ASIGN Observatory II is back on track!!
265 replies to this topic
#126 tim53
tim53
  • Loc: Highland Park, CA
Posted 18 May 2013 - 09:19 AM
Looking good!
#127 bloodhound31
bloodhound31
  • Loc: Canberra, Australia
Posted 19 May 2013 - 10:26 AM
Thanks Tim!
Finally!! Work has started on the stairs!
The builder's carpenter turned up today and together, we plotted out the stairs. There's a lot to watch out for with building standards, made even more challenging by the curve. Stair calculations are fairly simple though, once you get the hang of them. I just happen to be doing a tertiary course right now and just last week, we had an assessment on stair calculations. Coincidence? I THINK NOT!! ;)
With it all marked out, this week I'm going to crack on with cutting the support posts, fitting them and cutting the hole in the top floor larger to stop people from hitting their heads as they ascend the stair.
#128 hm insulators
hm insulators
  • Loc: Phoenix, Arizona
Posted 21 May 2013 - 11:22 AM
Thanks Tim!
Definitely not the kind of stars people want to see! :grin: Or as I like to put it, headbanging is only good to Metallica or Judas Priest.
#129 bloodhound31
bloodhound31
Posted 24 May 2013 - 03:15 AM
Today I got an early mark from tech school, so I came home to work on the observatory.
I had another log to inspect and grade to see if it was good enough to support the stair stringers. This one had several layers of rot, but it was a beautiful piece of wood. I used a rotary chisel to rake back all the layers until I was happy with what was left. It turned out pretty darned good actually. So far I haven't yet oiled them, so their true colour is yet to come out, but I have left the borer insect marks on the wood as I just love the look.
1. Stairs marked out.
2. Log to strip back.
3. Scribbly little suckers. These patterns are gonna stay!
4. Three posts in position.
#130 bloodhound31
bloodhound31
Posted 29 May 2013 - 11:06 AM
Laying in the drainage pipe.
#131 bloodhound31
bloodhound31
Posted 30 May 2013 - 03:00 AM
Drainage in, shrubbery planted and garden mulched.
#132 lunar
lunar
Posted 30 May 2013 - 07:37 PM
Very nice design and updates! I love seeing the photos as well. You have a very interesting project here, I'm only too happy that you're sharing it with all of us.
#133 hm insulators
hm insulators
Posted 04 June 2013 - 02:32 PM
What kind of shrubs did you plant?
#134 bloodhound31
bloodhound31
Posted 05 June 2013 - 05:02 AM
My pleasure mate!
Baz.
#135 bloodhound31
bloodhound31
Posted 05 June 2013 - 05:03 AM
Mexican orange blossoms. They grow to about 1.2 metres, are evergreen and hedge well.
#136 bloodhound31
bloodhound31
Progress on the stairs. Four stringers cut to the correct angle and calculated for the rise, tread and number of steps. Posts rebated to firmly seat and bolt in each stringer.
Making a massive mess of the space, but it will look a million bucks when I'm done!
#137 bloodhound31
bloodhound31
Posted 10 June 2013 - 03:05 AM
Today was probably the most productive day I've had on the observatory in a long time. Not only did I get hours of precious time, but I also trialled a couple of new tools.
One was a flap disk to fit the angle grinder. It's a round disk covered in overlaying sections of very coarse abrasive. I used it to strip the bark off the wood I am using for the balusters.
The other is a rotary chisel. This is also a round blade for the angle grinder, but it has only three teeth in it. It takes of massive amounts of wood in a single pass and is also very dangerous.
Finally, instead of trying to manoeuvre the belt-sander all over the wood, I turned it upside down on the saw-horse and clamped it down. Now I can move the smaller and lighter pieces of wood over the belt sander with ease. The trick now is to watch the knuckles as I de-skinned two until I got a good technique.
I got the top of the stairs (top floor) cut to match the vertical line of the stringers, plus dressed the hole with some big pine. The stringers are all bolted in and I made a start on the hand-rails and balusters.
#138 csa/montana
csa/montana
    Den Mama
  • Loc: montana
Posted 10 June 2013 - 12:59 PM
I'm loving the staircase railing and supports! Really nice to recycle wood; and this wood is beautiful!
