What do you think?
6 replies to this topic
#1 Tank
Tank
  • Loc: Stoney Creek, Ontario, CANADA
Posted 10 August 2012 - 05:05 PM
Will this be a good setup or a bit unstable?
Meade 102 APO 14 lbs
SW 180 MAK 16 lbs
plus extras
on the LXD75
Just wondering i tested a bit in daytime but yet to test at night. I think it might be good!
What do you guys think?
Thanks for the feedback!
#2 Peter D.
Peter D.
  • Loc: Central New York
Posted 10 August 2012 - 05:26 PM
It looks a trifle topheavy, but Meade originally sold it with a 30 lb 10" f/4 Schmidt-Newtonian and it's probably not any worse than that. It will be a little wiggly, but it might be tolerable for visual use as long as it's balanced. Try this: while maintaining a good grasp, tip it on the tripod and if you can move it a foot sidewise without it wanting to fall over, it will probably OK as long as the wind isn't blowing too hard. I doubt that it would be steady enough for high power astro-photography.
Good Luck,
Pete
#3 gillmj24
gillmj24
  • Loc: PA
Posted 10 August 2012 - 06:05 PM
Visual should be fine but maybe a bit shaky... don't expect an easy road if you want to do astrophotography though.
#4 Cliff Hipsher
Cliff Hipsher
  • Loc: North Chesterfield, VA
Posted 10 August 2012 - 06:15 PM
I think you need a 2nd mount.
#5 Nebhunter
Nebhunter
  • Loc: Frostbite Falls
Posted 10 August 2012 - 06:31 PM
For visual it might be OK - as long as there is no breeze. That's a lot of mass up there - and it looks like the CW's are maxed out on the shaft extension.
I might suggest doing a side by each setup. This would lower the centre of gravity and less CW required. Less wind resistance would also be a benefit. Just a thought.
#6 Tank
Tank
Posted 10 August 2012 - 06:46 PM
Peter
Its balanced there in the photo, thanks for the tips
gillmj24
not really going the astrophotograph way, just visual.
Cliff
If i got another mount it would be a Atlas or equivalet and i would get rid of the LXD75, the Tripod is a Super Meade Tripod with larger dia. legs than the original 1.5" legs.
Nebhumter
Yup its a extension on there and its maxed out
you might be right i might have to try out the side by side something like this
http://www.teleskop-...Montierung.html
#7 orlyandico
orlyandico
  • Loc: Singapore
Posted 10 August 2012 - 06:47 PM
do note that the side-by-side (ADM sells one too - http://admaccessorie...Series_SBS.htm) weighs a good bit too (5lb or so? the Losmandy side-by-side is 7lb).
