NexStar+ controller bootloader 0080 error
23 replies to this topic
#1 GMikea
GMikea
  • Loc: Texas
Posted 20 June 2012 - 04:22 PM
I know that I have perhaps committed a cardinal sin as a novice but felt that all would be fine according to manuals and what I read, but to the point I added the telescope plugin to Stellarium sw and connected to my new NexStar+ controller via the usb/rs232 port. The controller was talking ok up to that point. Now the controller only boots to the message 0080 error and stops. #$#$@%$$ my bad. Im not sure it can be recovered. I did open a RM to Celestron with full disclosure as to what I did. Has this happened to anyone else? I can power up on menu and info and get a hidden menu thats stable but the port doesn't proliferate and wont talk to the pc or visa versa. Im guessing plugin sw might have been for the older controller, but then again I am thinking that it should have been some basic ascii or control commands going out and thats all????
:foreheadslap: Appreciate any input.
#2 RTLR 12
RTLR 12
  • Loc: The Great Pacific NorthWest
Posted 20 June 2012 - 06:25 PM
Celestron has had some trouble with the early NexStar+ hand controllers. They will work fine for a while and then problems show up. The first thing to try is to hook up to Celestron Firmware Manager (CFM) and upgrade the HC. This will usually take care of problems. If this doesn't work you will need to get a hold of Celestron and get a replacement.
Stan
#3 GMikea
GMikea
  • Loc: Texas
Posted 20 June 2012 - 06:34 PM
Thanks. the HC wont even recognize the handset so hopefully Celestron will reply to my question to them.
#4 3snows
3snows
Posted 20 June 2012 - 06:36 PM
I don't think you broke it. I've connected my NexStar+ HC to Stellarium without issue.
#5 GMikea
GMikea
  • Loc: Texas
Posted 20 June 2012 - 08:36 PM
Thanks - thats good to know as it lessens my potential error. I waited until the HC booted and in a command wait state, so I feel better. Now if Celestron will fix or replace my one week old controller at no charge I will be extremely happy. Perhaps others might have had this issue(I hope) for reference back to them.
#6 Midnight Dan
Midnight Dan
  • Loc: Hilton, NY, Yellow Zone (Bortle 4.5)
Posted 21 June 2012 - 06:17 AM
Hi GMikea:
Not sure if I understand your terminology.
Normally, we use HC to indicate the Hand Controller, which is also referred to as the handset. So I'm not sure I understand what you're using HC to mean in your statement above.
Also, in your original note you say:
... to Stellarium sw and connected to my new NexStar+ controller via the usb/rs232 port
There is no usb port on the scope. The port on the bottom of the handset is what should be used to communicate with a PC. It is a serial connection and if your PC does not have a serial port, you'll need a usb to serial adapter. Did you connect to the bottom of the handset? If you used a usb to serial adapter, which brand did you use?
-Dan
#7 Bob Griffiths
Bob Griffiths
    Getting Grouchy
  • Loc: Frederick Maryland
Posted 21 June 2012 - 07:38 AM
Can anyone tell me how they like these new PLUS controllers..
Any advantages ??
Just curious .. I'm not likely to replace any of my "old" HC's
Bob G
#8 3snows
3snows
Posted 21 June 2012 - 07:50 AM
I've only had the +HC so can't comment. From what I can tell the Undo button is now labeled Back and there is the Celestron logo button. I don't know what that button is for.
The firmware versions are also 5.x, which oddly enough, the NexRemote software only recognizes 4.x firmware. I selected the latest firmware on the NexRemote settings page and it seemed to work fine however.
#9 GMikea
GMikea
  • Loc: Texas
Posted 23 June 2012 - 04:52 PM
Sorry, I am a newbie. I have the HCupdater software on my PC. I also have or had the usb port(virtual serial) connected to the handset successfully and could remotely control movement using the NexRemote sw via the cable and port while plugged into the bottom of the handset RJ4 serial port and all was well. The virtual serial to usb cable works fine and I use the same drivers on some other Weather reporting stations with older hardware.
I fired up Stellarium with the telescope plugin module that was set to load at bootup. With the Hand Controller connected and on I loaded Stellarium and went to try and move the scope but it was not talking to the controller. I looked at the display and saw the bootloader error. So I exited Stellarium and turned off the power to the HC and back on with the same error. "Verifying packages" and then bang the error code. I then tried to talk to the controller using the HCupdater program. It would never find the Controller yet I could see the port in device manager. IF I were to hold down the info and menu button and power up I got a stable hidden screen and I could connect to the controller on my virtual usb port and the HCupdater sw would show port 1 connected but thats as far as it would go. Trying to hold the two buttons to go into transmit mode etc did nothing. I thought at worst if I could communicate then I could load the binary NIX file that I saw on one of the NexSTar sites using the updater but again I cant force it into xmit mode and if I do a cold boot of the Hand Controller then I get the error message and the PC cannot see the rs232 port via the rj4 plug.
