AP Images Taken with Original NexStar
1128 replies to this topic
#851 hopskipson
hopskipson
  • Loc: Queens, New Yawk, Light pollution Headquarters!
Posted 27 January 2013 - 09:56 PM
Here's my first attempt at Jupiter using the original nextimage camera. It was an extreamely windy and partly cloudy night. I caught a clearing when Jupiter was high in the sky. I proccessed in Registax 6 and Gimp. Thanks for looking and feel free to comment and reproccess.
#852 Maverick199
Maverick199
  • Loc: India
Posted 28 January 2013 - 01:22 AM
Excellent M 42 Mgauthier. :D
James, your Jupiter is very good, try with a barlow next time now that you would have grasped gamma / contrast / shutter etc.,
#853 hopskipson
hopskipson
Posted 28 January 2013 - 02:25 PM
I used a 2x TV powermate. How much more power is possible. I was thinking either the 4x or 5x or should I goto 3x?
#854 TmaninTn
TmaninTn
  • Loc: Nashville, TN USA
Posted 06 February 2013 - 01:51 AM
Recent shot of Jupiter, about 600 frames 3X barlow with the Neximage cam (the old one). Seeing was kinda meh, but it was tracking well so I snapped this one. I plan on messing about with some of the m42 shots I took, there could be some worthy of processing.
#855 Joe Turner
Joe Turner
  • Loc: Louisiana
Posted 19 February 2013 - 11:04 PM
My first post to CN forums! (Apologize in advance for its length.)
When I was 12, I spent 6 months grinding my own mirror to make an 8" Newtonian. About that same time, Celestron came out with their distinctive orange 8" SCT and I said "one day I'm going to get one of those!” Fast forward over 40 years and I am the proud owner of a new Nexstar 8SE.
I have learned so much from CloudyNights on setup, alignment, tracking, astrophoto techniques. Many posters have commented that M42 is probably not the best first target for an amateur, but how can you resist during winter? Here is my first astrophoto attempt. Prime focus, 6.3FR, 20 sec exposures, ISO 1600, about 140 frames, DSS, then Photoshop.
My question (if this is the wrong thread for it, please forgive me and point me in the right direction) has to do with not being able to photograph anything above 50 deg altitude because the camera hits the base. I have modified my scope with “Ron’s rail” and added extra weight to the back end by putting on my camera flash unit and still cannot balance the scope far enough forward for the camera to miss the base. Numerous posts speak of the best seeing for photography is near the zenith, but I am severely limited in what I can image. How do most of you solve this problem?
Joe Turner
#856 TmaninTn
TmaninTn
Posted 20 February 2013 - 12:03 AM
Welcome to the Nexstar loony bin Joe, great group of folks here. I'm sure someone will be along shortly with and answer to your question about the clearance, I haven't had that issue yet but I know what you mean.
And that is one great shot of M42! Congrats!
#857 Tel
Tel
  • Loc: Wallingford England
Posted 20 February 2013 - 05:42 AM
Hi Joe,
A very warm welcome to CN and to this particular, Nexstar forum ! :bow::bow: Also, many congratulations on an excellent image of M42. :bow::bow:
Talking of mirror grinding, I did exactly the same at the same time; (i.e. 40 years ago);with an 8" blank. I've still got it and have it on good authority that, probably more by luck than judgement, I managed to figure it well !
I'll bet though you got further with yours than I did with mine. I never ever did get around to polishing it ! :bigblush:
But to your question.
Assuming the addition of "Ron's Rail" indeed allows you, in theory to clear the mount base with your camera assembly if you push the OTA forward enough to achieve this, I further assume that your concern is with front end heaviness produced which, in turn, is likely to cause the OTA to drop. (?)
If this is the case, then if the weight of the added flash unit is insufficient to counter balance, there is a counterweight system available from JMI which might prove more successful. (Link below). This indicates the counterweight placement forward on the rail, but presumably it can also be placed aft; with or without some ingenuity or improvisation.
Also, by the same token, don't be reluctant to make small, tightening adjustments to the altitude axis clutch in order to help support the extra foreward distribution of weight.
As to imaging at the Zenith, and of course this position is likely to be the clearest on any given night, it is however certainly not a good idea to attempt imaging here where Alt.Az. mounts are concerned. Couple the idiosyncrasies of the spur gear drive with the azimuth axis "algorithmic contortions" it needs to perform to keep track of the target directly above this axis, and one can imagine the anomalies which inevitably will arise.
http://www.jmitelesc...ng_brackets.htm
Hoping this helps,
Best regards,
Tel
#858 Peter9
Peter9
  • Loc: Yorkshire - Born & Bred
Posted 20 February 2013 - 08:12 AM
More great images by the A.P lads (Those who are able to get out that is). Please, keep them coming, there so good to look at.
Well done on your first attempt James. I'm sure the guys will keep you on the straight and narrow as far as A.P goes.
Thanks for posting.
Regards. Peter.
#859 Joe Turner
Joe Turner
  • Loc: Louisiana
Posted 20 February 2013 - 07:54 PM
Thanks Tel,
I actually keep a bookmark to a 2011 post you made detailing the alignment process (slight front end heavy, up and right movement etc) that helped me tremendously. I was worried about making it TOO front end heavy. If I go to the full extent of my very short "Ron's rail", I can just clear the base and I am about 1 inch forward of what I had marked as "slightly" front end heavy. (no room for JMI weight) Should I put it that far forward then re-adjust my Anti-backlash settings? Is that what you mean by tightening the altitude axis clutch? Thanks again.
Joe
#860 Tel
Tel
Posted 21 February 2013 - 05:05 AM
Hi Joe,
I'm pleased and flattered to learn that particular list of instructions of mine helped !
In terms of your above question though:---
No, adjustment of the altitude clutch doesn't refer to backlash adjustment although it's always wise to double check after such.
In this case however, it relates to the amount of friction one imparts to the altitude axis so that its elevation is not causing the altitude motor to labour while, at the same time, the OTA is prevented from slipping or falling under its own weight.
It's a very simple operation which has been detailed by our CN and Nexstar forum colleague, Art Dent, and is featured in the above "Sticky" on this forum page entitled;
"Links and Best of Celestron nexstar Forum".
http://www.cloudynig...4057680/page...
From this, go into the subtitle; "Useful Forum Threads" and then to "Altitude Nut Adjustment".
Footnote: Don't be too faint-hearted about making the adjustment. Place your OTA as far forward on the dovetail as is necessary to give your camera a minimum but safe amount of mount base clearance and then, with everything secure, elevate the OTA to the Zenith, ensuring that there is no slippage, (i.e. the altitude motor elevates it "tooth for tooth" cleanly).
Next, as Art describes: from the Zenith position, bring the OTA back down under "full steam" (Slew Rate 9) to the horizontal, keeping that other hand hovering, but not touching, beneath it, purely as a safeguard.
At the horizontal, remove your finger smartly from the control button. If the OTA stops dead or almost dead, (and I believe there is a safeguard mechanism in these later 'scopes, as opposed to my older Nexstar 8i, whereby the OTA is not so abruptly [immediately] arrested in order to place less load on the motor/bearings); then that's fine: no adjustment should be necessary.
Any tendency however, to drop under its own weight, i.e. continue downwards towards the base of the mount after the button has been released, will require a little more tightening of the adjustment nut.
Any doubts or problems with this and/or other matters, please let us know. We're all here to help.
Best regards,
Tel
#861 Joe Turner
Joe Turner
  • Loc: Louisiana
Posted 21 February 2013 - 07:28 PM
Tel,
Thanks to the link to the article on the altitude clutch. Mine seems to be holding the extra front end weight just fine.
Fine tuned anti-backlash too. Now if only I can get clear skies to test it out.
Unfortunately here in south Louisiana the forecast is clouds and rain for the next 2 weeks!
Thanks again,
Joe
#862 butsam
butsam
  • Loc: Ohio
Posted 21 February 2013 - 08:37 PM
Great photo, Joe!!!! Out of curiosity, what camera did you use? (You may have said in the alphabet soup, but I am a newbie, so I still need a decoder ring...lol :)
Keep the great shots coming!!!!
#863 Tel
Tel
Posted 22 February 2013 - 04:21 AM
Hi Joe,
Glad to hear all adjustments seem to have gone OK.
