AstroDevices Nexus WiFi DSC, Half Hitch and iPad
61 replies to this topic
#51 astrodevices
astrodevices
    Vendor-Astro Devices
  • Loc: Sydney, Australia
Posted 27 December 2012 - 01:23 AM
You do not need to be connected to any network (home WiFi or 3G/4G) in order to use an Android tablet or an iOS based device with Nexus and SkySafari Plus/Pro. Once you install SkySafari Plus/Pro on your tablet you are all set.
Nexus creates its own WiFi Access Point that any Android based (WiFi enabled) device (or iOS based device or a PC or a Mac) can connect to.
Best Regards,
Serge.
#52 zawijava
zawijava
  • Loc: West Paris, Maine 04289
Posted 20 January 2013 - 04:38 PM
Serge and others,
I'm interested in using a AstroDevices Nexus with a Nexus 7 [Google 7" Tablet] and SkySafari [for Android] on my Astro-Physics 400 QMD mount. Can you tell me if the encoder cables come with the Nexus? Also, I operate my mount and accessories via a 17 AH 12v battery with cig lighter sockets. Can I operate the Nexus via 12v? Is a cig lighter cord supplied with the Nexus? thanks! -Tim
Best Regards,
Serge.
#53 astrodevices
astrodevices
Posted 21 January 2013 - 07:25 AM
Hello Tim,
Nexus is supplied with a cigarette lighter adapter and you can power Nexus from 9 to 25V DC.
The encoders cable is not included but can be supplied at extra cost ($10) .
Also, you will need SkySafari Plus or SkySafari Pro as basic version does not support any telescope interface.
Best Regards,
Serge.
#54 zawijava
zawijava
Posted 21 January 2013 - 09:20 AM
Thanks for the quick reply Serge! Another question regarding Firmware Updates. I assume any updates are done via the USB Port on the Nexus? Can updates be accomplished via a Mac? thanks, -Tim
...I think I just answered my own question upon closer review of your website....looks like a yes I believe.
Hello Tim,
Best Regards,
Serge.
#55 astrodevices
astrodevices
Posted 21 January 2013 - 02:19 PM
Hello Tim,
You are welcome.
Firmware updates are done using a USB flash drive - it just needs to be formatted as FAT32. So, yes, you can use a Mac.
Best regards,
Serge.
#56 LateViewer
LateViewer
  • Loc: Pelham NY
Posted 08 May 2013 - 01:45 PM
Great thread. I was not aware of the Nexus system. I am still a bit confused about encoders and whose would work best an an Obsession like Dob.
#57 astrodevices
astrodevices
Posted 08 May 2013 - 06:26 PM
The most popular choice for encoders is to use optical 10000 steps per revolution encoders from US Digital:
http://www.usdigital...rotary/shaft/S6 .
Some people use AMT102/AMT103 capacitive encoders (hollow shaft, 8192 steps per revolution) available from http://www.digikey.com. AMT102/AMT103 require a bit of work to install them as they were designed to be mounted on motors.
Best regards,
Serge.
#58 Daud
Daud
  • Loc: AZ, Scottsdale
Posted 21 May 2013 - 08:18 AM
Serge,
what other specifications for the S6 encoders on the page you pointed to ?
#59 astrodevices
astrodevices
Posted 21 May 2013 - 08:29 AM
The specifications for the S6 encoders are as follows:
1. CPR (counts per revolution) - multiply by 4 to get the number of quadrature steps per revolution.
2. Shaft diameter - most people use 1/4".
3. Index - one of the pins has the index signal - one pulse per revolution, not used by most DSCs.
4. Output - most (if not 100%) DSCs need 'single ended'.
5. Torque - does not really matter which one.
In other words for 10000 steps S6 encoders the part number is S6-2500-250-NE-S-D.
Best Regards,
Serge.
#60 Defenderdan
Defenderdan
Posted 22 May 2013 - 04:12 PM
Thanks for this thread! Are there any other write-ups about installing encoders, specifically for a fork drive on a Meade 10" SCT.
#61 Mickey_C
Mickey_C
  • Loc: AZ
Posted 12 June 2014 - 01:36 PM
I hope it's not bad form to bring back this old thread... it just seems like the right place to keep this stuff concentrated.
I have a Unistar Deluxe with encoders that setup for interface to a Sky Commander XP4. In reference to the encoders, the mount has a label that says "Encoders 1250 steps/rev 5000 pulse/rev".
I'd like to know if I can just hook that RJ45 cable directly to the Nexus.
#62 astrodevices
astrodevices
Posted 12 June 2014 - 06:20 PM
Yes, you can use your existing cable with Nexus. Nexus is fully compatible with Sky Commander's encoder cable.
Best Regards,
Serge.
