Longest Exposures Auto Guiding a CG-5 GT?
31 replies to this topic
#26 wolfman_4_ever
wolfman_4_ever
  • Loc: El Segundo, Ca, So. Cal
Posted 20 September 2012 - 06:24 PM
I don't normally post pictures but I can post this test image!
15min guided CG5GT-AS (DSP Hypertuned) ADM side by side, ADM Max Guider
31 lb's
Celestron Onyx 80edf f/6.25 Stellarvue Field Flattener
Mallincam Extreme EXView Had Class 0
Baader 2" Narrowband OIII
Lunt 60mm Cak Scope. Guider (Cak BF taken off of course :p)
Lodestar
Raw and Unprocessed Veil Nebula OIII Test Shot @ 15min. White Red Zone of Los Angeles.
APC Setting 0 and 1
#27 Mkofski
Mkofski
  • Loc: Greenfield, Indiana, USA
Posted 20 September 2012 - 06:59 PM
Dave,
I'm just getting int AP and am no expert but I'd be delighted with that shot as a final not just a test! That was shot with a Mallincam?
#28 wolfman_4_ever
wolfman_4_ever
Posted 20 September 2012 - 11:01 PM
Hi Mike.
Just a mallincam, flatner and filter.. guided..
Just showing the OP the possibilities with the CG5. That was his topic after all.
Here is another test shot..
This is a 25min test shot.. just to compare from 15 to 25.. All the same parameters.. CG5 500mm vocal length f/6.25 Onyx 80
#29 A. Viegas
A. Viegas
  • Loc: New York City/ CT
Posted 23 September 2012 - 08:22 PM
Dave,
Great shots with your MCX! Amp glow is very pronounced but the detail with you Oiii filter is amazing. You said AGC 1 or were those in CCD mode?
al
#30 wolfman_4_ever
wolfman_4_ever
Posted 24 September 2012 - 03:29 PM
Thanks Al.
This was just a screen capture of what was displayed. I could of taken darks and flats to get rid of the amp glow.. But that's not what the Mallincam is designed for.. It does show what it is capable of the Mallincam.
My APC was 0 and 1, my AGC was 0. I was not in CCD mode. CCD mode would of also turned off APC..
#31 ic1313
ic1313
Posted 05 December 2012 - 02:39 PM
For newbie it may be the problem, but if you do excellent polar alignment you can do 100sec without guiding
With actual alignment and 100sec subs and pinpoint stars you can do 300 sec exposures easily with guiding(OAG on C8, f6.3, f-1200mm)
Dec backlash may be the problem but good balance of the telescope is important.
Put the new lubricant in the gears of the mount and you will have smooth action(myself)
my max exposure is 400 sec (not the best one) but sometimes I could do even 500sec when I did proper polar alignment.
guide star is problem on f 1200mm as it is on my setup(C8) :question:
#32 Mkofski
Mkofski
Posted 05 December 2012 - 07:33 PM
Patrick,
I love your shot of Andromeda! It's good to see results like that from a CG5 and DSLR. There is hope!