Hope that makes more sense. APPRECIATE EVERYONE'S INPUT SO FAR.
#10 RTLR 12
RTLR 12
Posted 23 June 2012 - 06:22 PM
Mike,
You don't upgrade the new NexStar+ hand controller with the Celestron HC/MC updater. You need to use the new "Celestron Firmware Manager". Go to Celestrons support site and then go to downloads, then go to software and at the bottom of the list you will find; "Celestron Firmware Manager" (CFM) v.1.0.2100. This is the program you need. Download this to your computer. Hook up to the bottom of the HC. turn the power on and open the CFM program. Everything is done automatically.
Stan
Here, let me make it easier...
http://www.celestron...temid=771&nav=0,7
#11 GMikea
GMikea
  • Loc: Texas
Posted 23 June 2012 - 09:19 PM
BINGO. Thanks Zeus, Hera and my hero Steve Reeves as Hercules and to you. [a little star humor]. That did the trick. Kept coming back as cannot find device so I proliferated a new port and the CFM found the device. I hit update and it loaded 10 packages into the HC and seems to be fine now. I am a bit leary of Stellarium for awhile but will work into it.. I have had an open RM into Celestron for a week now with no response from support team at all to my question. Sad but I am glad that there are guys(and gals) like you all to assist me-> I was going nuts. I was dreading sending it in for repair or replacement. Still not sure why it went south on me and gave me that error. The Celestron site and manual I got is vague or even less on the program and never mentioned the data and sw that you pointed out to me. THANKS. I hope I have seen the last of my problems.
thanks again for the rapid response
#12 Midnight Dan
Midnight Dan
Posted 23 June 2012 - 10:38 PM
Time and time again, I've found that the people here on this forum know a lot more about these scopes, and are a lot better at troubleshooting, than Celestron's support!
Nice catch, Stan! :bow:
-Dan
#13 RTLR 12
RTLR 12
Posted 24 June 2012 - 12:42 AM
Any advantages ??
I have only played with 2 or 3 of the new HC+. Did some updating and a couple of alignments on a CG-5, CGEM DX and an 8SE. (Not my mounts) The advatage over the now discontinued old style is that it processes faster (So I'm told) and eventually there will be some upgrades that were not available before. That's what the button with the Celestron logo is for. ??? Some of the 'Lists' have been 'edited' and combined. One new feature is that the display works better in cold weather.
Stan
#14 3snows
3snows
Posted 24 June 2012 - 07:37 AM
Just my 2 cents with my new scope and +HC. I'm surprised that Celestron would release a new component without updating the documetation . The quick start guide and manual still shows the non + HC in pictures and description. Also, the NexRemote software that shipped with the scope was way outdated. You can download the latest from the Celestron website but even that version does not include the 5.x firmware that ships with the +HC. Don't get me wrong, a love my new scope, I just think the product management processes at Celestron are a little sloppy. My company would never allow products to ship like that.
#15 GMikea
GMikea
  • Loc: Texas
Posted 24 June 2012 - 09:31 AM
I downloaded the new NexRemote sw but it still shows the old HC icon w/o the new buttons. I have not tried to hook it up to the HC and am waiting for some more data. Now that the HC sw is restored it says Advanced GT which is not what it said when I first opened the package so I am not sure if the new CFM uploaded a different sw version that is not compatible or not? HC GEM 5.2.1.2064. Seems like it went from 4.xx to this 5 version. I tried to again connect Stellarium and it sees the scope but hitting the alt1 or ctl1 wont move it via the autoguide port. For grins I DLd the NSOL sw and it wont even see the port at all. So I am backing up 10 paces and slowing down a bit and hopefully get some guidance.
Sorry for the dumb questions and am trying now to go back thru the forums and read all the queries. I am on a self guided mission out here in the wilds of Texas but thank god for this forum and members for helping out.
#16 GMikea
GMikea
  • Loc: Texas
Posted 24 June 2012 - 09:49 AM
As I mentioned above my HC sw version now comes up and says Advanced GT on the main menu and has the 5.2.12064 as read from the utilities menu. Has anyone else upgraded using the CFM sw from the link above? The scope appears to function correctly from the HC and as I indicated NSOL and Stellarium wont work from the autoguide port and I am hesitant to connect to the HC port as thats what caused the bootloader to fail in the first place.
