ pounds fully loaded), but I wouldn't recomend it for a beginner.
#12 rmollise
Posted 08 May 2011 - 08:55 AM
Nice wide field, huh? It may have other strengths, but even reduced to f/6.3...Not So Much to that. :lol:
#13 meademan4
meademan4
Posted 08 May 2011 - 09:35 AM
The field is awesome. Even reduced to 6.3. :roflmao:
#14 hickeydp
hickeydp
Posted 08 May 2011 - 09:36 AM
I did put my old Meade 10" on my old Atlas and for visual it was fine if a little prone to vibrations when focusing making that job difficult.
Imaging was a whole different matter. To image, a guide scope is essential adding to the overall weight along with whatever camera+imaging accessories you use. In my case I very rapidly maxed out the mount.
If well balanced it will swing it around but I found that the amount of counterweight needed at the end of the bar caused some nasty vibrations that made imaging impossible and focusing was near impossible. In a nutshell, with all that weight, I never got a useable image.
After that experience I sold the M10 in favour of the much lighter C9.25.
I should also add that this change didn't solve all my problems. I've been trying to image for about 2 years now and only in the last 6 months do I feel like I'm getting a handle on things. This is largely due to the fact that I gave up my stubborn pursuit to image at long FL and resorted to my WO110 at 650mm. Guiding this on my EQ6 was a joy and I finally managed to get some images I would be happy for others to see (still not great but presentable). Only when I gave into this did I feel like I started to learn what I was doing. Before with long FL heavy scopes it was an exercise in frustration.
I now have a G11 that's awaiting first light so I'm hoping this will give me the extra pulling power I need to move beyond the WO.
#15 rmollise
Posted 08 May 2011 - 09:59 AM
Awesomely _narrow_. :lol:
#16 clchildress
clchildress
Posted 08 May 2011 - 01:11 PM
I have found my intro to imaging with a CGEM and a light (13lbs) f/5 Schmidt-Newtonian challenging...I can only imagine the frustration of attempting to begin imaging with a heavy, "slow" tube riding on an even lighter mount...
#17 Maxedout
Maxedout
Posted 08 May 2011 - 06:47 PM
Seems you dont know your own nuts from your mounts CAT man. :lol:
#18 rmollise
Posted 09 May 2011 - 05:19 PM
I know about one nut around here, though. :roflmao:
#19 Bowmoreman
Bowmoreman
    Clear enough skies
Posted 09 May 2011 - 09:47 PM
:cool:lets keep it calm and clean, gang...
#20 Krish Mandal
Krish Mandal
Posted 10 May 2011 - 12:21 AM
How the heck can a 10-inch SCT have a wide field? My 8-inch is a 2000mm FL. :shrug:
#21 jrcrilly
jrcrilly
    Refractor wienie no more
Posted 10 May 2011 - 12:30 AM
Depends on your frame of reference. Your C8 has twice as wide a field as a C14 at 3900mm! :lol:
#22 tboconnor
tboconnor
Posted 10 May 2011 - 04:01 AM
Thats nothing - I have a meade 12inch ACF that is riding on a CGEM. Will I try imaging with it? Might give it a shot with an OAG, but I will stick with the WO 90 megrez for the most part :)
#23 Bowmoreman
Bowmoreman
    Clear enough skies
Posted 10 May 2011 - 05:53 AM
only when using hyperstar, bot then it is an f2...
and NOT for visual
#24 Geo.
Geo.
Posted 10 May 2011 - 08:15 AM
It's really amazing how much larger a C11 or 2120 is than a C8 or 2080. Reminds of sailboats, add four feet and there's twice the bottom to clean and the dockage doubles too!
#25 tboconnor
tboconnor
Posted 10 May 2011 - 08:33 AM
Tell me about it - Im going to have to do some serious weight training to get comfortable lugging stuff about now. :tonofbricks:
