CGEM HC INFO
6 replies to this topic
#1 MHamburg
MHamburg
  • Loc: Brooklyn, NY/Berkshires, MA
Posted 11 August 2012 - 01:21 PM
I love my two year old CGEM! But it has a persistent quirk. I always put it into Hibernation at the end of a run. But upon awakening, it never shows the correct time and date. All other info is correct. Is this a failing battery or something else? All suggestions are much appreciated.
Michael :question:
#2 RTLR 12
RTLR 12
  • Loc: The Great Pacific NorthWest
Posted 11 August 2012 - 01:46 PM
Is your RTC turned on? If so, you need to change the battery and see if that is the problem.
Stan
#3 MHamburg
MHamburg
Posted 11 August 2012 - 02:00 PM
Hi Stan,
RTC is turned on.
Michael
#4 RTLR 12
RTLR 12
Posted 11 August 2012 - 02:36 PM
Michael,
Try changing the battery and see if that works. Do you know how?
Stan
#5 wolfman_4_ever
wolfman_4_ever
  • Loc: El Segundo, Ca, So. Cal
Posted 11 August 2012 - 10:43 PM
How do you change the battery stan?
#6 RTLR 12
RTLR 12
Posted 11 August 2012 - 11:06 PM
Dave,
The RTC battery is located on the back side of the MC board. You remove the 4 screws holding the control panel and you will see the CR2032 battery.
Stan
#7 MHamburg
MHamburg
Posted 12 August 2012 - 09:48 AM
Thanks a ton. Will post results.
Michael
