Prinz Optics 550 - Anybody have one?
37 replies to this topic
#1 EastAnglian
EastAnglian
  • Loc: Cambridgeshire Fens UK
Posted 09 August 2011 - 03:50 PM
I've been searching the forums to see if I could find anybody with one of these scopes, but without success. Somebody on here must have one surely? I have recently acquired one of these and would be interested in hearing from other owners. I have one slight alternative motive; I need some measurements.
I found on a terrestrial first light, that this appears to be a good objective, but with very poor contrast. On removing the focuser assembly, I discovered two baffles in the tube; both reflecting huge amounts of light. If anyone has one of these, and they'd be agreeable to removing the focuser, I would like the measurements of the two baffles from each end. The reason I need this is because from marks I found, I suspect that one of these has been removed at some time, and I can't be sure if it's in the correct position. How critical these two baffle positions are, I'm not sure?
If somebody has one of these scopes and doesn't feel inlclined to remove the focuser, I don't mind in the least; I'd still be interested in opinions of this model.
Cheers
Max
p.s. pics will follow eventually.
#2 grendel
grendel
  • Loc: Canterbury, Kent, UK
Posted 09 August 2011 - 04:21 PM
I have a prinz astral 500, not sure what the difference between this and the 550 is, mine is Towa brand 60x 910 on an equatorial mount.
Grendel
#3 EastAnglian
EastAnglian
Posted 09 August 2011 - 06:11 PM
Hi Grendel!
I thought you might be along. The 550 is also 60x910 but circle K. As soon as I get it together, I'll do an album. I did do a piccy of the focuser today, which you can see at the bottom of this page:
http://www.cloudynig...ll/fpart/3/vc/1
The wooden tripod is the sturdiest of all the wooden tripods I have. The mount is heavy and simple; no setting circles. The finder fits in a reducing dovetail, and is pretty good, although it had been severely abused by somebody very heavy handed! If the blackening I intend to do helps the contrast to a marked degree, I suspect I will be very happy with this scope.
How does your 500 perform?
Max
#4 grendel
grendel
Posted 10 August 2011 - 08:58 AM
my 500 is a Towa and an excellent performer, I am starting to suspect that the Prinz scopes with *00 numbers must be Towa and with **0 numbers Kenko (circle K) like the 660 I own.
Grendel
#5 EastAnglian
EastAnglian
Posted 10 August 2011 - 08:28 PM
Hi Grendel,
You may well have something here.
Cheers
Max
p.s. I have replied to your other mail to me.
#6 grendel
grendel
Posted 12 August 2011 - 02:32 AM
well here are some pics of my focuser if thats any help -
Grendel
#7 grendel
grendel
Posted 12 August 2011 - 02:33 AM
and the baffles from the eyepiece end.
#8 grendel
grendel
Posted 12 August 2011 - 02:34 AM
and from the objective end of the draw tube.
#9 grendel
grendel
Posted 12 August 2011 - 02:43 AM
dimensions - draw tube length 205mm
baffle from eyepiece end 74.4mm
baffle from objective end 6.3mm
diameter of baffle hole 14.4mm (both baffles believed to be identical - but its a bit difficult measuring a hole diameter 74mm down a tube - a small bar inserted into the draw tube and rested inside the baffles appeared to be parallel.
Grendel
#10 EastAnglian
EastAnglian
Posted 12 August 2011 - 07:05 AM
Here are a couple of pics of my tube and focuser assembly. As you can just about see from the tube pic, it is very bright in there!!
Max
#11 EastAnglian
EastAnglian
Posted 12 August 2011 - 07:06 AM
Tube:
#12 grendel
grendel
Posted 12 August 2011 - 01:00 PM
I would say you definitely need to do something about that, it should improve things no end.
Grendel
#13 EastAnglian
EastAnglian
Posted 12 August 2011 - 02:15 PM
Agreed Grendel. I've ordered some Protstar from the States today. I'll keep you updated.
Cheers
Max
#14 seafury
seafury
Posted 18 January 2012 - 05:13 PM
Hi yes I have one it was given to me as a present in about 1968, used it a lot then, even got an A level in Astronomy, now 44 years later still have it and got it out of its box tonight for the first time in over 30 years it still looks ok, thought it was not very good at the time as unless you had at least a 3 inch refractor or an 6 inch relector it wasn't a proper telescope
regards Gordon :)
#15 Spyke
Spyke
  • Loc: Scotland
Posted 19 January 2012 - 03:02 PM
Interesting, nd great first post, Gordon! :)
I have a complete Astral 500 package incoming soon... ;)
Ant
#16 seafury
seafury
Posted 19 January 2012 - 03:10 PM
Hi Spyke, thanks and where in Scotland are you based
Gordon
#17 Spyke
Spyke
  • Loc: Scotland
Posted 19 January 2012 - 04:55 PM
Near Inverness in the Highlands, Gordon. Good stargazing country! ;)
Ant :cool:
#18 seafury
seafury
Posted 20 January 2012 - 02:05 AM
Not so good down here in Cornwall all mist and grey clouds lol, I was born in Elgin which is why I asked and my wifes family all come from Lossiemouth
gordon
#19 EastAnglian
EastAnglian
Posted 20 January 2012 - 05:42 AM
regards Gordon :)
Hi Gordon,
Just picked your post up. I'd be very interested to see pics of your scope if possible? If you don't want to post here, PM me and I'll send you my email address. You don't give your location in your details, but if you're anywhere near me (Peterborough UK) I'd love to see your scope.
Regards
Max
#20 seafury
seafury
Posted 20 January 2012 - 03:00 PM
Hi Prof will take some as soon as i can, its not much to look at though
gordon
#21 seafury
seafury
Posted 19 March 2012 - 11:25 AM
Hi Prof will try and attatch photo
regards Gordon
#22 seafury
seafury
Posted 19 March 2012 - 01:48 PM
hi prof here is very belated photo
#23 EastAnglian
EastAnglian
Posted 22 March 2012 - 10:03 AM
Hi Gordon!
Lucky boy, yours is in far better condition than mine! Could you do me a couple of close-up piccies of just the mount please? I've still not found anybody else who has one of these scopes; so far we're the only two.
Cheers
Max
#24 seafury
seafury
Posted 22 March 2012 - 12:48 PM
Hi will try and post pics
#25 EastAnglian
EastAnglian
Posted 22 March 2012 - 12:50 PM
Wow Gordon, you've got the box too!
Look forward to close-ups if you can manage them.
Cheers
Max
