Meade, Please Let Me Override Your LS North Align!
25 replies to this topic
#1 astrogeoguy
astrogeoguy
  • Loc: Thornhill, Ontario, Canada
Posted 14 March 2012 - 02:23 PM
:help:An open plea to Meade's Lightswitch engineers. :help:
Last night I took my LS-8 out to a public outreach event in a parking lot in Richmond Hill, ON. The sky was beautifully clear and dark in all directions.
I set up my LS-8 about 20 feet from the last row of cars and powered it up. It performed flawlessly until the North alignment step.
The scope swung around to north, stopped, made the small motions to pinpoint magnetic north, then adjusted itself for true north. I stood behind it and watched it carefully aligns itself a good TEN DEGREES off Polaris, which I could easily see above me! After that, the 2-star alignment failed to find Sirius, then Rigel! I eventuially carried out a manual 2-star alignment with huge azimuth shifts required to center each one.
Normally, the scope works beautifully, but this incorrect north fix is a major flaw in the process, and occurs at home and at public events.
Please, I beg you, give us a new firmware revision with the ability to accept or adjust the find north determination! It's a few lines of code! It only needs to give me 20 seconds to decide before it proceeds automatically.
I love this scope! This fix would, I'm quite sure, make these scopes far more reliable for suburban users, and result in far fewer RMAs from frustrated owners.
I look forward to your response. Thanks in advance.
#2 astrogeoguy
astrogeoguy
Posted 14 March 2012 - 06:59 PM
Just to make sure I'm being clear - the Lightswitch's horizontal OTA slews in azimuth to find the local magnetic North, then slews by the amount required to correct for the local difference between local grographic and magnetic North (in my case, 10.5 degrees west). At that point, the OTS azimuth should be nearly exactly the same as Polaris'. If I stand behind the scope and soght towards Polaris, the OTA is way off left or right depending on the local magnetic interference. Then it slews up towards the first alignment star, but the entire foundation of the auto-align is compromised at that point.
Chris
#3 Tempe
Tempe
  • Loc: Moscow, Russia
Posted 15 March 2012 - 04:49 AM
Hmm. I would never thought that Meade uses North alignment in this "full-auto" LS series. I believed that North alignment is an obsolete feature of first-generation GoTo systems. Personally, I had the same unpleasant experience with small ETX-80. After using Nexstar SE (which doesn't require pointing North or tube leveling) it was kinda new to me to use a compass,and check local magnetic deviation before observing session. And, after all these tricks, the scope veered away from proposed alignment star for at least 8 deg. And so on. I hate North align!
Now it's pretty interesting to compare these two full-auto Goto's from Meade (LS) and Celestron (SkyProdigy). They may (or may not) have different logic of self-alignment.
Clear skies,
Serge
#4 astrogeoguy
astrogeoguy
Posted 15 March 2012 - 10:40 AM
I personally think that Meade's determination of local magnetic North is highly accurate. It's that local sources of magnetic interference (including some steel elements on tripods, vehicles, etc.) perturb the local magnetic North direction.
Walk around your property with a compass and see for yourself. I just want to be able to correct for that.
Chris
#5 ChrisHall
ChrisHall
Posted 20 February 2013 - 03:29 AM
I've had my LS-8 for a week now - fantastic telescope. But I've noticed the following about its North alignment process:
- The tube aligns very, very carefully and consistently 10 degrees East of North (declination is 2 degrees W where I live so I'm not worrying about which North!)
- It then looks, typically, for Rigel; aligns about 10 degrees East of it, and says it can't find it...
- BUT it then says it'll try again, and slews about 10 degrees West, and finds it.
It would be absolutely great to know a bit more about how the software works. I get the impression that this is a sort of last-ditch correction for a badly aligned sensor, based on previous successful manual alignments - but equally, I might be reading too much into this.
Any thoughts would be welcome...
#6 ChrisHall
ChrisHall
Posted 20 February 2013 - 03:37 AM
I've had my LS-8 for a week now, and am absolutely delighted with it - AND have been exceptionally fortunate with clear skies, which are pretty rare in the UK!
My observations on the North alignment process are a bit puzzling so I thought I'd share them:
- The scope aligns very carefully (and consistently, wherever I place it) 10 degrees East of North (declination is 2 degrees here so I'm not particularly worried about which North)
- It then looks for (typically) Rigel, and slews to about 10 degrees East of Rigel.
