Celestron Los D dovetail compatibility question
10 replies to this topic
#1 ourobouros2k2
ourobouros2k2
  • Loc: okc area, oklahoma
Posted 08 September 2012 - 02:36 PM
Hello all, I have been wanting to get together the SSAG package from orion, but no matter how I try to save I just can't surpass life expenses, so I am trying to put it together piece by piece every paycheck.
I was wanting to purchase the celestron losmandy d type bar to mount the guidescope on.
http://www.astronomi...ount_p7022.aspx
It is reasonable and I like the orange color. I have heard there might be some compatibility issues and was wondering if anyone can vouch if it will fit on the ota in the following position:
The product page says it will fit a standard c8, and since the rear cells seem to be identical on the newer models I was just wondering if anyone has tried this before I buy it. Going to use astrotech los d adapters for the rings.
thanks in advance,
#2 Midnight Dan
Midnight Dan
  • Loc: Hilton, NY, Yellow Zone (Bortle 4.5)
Posted 09 September 2012 - 08:21 AM
Hi Andrew:
The Losmandy size dovetail rail is a large rail designed for attaching heavy scopes to a mount. It's way too large for an autoguider and I don't think it would fit those mounting holes anyway.
You don't mention which SSAG package you are interested in. The magnificent mini autoguider package fits into a finder shoe so that's all you'd have to buy if that's what you have.
The awesome autoguider package includes a ShortTube 80 telescope which needs a more substantial mount. But it comes with a "guidescope mounting bar" which you may be able to use.
I guess we need more details on exactly what you're going to be mounting on the scope.
-Dan
#3 ourobouros2k2
ourobouros2k2
Posted 09 September 2012 - 01:19 PM
I had planned on using the ST-80, but am not a fan of how far the rail provided in the package overhangs on the 8SE tube. Just trying to find a single rail solution that won't require spaces, radius blocks, etc..
thanks,
#4 Midnight Dan
Midnight Dan
Posted 11 September 2012 - 06:47 AM
Hi Andrew:
Not sure what you mean by the rail overhanging the 8SE tube. Is it longer than the 8SE? I can't find a spec on their site that says how long it is. In any case, most of the time when mounting a setup like this, there will be some drilling or cutting involved. If it's too long, simply cut the end off with a hacksaw, file it smooth, and paint it black.
You can get a guidescope mounting kit from ADM that will perfectly fit the scope, but you'll pay big bucks for it:
http://www.admaccess...descope_kit.htm
-Dan
#5 ourobouros2k2
ourobouros2k2
Posted 11 September 2012 - 10:39 AM
yeah, the stock dovetail in the ASSAG package overhangs the 8SE OTA by several inches it looks like, judging from some of the photos in other threads in this forum. I may end up just getting some radius blocks from ADM and be done with it. I noticed the awesome autoguider package is on sale right now at 350.
#6 hopskipson
hopskipson
  • Loc: Queens, New Yawk, Light pollution Headquarters!
Posted 12 September 2012 - 09:16 PM
Andrew
I hope you noticed they have the 80 mm refractor package for the same price as the finder package.
James
#7 ourobouros2k2
ourobouros2k2
Posted 12 September 2012 - 10:08 PM
I did notice :)
#8 ourobouros2k2
ourobouros2k2
Posted 16 September 2012 - 03:06 PM
Well, the SSAG is on the way, and wanting to prep my scope for it's arrival, I went ahead and got the celestron bar. I also picked up 2 astrotech los-D adaptors (astronomics is about a 30 minute drive). I put it all together and I am very, very pleased at the finish of the result. I know it is a bit of overkill, but hopefully will eliminate *some* flexure. Downside? 2.3 pounds.
#9 Charles_Galdies
Charles_Galdies
Posted 30 November 2012 - 05:50 AM
Hi, thanks for posting the pic of your setup.
I would like to know if you had to remove the original vixen plate to accommodate the new dovetail, or if you to drill new holes in the 8SE OTA.
Charles
#10 Midnight Dan
Midnight Dan
Posted 30 November 2012 - 07:13 AM
Yikes! You could mount a Volkswagen on that thing! :grin: Yeah, I'd say you've eliminated flex.
-Dan
#11 ourobouros2k2
ourobouros2k2
Posted 30 November 2012 - 09:24 PM
Works pretty well, but makes balancing a chore on the Sirius EQ-G. At max load for ap, prompting me to save for the atlas.
In answer to your question Charles, I did not have to remove the vixen bar, this is a direct bolt-on for the rail holes on the opposite side of the vixen bar. No drilling or modification needed.
thanks,
