June 2012 Celestial Calendar
No replies to this topic
#1 Dave Mitsky
Dave Mitsky
Posted 31 May 2012 - 09:55 AM
June Celestial Calendar by Dave Mitsky
All times, unless otherwise noted, are UT (subtract four hours and, when appropriate, one calendar day for EDT)
6/1 The Moon is 1.5 degrees south of the first-magnitude star Spica (Alpha Virginis) at 4:00; Saturn is 7 degrees north of the Moon at 5:00
6/3 The Moon is at perigee, subtending 32 arc minutes from a distance of 358,484 kilometers (225,595 miles), at 13:00
6/4 Full Moon (known as the Flower, Rose or Strawberry Moon) occurs at 11:12; a partial lunar eclipse takes place across most of North and South America, the Pacific Ocean, eastern Asia, and Australia, reaching maximum at 11:03
6/5 Neptune is stationary, with retrograde (western) motion to begin, at 6:00
6/6 Venus is at the descending node today; Venus is at inferior conjunction at 1:00; an historic transit of the Sun by Venus reaches its peak at 1:30
6/7 Jupiter is 5 degrees south of the bright open cluster M45 (the Pleiades) in Taurus at 6:00
6/8 Mercury is at its greatest heliocentric latitude north today; Mercury is 1.0 degree north of the bright open cluster M35 in Gemini at 13:00
6/10 Neptune is 6 degrees south of the Moon at 5:00
6/11 Last Quarter Moon occurs at 10:41
6/12 Asteroid 2 Pallas is 0.8 degree south of the Moon, with an occultation occurring in northern Canada, eastern Russia, and most of Japan, at 17:00
6/13 The earliest sunrise of the year occurs today; Uranus is 5 degrees south of the Moon at 1:00; the Curtiss Cross, an X-shaped illumination effect located between the craters Parry and Gambart, is predicted to occur at 3:25
6/15 Venus is 4 degrees north of the first-magnitude star Aldebaran (Alpha Tauri) at 5:00
6/16 The Moon is at apogee, subtending 29 arc minutes from a distance of 405,787 kilometers (253,798 miles), at 1:00
6/17 The earliest morning twilight of the year occurs today; Jupiter is 1.1 degrees south of the Moon, with an occultation occurring in northern Canada, at 8:00
6/18 Venus is 2 degrees south of the Moon at 1:00
6/19 New Moon (lunation 1107) occurs at 15:02
6/20 Summer solstice in the northern hemisphere occurs at 23:09
6/21 Mercury is 5 degrees south of the first-magnitude star Pollux (Beta Geminorum) at 18:00; Mercury is 6 degrees north of the Moon at 19:00
6/24 The latest evening twilight of the year occurs today; asteroid 18 Melpomene (magnitude 9.8) is at opposition at 16:00
6/26 Saturn is stationary, with prograde or direct (eastern) motion to begin, at 9:00; the Purbach Cross or Lunar X, an X-shaped illumination effect involving various rims and ridges between the craters La Caille, Blanchinus, and Purbach, is predicted to occur at 12:02; Mars is 6 degrees north of the moon at 15:00
6/27 The latest sunset of the year occurs today; First Quarter Moon occurs at 3:30; Venus is stationary at 4:00
6/28 The Moon is 1.4 degrees south of Spica at 11:00; Saturn is 6 degrees north of the Moon at 12:00
6/29 Pluto (magnitude 14.0, size 0.1") is at opposition at 16:00
Giovanni Cassini (1625-1712), Charles Messier (1730-1817), and George Ellery Hale (1868-1938) were born this month.
The normally very minor Boötid meteor shower peaks on the night of the First Quarter Moon, June 27.
