First attempt at sketching: Sun 2011 mai 8
9 replies to this topic
#1 skoop
skoop
Posted 12 May 2011 - 02:15 PM
Here is my first attempt at sketching.
Sun on Mai 8, 2011
Hardest part was the disk background. :)
At the bottom of the disk is a small paper defect that got darker.
I do not have a scanner so I took a photo, added the dark background in Gimp and adjusted the white balance so it resembles the color of paper.
#2 cildarith
cildarith
Posted 12 May 2011 - 03:04 PM
Looks like a fine start. Thanks for sharing.
#3 Erix
Erix
    Toad Lily
Posted 12 May 2011 - 04:03 PM
Very nice! It can be a little difficult to make out granulation in white light. the seeing and transparency have to be darned near perfect for it, especially at low aperture.
#4 Jef De Wit
Jef De Wit
Posted 13 May 2011 - 08:07 AM
Really fine sketch! What magnification did you use?
#5 skoop
skoop
Posted 13 May 2011 - 12:46 PM
I actually made a sketch of sunspots to my notepad just for fun while we had our first picnic of the year.
After that I decided to go to a art supplies store and buy some paper, 3 pencils and a stick of charcoal to see, can I actually do it by following Jeremy Perez instructions on June 2010 Astronomy Now.
Erix, I can actually see the surface but it is one of those mirage type of experiences. One moment it is there and then it is gone. :) "Granulation" on this drawing is actually a caused by the surface of the paper.
Jef De Wit, I used a 25mm EP and for sunspots 5mm Hyperion and 7.5mm TAL Plössl with 2x Barlow. I have a 90mm f/6.6 refractor.
I think I am hooked! Thank you Jeremy! ;)
#6 Special Ed
Special Ed
Posted 13 May 2011 - 02:08 PM
Skoop,
That's nice work for a first try. :waytogo: What type of white light filter did you use?
#7 frank5817
Posted 13 May 2011 - 07:44 PM
Skoop,
I like your white light sketch very much.
Just keep going and do what what works.
Frank :)
#8 Uwe Pilz
Uwe Pilz
Posted 14 May 2011 - 01:15 AM
The sketch shows well what happened at the sun ths day. Congratulation!. You may consider to add additional detail skecthes next time: You scope shows more than you can show in a whole disc.
#9 skoop
skoop
Posted 14 May 2011 - 02:19 AM
Skoop,
I made my own filter from AstroSolarTM Safety film.
I made it 2 parts so I can replace or repair the filter in the holder. Filter disk is made of thick black velvet (flocking?) paper. patent pending ;)
#10 skoop
skoop
Posted 14 May 2011 - 05:37 AM
...You may consider to add additional detail skecthes next time: You scope shows more than you can show in a whole disc.
You are absolutely right. Here it is.
This is not the original but I redraw my rough sketch today.