- It says it can't find it, but will have another go.
- It then slews about 10 degrees West, and finds it with no problem (usually).
It would be fantastic to understand a bit more about how the software works, and I may be reading too much into this but... Is this a sort of last-ditch fix for a badly aligned magnetic sensor, whereby the scope tries a correction based on earlier, successful, manual alignments?
Any views welcome, folks.
#7 ChrisHall
ChrisHall
Posted 20 February 2013 - 03:43 AM
Oops - you can tell I'm a newbie - thought I'd lost the first version of the above post and so did it again. Apologies.
#8 REC
REC
  • Loc: NC
Posted 20 February 2013 - 10:02 AM
Just an FYI...right now from my location, it finds the first star, which I don't remember and the second star is Rigel and that's where it stops. I don't usually pay close attention as it is aligning it's self, just that what ever the stars are, make sure I can see them over head. I just know it is Rigel as when I first start observing I start with the last star that is in the EP to adjust the focusing. Noticed Rigel was a double star:)
Bob
#9 astrogeoguy
astrogeoguy
Posted 20 February 2013 - 06:20 PM
You might also check that your time zone is correct and that DAylight Savings is being handled properly. This will shift the entire sky an hours worth. You can check your scope's time/date on the handbox by hitting Mode and then scrolling down the various values RA, Dec, etc. The Time Zone settings are under the Preferences menu.
#10 Christopher Erickson
  • Loc: Waikoloa Village, Hawaii
Posted 21 February 2013 - 01:14 PM
Is there a "Calibrate Sensors", "Calibrate on Home" or any other Calibrate functions in the hand controller's setup?
Magnetic North calibration might help, if there is a way to do it.
And cars and other large metal objects can throw off detection of correct magnetic North.
I hope this helps.
#11 Christopher Erickson
Posted 21 February 2013 - 01:17 PM
Clear skies,
Serge
Yes, even these "full auto" scopes need to somehow find True North in order to work. The tiny alignment camera has a narrow field of view.
This is one of those times where Celestron's "Pick any three bright stars" method really can work a lot better.
#12 Christopher Erickson
Posted 21 February 2013 - 01:19 PM
Chris
Setting up near power lines can really disrupt Magnetic North detection too.
#13 astrogeoguy
astrogeoguy
Posted 21 February 2013 - 11:01 PM
No - the LS scopes use Autostar III and only have centre finder (calibrates the camera), and training the alt and az drives. No options for the other types of calibrations you mentioned above.
#14 Christopher Erickson
Posted 22 February 2013 - 12:06 AM
Bummer!!!
#15 ChrisHall
ChrisHall
Posted 24 February 2013 - 05:50 AM
Many thanks - interesting idea (and all ideas welcomed!) I tried it - I tried fixing the time zone (it defaults to 'auto') but sadly no difference. Next I will reload the firmware completely (as soon as I can get hold of one of those obscure mini SD cards) and try that. Then sadly it's back to the shop...
#16 ChrisHall
ChrisHall
Posted 28 March 2013 - 07:52 AM
And just to finish this rather sad tale... It was back to the shop with the ls8. Unknown repair timescale, and no more ls8s available in the uk, so all money refunded and I got a Celestron cpc8 instead. Much simpler and I very much hope there's less to go wrong! Also, I have to say, it's about ten times more robust, and very, very much more stable - no focusing vibration. Recommended.
#17 tarbat
tarbat
Posted 02 March 2015 - 10:15 AM
Yes, what we need is a way of entering a special code at power-up:
lscal1
Then when using the setup menu:
lscal2
There is an extra menu option:
lscal3
And then you can calibrate the north sensor and level sensor:
lscal4
For those of us who's LS telescope is out of warranty, perhaps Meade would like to share the special code, since this is a lot easier and cheaper than returning the telescope to Meade for them to do this.
Once I got access to the special code, I was able to calibrate the north sensor, and now even doing a manual 2 star alignment, the first star is nearly perfectly centred in the eyepiece.  Automatic alignment also now works, rather than locking on to the wrong star(s) which is what was happening before I got access to these calibration functions.  Why the north sensor is so far out of calibration on my LS6 is anyone's guess.
Edited by tarbat, 02 March 2015 - 01:58 PM.