#139 Mary B
Mary B
  • Loc: Minnesota
Posted 12 June 2013 - 05:01 PM
That stairs is going to look so cool with the local wood instead of the typical pine or fir.
#140 bloodhound31
bloodhound31
Posted 15 June 2013 - 02:10 AM
Thanks guys!
WOOT WOOT!! YIPPYKAYAY!!
Finally I've made a start on the treads. The first one was the hardest, just working out how best to mark the template and deciding if I was going to go flush with the outer wall or take the tread right into the wall.
It worked out a lot more secure to go into the wall, fastening supporting timber inside the steel studs. Now I've got two treads in, custom cut to fit exactly. As I showed my wife and bragged about my superior craftsmanship, I jumped hard on both treads - SOLID AS A ROCK!
I'm well pleased. The second tread was a lot faster than the first, so now that I have a technique worked out, I should be able to get around three in every hour I get in there.
#141 csa/montana
csa/montana
    Den Mama
  • Loc: montana
Posted 15 June 2013 - 08:18 AM
That staircase is super awesome! Recycling the available wood +1, and another +1 for the beautiful, natural beauty that railing brings to your observatory!
#142 hm insulators
hm insulators
Posted 19 June 2013 - 12:38 PM
That's going to be lovely when you're done!
#143 bloodhound31
bloodhound31
Posted 23 June 2013 - 10:41 AM
Ready for oil!
Well.... nearly...
I have one tread at the top of the stairs left to cut and install. It's a bit tricky because it is surrounded on two sides by thick steel and some bolts, lips, edges etc - lots to custom-cut around to make it fit.
The insulation is back in the walls with every nook and cranny stuffed to keep the temperatures out/in and also a bit of soundproofing.
The bulk of the work is done but there are a couple of gaps that I want to fill and tidy up. Now the wall-panelling can be cut for the stairs and fitted on the walls.
Big hole!
As soon as the stairs are dressed, there's the issue of the long drop from the top floor. A bannister needs to be constructed with a gate at the top of the stairs.
Stay tuned for the updates as I get to the task.
#144 Mary B
Mary B
  • Loc: Minnesota
Posted 23 June 2013 - 03:12 PM
Old fashioned craftsmanship is what that is :bow: I can't wait to see it all stained and finished.
#145 bloodhound31
bloodhound31
Posted 29 June 2013 - 05:05 AM
^^^ Thanks mate!
Spent today building the upstairs banister out of steel. The thing is rock-steady. Soon I will bolt in some thick board behind it, which gives me three functions.... it blocks some light from below, (even though later there will be drop-hatches over the hole anyway).... it stops my young toddler from crawling through gaps when he's chillin' up there with me..... and finally, it gives me something to put some charts and space photos/posters on. There will be a gate on the end (left of photo) to stop folks from accidentally falling down the stairs.
Downstairs, I cut one more dead tree down to provide the final post on the far left. I also cut the wall-panelling for the stairs. The wall above the stairs is filled, now to put in the panelling for the wall underneath them.
#146 JoseBorrero
JoseBorrero
  • Loc: Puerto Rico Island
Posted 29 June 2013 - 10:58 PM
great looking :waytogo:
#147 bloodhound31
bloodhound31
Posted 30 June 2013 - 08:22 AM
Thank you Jose. :grin:
#148 Mike I. Jones
Mike I. Jones
  • Loc: Fort Worth TX
Posted 08 July 2013 - 09:29 PM
Lordy, dude, that staircase is BEAUTIFUL! And quite original! :bow: :bow: :bow:
Thought about what to cover your fiberglass insulation with? I used this on the underside of my roll-off roof and it works like a champ.
Well done,
#149 bloodhound31
bloodhound31
Posted 11 July 2013 - 10:22 AM
Well done,
Thanks Mike. I'm just going to put Gyprock (plasterboard) up on the ceiling. Good suggestion mate.
Baz.
#150 bloodhound31
bloodhound31
SOOOOOO CLOSE!!
I can almost taste completion! The banister is looking great now filled in, painted, gate on one end and a big thick natural timber handrail to dress it all off.
Upstairs the only big job left is to lay the carpet properly then instal the lighting. That will conclude the upstairs construction and fitout.
Full construction page http://www.asignobse...nstruction.htm"" target="_blank">here.
