Square Peg.....Round Hole
33 replies to this topic
#1 herrointment
herrointment
  • Loc: North of 64
Posted 16 July 2012 - 11:54 AM
The finder scope on the new CPC 11 was rapidly wearing out its welcome. A Telrad would be great but I'm not ready to tape one to the tube just yet.
I started fiddling around with both units and saw that the Telrad might possibly fit into the Synta 50mm bracket.
Off we go...
  • AhBok likes this
#2 herrointment
herrointment
  • Loc: North of 64
Posted 16 July 2012 - 12:00 PM
Take a file to the outside edges of the Telrad and remove just enough material so that the nose of the telrad slides into the rear ring of the finder scope bracket.
That accomplished, time to saw off the front feet of the Telrad.
You should now be able to push the Telrad forward, up to the front mounting ring.
#3 herrointment
herrointment
  • Loc: North of 64
Posted 16 July 2012 - 12:05 PM
Stick some tape on the front mounting ring and mark where the centered and leveled Telrad contacts the ring.
Break out the files (a square file works well) and start removing material and checking your work frequently.
This is what i ended up with.
#4 A. Viegas
A. Viegas
  • Loc: New York City/ CT
Posted 16 July 2012 - 12:06 PM
Ingenious idea... I have unfortunately taped my Telrad onto my OTA, so no going back now :(
What is the best way to remove the sticky tape from your OTA, assuming one day you want to do this? Can you avoid messing up the OTA paint job?
Al
#5 herrointment
herrointment
  • Loc: North of 64
Posted 16 July 2012 - 12:08 PM
You can clean up any rough areas on the Telrad with wet/dry sandpaper. I stopped at 1200....gotta go get some 2000 and then the Telrad will look pretty good.
#6 herrointment
herrointment
  • Loc: North of 64
Posted 16 July 2012 - 12:12 PM
Remove the ring mounting hardware. Disassemble the spring-loaded plunger and re-install the main casing....it holds the Telrad very nicely.
What do you think?
  • havasman likes this
#7 herrointment
herrointment
  • Loc: North of 64
Posted 16 July 2012 - 12:16 PM
The sticky stuff will come off with mineral spirits easily.
#8 csa/montana
csa/montana
    Den Mama
  • Loc: montana
Posted 16 July 2012 - 12:23 PM
Al
Very easy to remove, simply by using dental stripping, or as I used, the thin "leader" line for fishing. Start at one end of the Telrad base, & start "sawing" back & forth, as you apply downward pressure towards you. It comes off very well, leaving little residue behind. You can use any product such as Goop to remove what little residue is left.
#9 csa/montana
csa/montana
    Den Mama
  • Loc: montana
Posted 16 July 2012 - 12:24 PM
I think that's a most clever & nice looking solution! :bow:
#10 herrointment
herrointment
  • Loc: North of 64
Posted 16 July 2012 - 12:31 PM
#11 craytab
craytab
  • Loc: Bethlehem, PA
Posted 16 July 2012 - 12:35 PM
Yeah, good work!
#12 thinairart
thinairart
  • Loc: Denver, Co
Posted 16 July 2012 - 01:06 PM
Now I know all that time I spent trying to jam a square block into a round hole as a kid was not wasted, there is a way to make it work! Nice solution :)
#13 barasits
barasits
  • Loc: Chicago
Posted 16 July 2012 - 04:37 PM
What do you think?
I think you've got great problem solving skills, not to mention the wryest wit at CN.
Geoff
#14 beatlejuice
beatlejuice
  • Loc: Hamilton, ON,Canada
Posted 16 July 2012 - 06:05 PM
Hair dryer, I recently did this and it works great. I thought I would need a screw driver to pry it up: Not necessary. I was even able to pick off the little pieces that remained with my fingers in conjunction with the hair dryer. The metal tube of my scope did get momentarily hot, so don't burn your fingers.
Eric
#15 GlennLeDrew
GlennLeDrew
Posted 16 July 2012 - 10:01 PM
Another sticky tape remover: Skin oil! Yep, just rub a finger tip against the side of your nose and then rub it on the offensive residue. Add more oil if necessary. Clean up with a dab of soap on a damp rag.
#16 pogobbler
pogobbler
  • Loc: Central Indiana, USA
Posted 17 July 2012 - 12:31 AM
What do you think?
You're quite mad, you know.
#17 MAURITS
MAURITS
  • Loc: Belgium
Posted 17 July 2012 - 01:04 AM
Good job Jim!
#18 amicus sidera
amicus sidera
  • Loc: East of the Sun, West of the Moon...
Posted 17 July 2012 - 07:01 PM
Elegant solution - kudos!
#19 Scott in NC
Scott in NC
    Refractor Fanatic
  • Loc: NC
Posted 17 July 2012 - 07:31 PM
+1 :waytogo:
#20 Helveticus
Helveticus
  • Loc: Switzerland
Posted 19 October 2013 - 09:18 AM
excellent idea, well done!
#21 mountain monk
mountain monk
  • Loc: Grand Teton National Park
Posted 19 October 2013 - 01:27 PM
More kudos. One of the more creative solutions I've seen on CN.
Dark skies.
Jack
#22 Geo31
Geo31
  • Loc: The Woodlands, TX
Posted 20 October 2013 - 12:17 AM
WD40
#23 Jon Isaacs
Posted 20 October 2013 - 04:32 AM
+1
#24 herrointment
herrointment
  • Loc: North of 64
Posted 20 October 2013 - 11:09 AM
It is still in service a year later and doing double-duty on the CPC 1100 and the 8SE. If I find another mounting bracket I can use it on the newt!
#25 csa/montana
csa/montana
    Den Mama
  • Loc: montana
Posted 20 October 2013 - 11:16 AM
It certainly is a great idea, and we are glad you shared your ingenuity of this adapted Telrad mount with us!