The Moon is 11.0 days old and is located in Virgo on June 1 at 0:00 UT. Large tides will take place from June 3 through June 6. A partial lunar eclipse occurs from 9:59 to 12:06 UT on June 4. The Moon is at its greatest northern declination of +21.7 degrees on June 18 and its greatest southern declination of -21.7 degrees on June 4. Longitudinal libration is at a maximum of +7.3 degrees on June 9 and a minimum of -6.2 degrees on June 24. Latitudinal libration is at a maximum of +6.8 degrees on June 24 and a minimum of -6.9 degrees on June 10. See http://www.lunar-occ...ota/iotandx.htm for information on lunar occultations. Visit http://saberdoesthes...does-the-stars/ for tips on spotting extreme crescent Moons and http://www.curtrenz.com/moon06.html for Full Moon data. Times and dates for the lunar light rays predicted to occur this month are available at http://www.lunar-occ...o/rays/rays.htm
The Sun is located in Taurus on June 1. The Sun reaches its farthest position north for the year on June 20, the longest day of the year in the northern hemisphere. There are 15 hours and one minute of daylight at latitude 40 degrees north.
Brightness, apparent size, illumination, distance from the Earth in astronomical units, and location data for the planets and Pluto on June 1: Mercury (magnitude -1.8, 5.2", 97% illuminated, 1.30 a.u., Taurus), Venus (magnitude -4.1, 57.0", 1% illuminated, 0.29 a.u., Taurus), Mars (magnitude 0.5, 7.9", 89% illuminated, 1.19 a.u., Aries), Jupiter (magnitude -2.0, 32.9", 100% illuminated, 5.98 a.u., Taurus), Saturn (magnitude 0.5, 18.4", 100% illuminated, 9.02 a.u., Virgo), Uranus (magnitude 5.9, 3.5", 100% illuminated, 20.52 a.u., Cetus), Neptune (magnitude 7.9, 2.3", 100% illuminated, 29.84 a.u., Aquarius), and Pluto (magnitude 14.0, 0.1", 100% illuminated, 31.34 a.u., Sagittarius).
Mercury is in the northwest, Mars is in the southwest, and Saturn is in the south in the evening sky. At midnight, Mars is located in the west and Saturn in the southwest. Venus and Jupiter can be found in the east and Uranus and Neptune in the southeast at dawn.
At midmonth, Mercury is visible during evening twilight, Venus rises at 5:00 a.m., Mars sets at 1:00 a.m., Jupiter rises at 4:00 a.m., and Saturn transits the meridian at 9:00 p.m. and sets at 3:00 a.m. local time for observers at latitude 40 degrees north.
Mercury reappears in the evening sky by the second week of the month. It’s situated between Pollux and a waxing crescent Moon on the evening of June 21. The speediest planet reaches a greatest eastern elongation of 26 degrees on the night of June 30 (July 1 UT). At that time, Mercury is 42% illuminated, subtends 7.9 arc seconds, and shines at magnitude 0.4.
Venus is in inferior conjunction with the Sun on the evening of June 5. An extremely rare transit of the Sun by Venus, the last until 2117, takes place on that date. The transit lasts for 6 hours and 30 minutes but won’t be visible in its entirety from the contiguous United States. First contact for North America occurs within two minutes of 22:05 UT (6:05 p.m. EDT). (The geocentric time is 22:10 UT.) Second contact takes place about 18 minutes later. At 1:30 UT geocentric time, Venus is 9.4 arc minutes from the center of the Sun. The geocentric time of third contact is 4:32 UT, with Venus exiting the solar disk 18 minutes later. Venus subtends 58 arc seconds, almost a full arc minute, and is 0.289 astronomical units or 2.4 light-minutes from the Earth at the time of the transit. Venus reappears in the dawn sky by the second half of June. On the morning of June 27, Venus is three degrees above Aldebaran and five degrees below Jupiter. By the end of the month, Venus has decreased in apparent size to 45 arc seconds, increased in illumination to 16%, and brightened to magnitude -4.6.
Mars travels eastward through Leo this month and enters Virgo on June 20. It passes just to the southeast of the fifth-magnitude binary star Chi Leonis on June 1 and southwest of the fourth-magnitude binary star Beta Virginis on June 27. Mars glows at magnitude 0.8 and subtends less than seven arc seconds by month’s end.
Jupiter appears again in early June shortly before dawn. The waning crescent Moon passes just to the north of Jupiter on the morning of June 17. By the end of June, the King of the Planets is located approximately half-way between M45 (the Pleiades) and Aldebaran some two hours prior to sunrise. It shines at magnitude -2.0.
