iOptron iEQ30 - 12 arc-sec p-p periodic error
16 replies to this topic
#1 orlyandico
orlyandico
  • Loc: Singapore
Posted 22 May 2012 - 11:35 AM
Now I've got your attention? :grin:
I'm subscribed to William Optics' Facebook, and one of their recent posts was "new setup for high quality imaging" with the 81mm and 102mm 5 element refractors "with iOptron IEQ 30 mount (excellent tracking around +- 6 sec.)"
#2 GooglyEyes
GooglyEyes
  • Loc: Colorado
Posted 22 May 2012 - 12:17 PM
Yes. I was considering that mount, recently, and waiting to see a few reports on it.
Mar
#3 MRNUTTY
MRNUTTY
  • Loc: Mendon, MA
Posted 22 May 2012 - 04:51 PM
Only, where did you find the PEC spec?
#4 orlyandico
orlyandico
  • Loc: Singapore
Posted 22 May 2012 - 06:35 PM
On william optics facebook page. I presume they had measured it...
#5 tjugo
tjugo
Posted 23 May 2012 - 05:26 PM
Wow... If the 12 arcsec p-p periodic error is the 'typical' value of this mount out of the box, ioptron is pushing the envelope.
12 arcsec p-p is in the +2.5K realm (vixen SXD)
Jose
#6 MRNUTTY
MRNUTTY
  • Loc: Mendon, MA
Posted 24 May 2012 - 06:26 AM
If they get that on the 30, the 45 will be sweet! Can't wait for mine.
#7 moligpy
moligpy
  • Loc: Santa Clara, California
Posted 28 May 2012 - 01:30 AM
I have one iEQ30 even better than that.
The following picture is the raw curve:
#8 moligpy
moligpy
Posted 28 May 2012 - 01:36 AM
After linear fitting:
#9 MeadeSquared
MeadeSquared
Posted 28 May 2012 - 03:24 AM
Just judging from the reports on this site, it looks as if IOptron is building high quality products. There was another thread on here about a month ago stating they got PE on their iEQ45 down to 6 arcsec after PPEC and programming through PEMPro. Someone else on that same thread was claiming 4, getting close to atmospheric interference levels.
link to previous thread
http://www.cloudynig...5/o/all/fpart/1
If ALPH is watching, he'd like to see Log files. ;)
#10 rjsc2000
rjsc2000
  • Loc: Portugal
Posted 28 May 2012 - 03:49 AM
Is PEC enabled when measuring?
#11 moligpy
moligpy
Posted 28 May 2012 - 07:54 PM
Of course not.
#12 tjugo
tjugo
Posted 28 May 2012 - 09:20 PM
Of course not.
WOW... It was not obvious that PEC was not enable, cause the iEQ45 has a PE of at least twice this value.
So the iEQ30 tracks much better than the iEQ45. The original FB post of William Optics, said that the iEQ30 was more accurate than the ieq45, and it looks like it is.
I wonder how low you can get after PEC.
Cool!
Jose
#13 nomosnow
nomosnow
  • Loc: Fort Saskatchewan,Ab ,Canada
Posted 29 May 2012 - 09:04 AM
The spec sheet on this mount says it has permanent pec.? What does this mean it ? It does not say permanent pec for the iEQ45.?
#14 gdd
gdd
  • Loc: Lynnwood, WA (N/O Seattle)
Posted 29 May 2012 - 10:23 AM
The spec sheet does not promise 12 arc-sec p-p for this mount. We don't know if this was a typical or an exceptionally good sample that was measured.
Gale
#15 tjugo
tjugo
Posted 29 May 2012 - 11:01 AM
Permanent PEC means that the mount/HC will store the PE curves and play them back without retraining it after a power cycle.
Jose
#16 tjugo
tjugo
Posted 29 May 2012 - 11:08 AM
Gale
At this price point it would be impossible for manufacturer to include a max PE in the specs. The 'cheapest' mount that includes a PE spec is the EM11.
So far there are 2 ieq30 that performs under 12 arcsec PEC. The William Optics sample and moligpy's
Let's wait for more data, but so far so good.
Jose
#17 kyang
kyang
  • Loc: Fremont, CA
Posted 01 January 2014 - 01:13 PM
Hello all,
Have been using iEQ30 for almost an year. Only use it with AT65EDQ (FL 460mm), Orion 50mm guider, and DSLR. Got some reasonable photos and start curious about the performance.
I used PHD to measure PE last night. Follow the approach of: http://www.telescope...ew.asp?tid=4131 and here is the result with 40+min tracking.
:bawling: Looks like my mount is not so lucky to be the 12-arcs-p-p one. Instead, it is more like 35-arcs-p-p. With PEC enable (simulated by PECPrep), it might get 15-arcs-p-p ...
Any other iEQ30 owners would like to show their results ?
Happy New Year to you all.
-Kai