#18 tarbat
tarbat
Posted 04 March 2015 - 06:52 AM
So, I've been experimenting with the north alignment on my LS6 (Lightswitch), to see how far out the north sensor really is.  This is a telescope that was returned to the retailer within the 12 month warranty, and their technician reported that he found nothing wrong with the telescope, that "it aligned successfully first time and put the guided tour targets into the field of a 26mm eyepiece as it should".  Now, the only difference between my use of the telescope and their technician's testing of the telescope is location.  I'm in the far north of Scotland, and their technician is in Sussex I think.
So, to test the north alignment, I did the following, after disabling the automatic alignment.
1. Powered up, got GPS fix etc.
2. Started an AltAz 1 star, manual alignment.
3. Let it find north, and when it asked to select a star, pressed BACK to cancel the alignment.
So, in theory, at this point the telescope is pointing to the magnetic north as measured by the north sensor.  I then marked a point on the opposite wall (with a blob of plasticine) to show where this point was, and shutdown/restarted the telescope.
Next, I did an AltAz 2 star manual alignment, and for each of the 2 stars, just accepted the position slewed to, so accepting the positions that the telescope thought were the star locations.  Now, when I return the telescope to point towards the original magnetic north (the platicine blob), the Azimuth reading is out by nearly 40 degrees!
P1010054
So, looks like the Magnetic Declination for my location is completely wrong.  Current MagDec for my location is only -3.5° (W), so why is the telescope adjusting by nearly 40 degrees to correct for my location?
magdec
I'm not happy that my telescope is 40° out of alignment, but at least with the hidden factory calibration functions now available I can correct for it.  Just frustrated that the retailer's technician could find nothing wrong, but maybe the MagDec at his location was okay.
Edited by tarbat, 04 March 2015 - 08:43 AM.
#19 tarbat
tarbat
Posted 05 March 2015 - 07:23 AM
Specifically to Wolfgang on the Meade4M forum, who I know is reading this.  I can't answer on the Meade4M forum as I can't get any response from their moderators to approve my account.
To access the Factory Calibration:
1. Turn on telescope, and when the very first message appears, press the 9 button
2. When it asks for a code, enter 752
3. Once the telescope is up and running, the factory calibration function is in the setup menu.
Obviously, if your telescope is still within the warranty period, then you should return it Meade for them to carry out any factory calibration.
#20 Wolle1949
Wolle1949
  • Loc: Germany
Posted 05 March 2015 - 08:14 AM
Hello Tarbat,
I just read your post.
Thanks alot. I have the telescope two years and no more warranty. Here in Germany there is no representation of clients Meade more.
Many Thanks. Sorry for my bad English.
I also had problems with accessing Meade4M.
Visit the website: http://astronomy.qteaser.com
Mark and write an email, it will help you.
Sorry for my bad english.
Best greetings from Germany
Wolle1949
#21 Wolle1949
Wolle1949
  • Loc: Germany
Posted 06 March 2015 - 06:37 AM
Hi Tarbat,
I am thankful that I am not the only user with the Problem  :)
My telescope is the time to check in once Meade Europe next week and I'll get an answer if the problem is solved.
When, has not been solved as yours, the problem, I would love to work with you, try to recalibrate after the "Factory Calibrate" perform menu.
If I'm going to need help, I would like to advise me with you, that's ok?
I'm going to follow the instructions you have it already described and then correct, let's see what happens.
Best regards from Germany to the north of Scotland.
Wolfgang
#22 tarbat
tarbat
Posted 05 July 2015 - 05:06 AM
So, I put together this little video guide for a colleague.  It shows how to access the factory calibration options on the Meade LS telescopes.
#23 Wolle1949
Wolle1949
  • Loc: Germany
Posted 06 July 2015 - 09:04 AM
Hi Tarbat,
thanks for the video. I'll test it.
Great that they like to pass the info.
Greetings from Germany
Wolfgang
#24 astrogeoguy
astrogeoguy
Posted 07 July 2015 - 07:30 PM
This is great that we have more abilities available to us, but calibrating the compass doesn't the problem of local magnetic interference by a car, etc.
I'd still like to be able to override the LS's determination of north if it happens to be incorrect at that particular observing site.
Regards, Chris
#25 Wolle1949
Wolle1949
  • Loc: Germany
Posted 08 July 2015 - 11:03 AM
Hi Tarbat,
I've tested it and am very satisfied.
greetings
Wolfgang