Saturn ends its retrograde motion on June 26, when it is less than five degrees to the north of Spica. The tilt angle of Saturn’s rings is 12.5 degrees this month, which is the smallest angle for the year. Eighth-magnitude Titan is due south of Saturn on June 5 and June 21 and due north on June 13 and June 29. On the night of June 11, twelfth-magnitude Enceladus lies due west of Saturn and the tenth-magnitude moons Tethys, Dione, and Rhea are located to the west. Titan is situated about an arc minute to the northwest of Enceladus. For further information on Saturn’s satellites, browse http://www.skyandtel...pt/3308506.html
Uranus can be found in Cetus about 1.5 degrees to the east-northeast of the sixth-magnitude star 44 Piscium.
During June, Neptune is located approximately three degrees to the south-southeast of the fourth-magnitude star Theta Aquarii. The eighth planet begins retrograde motion on June 5.
Finder charts for Uranus and Neptune can be found at http://media.skyandt...eptune-2012.pdf
Pluto is two arc minutes south of the seventh-magnitude star SAO 161635 on June 17. The distant dwarf planet reaches opposition on June 29. A finder chart appears on pages 52 and 53 of the June issue of Sky & Telescope.
Comet C/2009P1 (Garradd) fades from tenth to eleventh magnitude as it travels southeastward through Cancer. It passes roughly parallel to the west of a line joining the fifth-magnitude stars Nu and Xi Cancri.
Asteroid 18 Melpomene shines at magnitude 9.8, as it heads westward through Scutum and into Serpens Cauda. Data on asteroid occultations taking place in June is available at http://www.asteroido.../2012_06_si.htm
A free star map for June can be downloaded at http://www.skymaps.com/downloads.html
Forty binary and multiple stars for June: Struve 1812, Kappa Bootis, Otto Struve 279, Iota Bootis, Struve 1825, Struve 1835, Pi Bootis, Epsilon Bootis, Struve 1889, 39 Bootis, Xi Bootis, Struve 1910, Delta Bootis, Mu Bootis (Bootes); Struve 1803 (Canes Venatici); Struve 1932, Struve 1964, Zeta Coronae Borealis, Struve 1973, Otto Struve 302 (Corona Borealis); Struve 1927, Struve 1984, Struve 2054, Eta Draconis, 17-16 Draconis, 17 Draconis (Draco); 54 Hydrae (Hydra); Struve 1919, 5 Serpentis, 6 Serpentis, Struve 1950, Delta Serpentis, Otto Struve 300, Beta Serpentis, Struve 1985 (Serpens Caput); Struve 1831 (Ursa Major); Pi-1 Ursae Minoris (Ursa Minor); Struve 1802, Struve 1833, Phi Virginis (Virgo)
Notable carbon star for June: V Coronae Borealis
Fifty deep-sky objects for June: NGC 5466, NGC 5676, NGC 5689 (Bootes); M102 (NGC 5866), NGC 5678, NGC 5879, NGC 5905, NGC 5907, NGC 5908, NGC 5949, NGC 5963, NGC 5965, NGC 5982, NGC 5985, NGC 6015 (Draco); NGC 5694 (Hydra); NGC 5728, NGC 5791, NGC 5796, NGC 5812, NGC 5861, NGC 5878, NGC 5897 (Libra); M5, NGC 5921, NGC 5957, NGC 5962, NGC 5970, NGC 5984 (Serpens Caput); M101, NGC 5473, NGC 5474, NGC 5485, NGC 5585, NGC 5631 (Ursa Major); NGC 5566, NGC 5634, NGC 5701, NGC 5713, NGC 5746, NGC 5750, NGC 5775, NGC 5806, NGC 5813, NGC 5831, NGC 5838, NGC 5846, NGC 5850, NGC 5854, NGC 5864 (Virgo)
Top ten deep-sky objects for June: M5, M101, M102, NGC 5566, NGC 5585, NGC 5689, NGC 5746, NGC 5813, NGC 5838, NGC 5907
Top five deep-sky binocular objects for June: M5, M101, M102, NGC 5466, NGC 5907
Challenge deep-sky object for June: Abell 2065
The objects listed above are located between 14:00 and 16:00 hours of right ascension.
