Atlas PAS LED issue - help!
2 replies to this topic
#1 Red Dwarf
Red Dwarf
  • Loc: Issaquah, WA
Posted 23 August 2012 - 08:27 PM
Hi all,
I finally got the Orion Atlas this week, and tried to use it last night - until the clouds rolled in. :(
From reading literature, Polar Alignment on these mounts are supposed to be fairly accurate. However when I tried to use the polar alignment scope, the entire field of view was just bright RED!!
I have been surfing the internet for a way to dim it and it appears there is a way to do it via hand controller - yet I cannot find it in the manual (both supplied and latest downloaded).
Could somebody tell me where this option lives on the menu tree?
Thanking in advance,
Paul
#2 rigel123
rigel123
  • Loc: SW Ohio
Posted 23 August 2012 - 08:47 PM
If I remember correctly go to Menu>Setup>Handset Setting>Polar LED and then you use the up and down arrows (direction arrows) to dim or brighten the LED. I typically set up at dusk and don't use it anymore.
#3 Red Dwarf
Red Dwarf
  • Loc: Issaquah, WA
Posted 23 August 2012 - 09:00 PM
OK. Thank you!
