Yet Another Synscan Beta Code Release
23 replies to this topic
#1 Skylook123
Skylook123
  • Loc: Tucson, AZ
Posted 07 September 2012 - 11:57 PM
A new beta release has popped up on the Skywatcher site. There are no release notes, just the commentary "Notes: This is not SynScan EQ official firmware release, but for beta-site test only.
A new feature of Polar Re-alignment is added and improved accuracy under Alignment sub-menu of the hand control in the firmware. User may use this feature to do the polar alignment without aligning Polaris in the polarscope for an EQ mount.
This new firmware also works with AZ goto and DOB SynScan goto mount."
Skywatcher EQ Firmware Updates
#2 RandallK
RandallK
  • Loc: Nanaimo, B. C. Canada
Posted 09 September 2012 - 01:38 PM
There was an earlier thread on this posted a few weeks ago for the Sirus mount which is the same as the SkyWatcher. It's essentially a drift alignment procdure with "hand controller assist". It really does cut down on the drift. PHD guiding doesn't have to work as hard.
#3 rmollise
Posted 09 September 2012 - 01:54 PM
It's not really a drift alignment, what it is is the AllStar polar alignment system from the company's Celestron mounts ported to their SynScan mounts...
#4 RandallK
RandallK
Posted 09 September 2012 - 02:58 PM
Thanks for the correction Rod.
I have now downloaded 03.30 beta 29 and tested it with no issues.
I still do a Polar alignment via the original instructions in my Skywatcher manual and it has given me very good accuracy in imaging. Of course the polar scope reticle has to be aligned correctly as well for this to work properly. (When my mount was shipped from the distributor, the reticle was NOT set correctly.) Now with the hand controller update, I further adjust on a selected star (after the "regular" Polar alignment), to tweak both T-Bolts to center. I think this helps PHD guiding in that it doesn't have to do as much correction. What do you think?
#5 rmollise
Posted 09 September 2012 - 02:59 PM
BTW, I just downloaded and installed it yesterday. Planned on giving it a try last night. The clouds thought otherwise. :lol:
#6 Raginar
Raginar
  • Loc: Rapid CIty, SD
Posted 10 September 2012 - 12:47 AM
They just removed my last reason why I didn't get an Atlas... :)
#7 astroRoy
astroRoy
  • Loc: Southern Oregon
Posted 10 September 2012 - 05:13 PM
They finally got their site back up so I downloaded it. I'll try it out tonight. The last one wasn't as good as I had hoped. maybe this one IS more accurate as they report it to be.
Roy
#8 rmollise
Posted 10 September 2012 - 05:22 PM
Hmm...the reports on it I had were "pretty accurate." The people getting good results did a 3-star, the polar routine, another 3-star and the polar routine again.
#9 astroRoy
astroRoy
Posted 16 September 2012 - 09:50 AM
Finally got my Atlas working well enough to use (details on different thread) and tested the new beta 3.30/29. I did the "Re-align" twice - once after each 3-star align as mentioned above, and I am quite pleased with the results. Definately better than the previous version. Faster by far than drift-aligning, PHD aligning, or any of the others methods I have tried. Accuracy seems very good, but I have not tried to verifiy it with tests other than seeing improved guiding results, and lack of drift in my PEC curves. The upgrade is easy, and free, and the results seem to bear out that it is worth the effort. Thanks Synta, and thanks to all posters involved.
Roy
#10 Tom_H
Tom_H
  • Loc: Russellville, Ar.
Posted 17 September 2012 - 07:09 PM
Hi Guys
Quick question about the upgrade. Did you use the Orion loader or the Synscan loader. I noticed there is a slight difference in the file size, and was wondering whats being used.
Regards
Crow Mtn Observatory (ROR) - Russellville, Ar.
Orion 8" Astrograph on Sirius Mount
EQASCOM control for the mount
Orion SSAG Mini guider
PHD Guiding Software
Meade DS II with Peltier cooling
SkyTools 3 PRO
Nebulosity 3
Celestron NexStar 6SE
#11 ad701xx
ad701xx
  • Loc: Oregon, USA
Posted 17 September 2012 - 10:26 PM
I did the update a couple of days ago using the Synscan v3.00 loader. No issues there.
#12 astroRoy
astroRoy
Posted 18 September 2012 - 12:14 AM
+1 Synscan.
roy
#13 MikeCMP
MikeCMP
  • Loc: Chardon OH
Posted 18 September 2012 - 04:37 PM
Just released version 3.30 beta
#14 evhap
evhap
  • Loc: California
Posted 06 October 2012 - 01:29 PM
I've been a little reluctant to install the betas, since there is no documentation. Is the use of the new features pretty self-evident?