You can of course test the 'scopes' smoothness of operation to a certain extent while waiting for the clouds to clear, by artificially programming the 'scope, "in the comfort of your own home", by literally kidding it into an alignment and then making some pracice slews to this and that called-up object just to see that all is tight and functioning.
Best regards,
Tel
BTW. Don't forget though, to let us know how it goes when you do get a break in the clouds and are able to get outside for real ! :waytogo: !
Best regards,
Tel
#864 Joe Turner
Joe Turner
  • Loc: Louisiana
Posted 22 February 2013 - 07:19 PM
Camera is a Canon 1D Mark IV (since discontinued). I originally got it for its speed for bird photography.
When I first started practicing alignment and tracking with my new 8SE, i tried some piggyback shots with it first.
M31 below was shot with the Canon 1D Mark IV, zoom lens at 280mm F4.0, 1250 ISO, piggyback on 8SE,
30 sec exposures, 50 light frames, 25 darks, flats, flat darks, bias, DSS then PS.
#865 butsam
butsam
  • Loc: Ohio
Posted 22 February 2013 - 07:58 PM
Wow, awesome shot of M31!
If you don't mind me asking (sorry if this is a complete newbie question, still getting the hang of things), how did you get such a wide FOV with your 8SE? Was it just because of the camera settings you mentioned, or is there something else helping you with FOV?
Excellent shots!!!
#866 Joe Turner
Joe Turner
  • Loc: Louisiana
Posted 22 February 2013 - 08:40 PM
This was only using the 8SE for tracking. This is shot through my camera lens at 280mm piggybacked on top of the 8SE tube.
So, I guess, that photo may be a little out of place for this thread. Sorry for the confusion!
Joe
#867 Maverick199
Maverick199
  • Loc: India
Posted 26 February 2013 - 01:51 AM
Awesome images guys, keep 'em coming. I am not frequenting as before but I do see images now and then.
Tel's advise is always spot on and helpful isn't it. :bow:
#868 Joe Turner
Joe Turner
  • Loc: Louisiana
Posted 02 March 2013 - 05:40 PM
As a AP newbie, I sure picked a tough subject for my second DSO, but I've always been fascinated with the Crab Nebula.
Stock 8SE, 6.3FR, 20 sec exposures, 1600 ISO, 140 lights, 80 darks, 10 bias, 10 flat, 10 dark flat, DSS, PS3.
#869 Greyhaven
Greyhaven
  • Loc: 16 miles south of the Buckfield Mall
Posted 03 March 2013 - 09:32 AM
Joe
Nice shot! I think that there is a lot more detail in that shot that could be enhanced with careful processing. You caught a good one.
BE Well
Grey
#870 Tel
Tel
Posted 03 March 2013 - 03:43 PM
Nice imaging, Joe ! :bow::bow::bow:
As Grey says though, there is more detail contained within this one, as perhaps this attempt to bring it out, shows ? :idea:
Best regards,
Tel
#871 Joe Turner
Joe Turner
  • Loc: Louisiana
Posted 04 March 2013 - 08:14 PM
Wow, do I have a lot to learn! Everything I tried to bring out the filaments just increased noise.
What's even more amazing, Tel, is that you did that working with a small jpeg file!
#872 TmaninTn
TmaninTn
Posted 04 March 2013 - 10:01 PM
One of the coolest things about this forum is when Tel remixes a picture. It speaks to the reason we all love astronomy, to see more of what is out there.
#873 Peter9
Peter9
Posted 05 March 2013 - 03:55 AM
Thanks for the images Joe and well done. :bow: :bow:
Wonderful remix of the Crab Tel. :bow: :bow:
Thanks for posting.
Regards. Peter.
#874 Tel
Tel
Posted 05 March 2013 - 04:11 AM
Many thanks guys for your kind comments but conversely, I feel privileged that you gents allow me to "mess" with these fine images of yours. :bow::bow:
(Of course there's always the ulterior motive: namely that it provides me with an occasional opportunity to practise my P/Shop et al processing, which is about all I'm doing these days given that we've endured weeks of practically solid cloud cover here in the UK) ! :4
Once again, many thanks and best regards,
Tel
#875 hopskipson
hopskipson
Posted 27 March 2013 - 07:34 PM
A couple of moon shots with the original Neximage
Exodus, Plato and Cassini
