ASIGN Observatory II is back on track!!
265 replies to this topic
#1 bloodhound31
bloodhound31
  • Loc: Canberra, Australia
Posted 14 July 2012 - 03:55 AM
Finally!!!
Wowee, the plan is coming together! A while back I sent my design concept and dimensions to a building engineer. A couple of weeks ago I received the engineer drawings for the structural support. The drawings look fantastic, hi-tech and very professional. And get this, the awesome guy did it for free! Last week I started buying steel and cutting, drilling, welding and assembling.
The very next day, I got a message from a company called Diversified Computing and Consulting. They have very generously donated $500 to get the observatory started and have pledged $500 every month for the next six months! Wow! I am blown away and was really lost for words. Such generosity is rare and I am sure that future patrons of this resource will be very grateful. I know I am!
I also got a $100 donation from a troop-commander of mine from my army days, two astronomy mates, a church friend, plus a pledge at tax time from my insurance broker! There’s a long way to go, but all this certainly helps! At any rate, it gets it all moving and that’s often the hardest part.
This week I have bought the bearers and cut them to size, cut the support studs and cut and drilled all the joining brackets. The welder is coming tomorrow to weld all the brackets on then I can start bolting it and erecting it!! WOOOHHOOO!!
To keep up with progress,Here's a link to the project.
Link
(none-working link changed by Moderator)
#2 Starman27
Starman27
  • Loc: Illinois, Iowa
Posted 14 July 2012 - 07:24 AM
Outstanding! I will definitly watch your progress. This looks like an innovative build. Are there any special conditions that require this construction approach?
#3 bloodhound31
bloodhound31
Posted 14 July 2012 - 11:45 AM
Thanks mate. What do you mean by conditions?
#4 Starman27
Starman27
Posted 14 July 2012 - 03:21 PM
Are therer climate or soil conditions that would be mitigated by your design. It's a great design. I was just wondering if you were dealing with anything special.
#5 bloodhound31
bloodhound31
Posted 14 July 2012 - 11:37 PM
Ah I see. No, nothing special. I live surrounded by houses and trees, so the ones I can't trim down I have to get above. Hence the raised dome platform, while the room below gives me functionality of office space and reduction of obstructions and trip hazards in the room above.
Baz.
#6 bloodhound31
bloodhound31
Posted 19 July 2012 - 06:43 AM
Slowly getting little bits done at a time now. I only get about an hour of daylight after work at the moment, so it's frantic activity the moment I get out of the car.
Progress so far.
#7 bloodhound31
bloodhound31
Posted 22 July 2012 - 08:45 AM
WOOHOO! The Bearers are up! It took a few hours today and into the night, but the hardest part (heaviest) is done!
link
#8 Hilmi
Hilmi
  • Loc: Muscat, Sultanate of Oman
Posted 22 July 2012 - 08:57 AM
Congrats. Looking very good :)
#9 Starman27
Starman27
Posted 22 July 2012 - 09:39 AM
Wonderful progress. What a beautiful sky!
#10 bloodhound31
bloodhound31
Posted 28 July 2012 - 09:54 AM
It doesn't look like much, but I got a heap done today on the observatory. Tomorrow all the studs go up. I thought I would jump in the photo and stand still for 30 seconds tonight to give a sense of scale. (I'm 6'2)
#11 csa/montana
csa/montana
    Den Mama
  • Loc: montana
Posted 28 July 2012 - 11:00 AM
Now, that is impressive! :bow:
#12 JoeT6571
JoeT6571
Posted 29 July 2012 - 05:12 AM
Very impressive. Great build.
#13 bloodhound31
bloodhound31
Posted 29 July 2012 - 07:51 AM
This weekend was a marathon of time available for building. By doing some extra cash work after hours and with help from some awesome people and generous givers, I managed to get together enough funding to buy the wall-framing.
Click here for construction update.
Below: Studs in place - with some minor plumbing (vertical alignment) to be done on each before they are screwed to the flexi-track top and bottom.
#14 bloodhound31
bloodhound31
Posted 01 August 2012 - 09:20 PM
My apologies for the code going funny on my posts. I'm not sure what's happening here, because they seem to work when I post, but a day or so later they all revert to code again... what gives?
#15 csa/montana
csa/montana
    Den Mama
  • Loc: montana
Posted 01 August 2012 - 09:52 PM
If you follow the instructions I gave you in a PM, I'm sure your links will work just fine. :)
#16 bloodhound31
bloodhound31
Posted 02 August 2012 - 09:03 AM
I've tried to do that, but I get this... "This post can no longer be edited because the maximum edit time has expired"
#17 csa/montana
csa/montana
    Den Mama
  • Loc: montana
Posted 02 August 2012 - 09:23 AM
Going back to edit older posts that the 72hr time has expired will give you this message. However, if you will use the instructions on new links, I think you will find it quite easy. :)
#18 bloodhound31
bloodhound31
Posted 06 August 2012 - 02:50 AM
Article in the Canberra Times this morning, page three.
http://www.canberrat...0805-23o7v.html
#19 bloodhound31
bloodhound31
Posted 06 August 2012 - 07:55 AM
#20 bloodhound31
bloodhound31
Posted 20 August 2012 - 08:02 AM
Floor support ring on and floor joists assembled!
The Southern Cross watches over the construction of ASIGN Observatory II.
#21 bloodhound31
bloodhound31
Posted 22 August 2012 - 05:10 AM
Here's this afternoon's progress. External walls on! Latest update http://www.asignobse...onstruction.htm
#22 bloodhound31
bloodhound31
Posted 25 August 2012 - 05:21 AM
#23 bloodhound31
bloodhound31
Posted 25 August 2012 - 08:11 AM
Here's a video of the dome rolling.
http://youtu.be/O8GvTF8NABw
#24 Hilmi
Hilmi
Posted 25 August 2012 - 02:56 PM
Looks good :) Just a question, how will you protect all that metal from corrosion? Also, if it is something you have to paint or spray on, wouldn't it make more sense to do it before putting on the wall panels?
Just my 2 cents
#25 bloodhound31
bloodhound31
Posted 26 August 2012 - 05:30 AM
Just my 2 cents
Most of it is zinc-coated or galvanised. The raw steel will be painted with rust-guard.The outside under the wall-panels has already been done.