Evan
#15 MikeCMP
MikeCMP
  • Loc: Chardon OH
Posted 06 October 2012 - 02:43 PM
New features have documentation in the bandbox telling you what to do, so it's pretty straightforward.
#16 RogerRZ
RogerRZ
    Whatta you lookin' at?
  • Loc: West Collette, NB, Canada
Posted 06 October 2012 - 05:13 PM
I installed it on my EQ6, and the mount was already pretty close. I did a 3 star alignment, and then the polar alignment routine. The HC wanted me to move by two degrees in alt, and over four in az. Knowing this to be out of whack, I cancelled out of the routine. I did another 3 star alignment, did the PA routine on the same star, and this time, I was asked to move the mount less than a degree in both axis.
I did this for the next half hour, only to have to start over with the pa scope.
I am no longer using this feature...
#17 rmollise
Posted 07 October 2012 - 08:55 AM
The beta is a beta. It still has a buggie or two lurking, but mostly seems to work OK:
http://uncle-rods.bl...i-nights-1.html
#18 evhap
evhap
  • Loc: California
Posted 07 October 2012 - 10:58 PM
Mike, please excuse my ignorance, but could you explain what you mean by "documentation in the bandbox?" I find a gaggle of new functions and not a scrap of documentation anywhere.
Evan
#19 neptun2
neptun2
  • Loc: Bulgaria
Posted 18 October 2012 - 10:04 PM
I have tested both 3.28 beta 21 and 3.30 beta 29. Version 3.28 works ok and i really like the new polar realign feature. I have problem with 3.30 though. I do not see the option to change autoguiding speed in the new firmware. I really need that feature so i got back to 3.28. What are your observations? Do you see the same option missing from your hand controller after the upgrade?
Edit: One more thing - with the new beta 3.30 i could not make PHD to calibrate and start guiding. The star just does not move enough. I am definitely back to 3.28 till we get new beta with these bugs fixed.
#20 evhap
evhap
  • Loc: California
Posted 26 October 2012 - 09:13 PM
There's a newer beta out: SynScanV0332AZEQB05. This is supposed to be the last beta before the production version.
Evan
#21 neptun2
neptun2
  • Loc: Bulgaria
Posted 28 October 2012 - 03:15 PM
I flashed the new beta. Everything went fine. I see that the option to select the auto guide speed is back which is very important for me. It's miss was very annoying bug in 3.30 beta firmware. At first opportunity i will test the new beta under the stars and will report.
Meanwhile for those of you that want to test the new polar re-align feature here is what i do to make it work as expected:
1. Make rough polar alignment using the polar scope. I personally put polaris in the center of the polar scope and this way guarantee that it is no more than 1 degree off in azimuth and altitude.
2. Make 3-star alignment. Center the stars as accurate as possible during it. I personally attach my DSLR and use the live view with enabled grid to ensure that the star is centered properly.
3. After the 3-star alignment is completed start the polar re-alignment. when asked for a star to be used select star from the list which is not near any one of the 3 used for the previous alignment. Follow the procedure and center the star as accurate as possible. When the procedure is completed look through the polar scope to ensure that the polar star is where it is expected to be. You can use program like "polar finder" to see where polaris should be regarding the center of the polar scope at this time.
4. After the polar re-align is completed park the mount, turn off the power, turn it on again, select not to start from park position and make another 3-star alignment. After this you can start taking pictures.
These observations are based on the tests that i made on 3.28 and 3.30 beta versions. When i have observations about the new beta 3.32 i will report.
#22 neptun2
neptun2
  • Loc: Bulgaria
Posted 10 November 2012 - 01:16 PM
I finally had 2 days with good weather to test the new beta firmware 3.32 beta 5 and it is working really well. The polar realign algorithm seems to be working better. It was enough to just put polaris in the field of view of the polar scope, make 3 star alignment and then the polar realign and everything was ok. There was no need to make another 3 star alignment after the polar realign and the goto accuracy was very good. I also checked the polaris position through the polar scope after the polar realign and it was just where i expected to be. I recommend the new beta firmware to everybody.
#23 John Carruthers
John Carruthers
    Skiprat
  • Loc: Kent, UK
Posted 11 November 2012 - 03:53 AM
+1 for the 332b release. I had to slow the loader down to 'Lo' transfer rate for the first time ever with loader v3, but all seems well.
#24 kaj_mustikkamaki
kaj_mustikkamaki
  • Loc: Finland
Posted 12 December 2012 - 11:40 AM
It's not beta anymore. 3.32 release can be downloaded on Sky-watcher's web-site. Just upgraded my HC without problems and seems to work OK.
- Kaj -