Hope someone else can chime in with any assistance to get remote working using the new + controller and updated sw.
#17 GMikea
GMikea
  • Loc: Texas
Posted 24 June 2012 - 10:23 AM
I just went back into Mikes NexStar site and think I found all the information I need about setting up the correct mount and HC. Its in the new section on his site and I am reading it now.
Thanks everyone for being patient.
#18 GMikea
GMikea
  • Loc: Texas
Posted 24 June 2012 - 01:29 PM
Okay I am good to go my bad again. On the CFM Java software at the top is a Hand Controller menuing option to select GEM or AZ. Apparently the default was GEM so it loaded that sw update into my HC and mount. No harm done. Just per Mikes comment on his site is to select the AZ.(I was trying to find that option on the HC and not the CFM sw). Works fine and I am back on the road again
#19 GMikea
GMikea
  • Loc: Texas
Posted 24 June 2012 - 01:44 PM
I am trying to connect via the autoguide port on the mount to use Stellarium. Is that what you are using? I see from the Celestron site that that port is used by several software loads to control motion. I have a feeling or dont know that hooking the stellarium up to the HC will work to control although you said that NexRemote still works. I just dont want to blow that bootloader out again now that I am up and running.
#20 mclewis1
mclewis1
    Thread Killer
  • Loc: New Brunswick, Canada
Posted 24 June 2012 - 01:54 PM
Mike,
First what scope/mount do you have?
Don't touch the autoguider port.
For simple mount control the correct interface port is the serial port on the bottom of the hand controller. The cable required is the Celestron #93920.
I would initially stay away from setting up NexRemote. Keep to simple things like basic scope control via Stellarium.
Read Mike's nexstarsite.com on PC connectivity.
#21 Midnight Dan
Midnight Dan
Posted 24 June 2012 - 03:40 PM
What Mark said. :waytogo:
As I mentioned above, use the port on the bottom of the handset to connect to the PC. The autoguider port is for, well, autogiding. :grin: However, given that the mount is not really designed for long exposure AP, autoguiding is not a particularly useful capability on this mount.
-Dan
#22 GMikea
GMikea
  • Loc: Texas
Posted 25 June 2012 - 07:18 AM
Thanks Mark. I was able to use Stellarium and the RJ4 port on the HC bottom and it worked fine(as it did with the old 4.xx sw and NexRemote which was totally outdated on the CD that I got). I guess the issue that I have as a newbie is the Celestron Docs are horrible for me. The manual was dated 07. There is an addendum for the HC+ BUT no mention of the new CFM autoloading SW, The manual as far as I can tell doesnt even tell me what the autoguide port or aux port on the main SE mount do and I am having to get help from you guys(thanks) to find out some rudimentary items. I think I know what the autoguide does now but I was advised that the aux port parallels the HC+ port so as the arm swings around you dont have to worry about tangle BUT Im not sure YET :)
Its been two weeks now I havent heard back on my Celestron query that I entered online. Thank god for this forum. I will continue to read, pick brains and learn.
#23 mclewis1
mclewis1
    Thread Killer
Posted 25 June 2012 - 02:40 PM
Celestron hasn't updated a manual in many years ... it's one of most glaring deficiencies in their whole product portfolio.
If your scope is an Advanced Series (CG-5) then the original manual is only appropriate for the hardware side of things. The latest manual that contains anything close to the functionality of your hand controller will be the CGEPro manual (which is actually appropriate for firmware up to gem4.19) but the changes beyond what's in that manual are essentially bug fixes and not real changes to the functionality so it's not a real problem.
About the NexRemote CD - put the CD and envelope away somewhere safe. The valuable part is the license key on the envelope. The CD's contents are way down level, the code you want is the NexRemote download on the Celestron website. It's labeled as a 30 day download, ignore this, your license key will create a permanent installation.
The functionality of the various ports has never been well documented. Mike Swanson's website has probably done the best job here. The Aux ports were at one time intended to support a variety of accessories that never materialized. The original devices that were made available to use them were a GPS and a port extension kit ... both now discontinued. The simplest thing to remember about the AUX ports is that they are identical to the hand controller port ... absolutely electrically identical (the wiring is actually totally done in parallel).
#24 mathfarm
mathfarm
Posted 08 November 2013 - 11:05 PM
I had the error described in this post. Took about three tries of downloading the Celestron Firmware Manager (CFM), extracting the software on my computer, and then updating the HandControl. It did work. The link on this post took me straight there.
My error occurred when I accidentally kicked the power supply to my scope. When I plugged it back in, it said that I had a Boot Error... and something about package 0080. All fixed now. Very grateful to this post and the support of CN in general.
Clear Skies,
William
