Barkonian ATM RFT Refractor Project
6 replies to this topic
#1 Charlie Hein
Charlie Hein
  • Loc: 26.06.08N, +80.23.08W
Posted 30 June 2012 - 11:36 AM
By Kevin Barker
#2 cheapersleeper
cheapersleeper
  • Loc: Sachse TX
Posted 30 June 2012 - 08:31 PM
Great idea!!! I would love to put my Dob building skills into a refractor.
Brad
#3 Rayh
Rayh
  • Loc: Gilbert, AZ, USA
Posted 01 July 2012 - 04:05 PM
This is partly my problem because I am not an ATM but this article really would have been better if there were a single labeled sketch to see what the optics are on the finished product.
Ray
#4 Kevin Barker
Kevin Barker
  • Loc: Auckland, NZ
Posted 03 July 2012 - 02:16 PM
Rayh
You are right I should have put a sketch of the optical config in the article. Although I have described the way I went about it. It is basically all wood. I made this scope just before rushing off for a Venus transit trip to Northern Australia.
Note in the shot below one can see the three 32 mm screws which hold the back plate with secondary assembly in place.
Kevin B
#5 Kevin Barker
Kevin Barker
  • Loc: Auckland, NZ
Posted 03 July 2012 - 02:29 PM
The shot above includes screws which I used to help align the secondary. I removed them. One can also see the central 7 mm bolt and the three 6 mm bolts screwed through the ply. These are used to adjust the secondary tilt.
Below is a shot of the method I used to set objective. note ; I used sandpaper shims as well well as blocks which were screwed down firmly when i was satisfied I was reasonably central.
Although this looks crude it was quite easy after carefully screwing in place then adjusting the secondary to get a laser beam and chesire cross hair collimator to show the optics were well aligned. I have been using this scope daily and it has retained good collimation.
Kevin B
#6 Rayh
Rayh
Posted 05 July 2012 - 09:45 PM
Thanks, Kevin! I get it now. Somehow my brain was thinking a curved secondary.
Ray
#7 Kevin Barker
Kevin Barker
  • Loc: Auckland, NZ
Posted 07 July 2012 - 06:56 PM
Ray
I did consider making a spider but then thought cutting a 40 mm diameter circular piece of timber and mounting to a back plate was easier to fabricate.
It worked!!!
Kevin
