Processing Software - StarTools
157 replies to this topic
#101 mcbbcn
mcbbcn
  • Loc: Portland, OR
Posted 21 November 2012 - 03:26 PM
Hi Mike,
I like the color of the stars a d the background but unfortunately, the color mapping is wrong. I've asked Ivo to post his workflow, so hopefully, we will learn more from his processing approach.
Thanks for giving it a try!
M.
#102 mcbbcn
mcbbcn
  • Loc: Portland, OR
Posted 21 November 2012 - 06:19 PM
Hi Tim,
I agree with you. As I shared in my previous post, I'm giving Ivo and StarTools rave reviews, you saw me bowing. ;)
I'm very curious about how much you can push the image now. Have you given my nebulae a try? I would love to see what you can do too.
I know Ivo is very busy, but he said that he was going to share his workflow with us, and I can't wait.
I'm also curious to see if his deconvolution approach could sharpen the low SNR faint nebulae. I have the feeling that it can,...given what I saw in the video for processing the galaxy. I remember a step in the video where he was able to pull individual stars from a smudge of gradients...I was certainly quite impressed with that step.
I look forward to hear more about it.
Thank you so much for creating this post. It's been quite a nice discovery for me, and I don't exclude the possibility that I may end up using a combination of programs, as I always do to get the results I want.
Best regards,
Miquel
#103 Mike7Mak
Mike7Mak
  • Loc: New York
Posted 21 November 2012 - 07:52 PM
...unfortunately, the color mapping is wrong.
Heh, wrong eh? :) To be honest I think I've only seen one or two 'red/blue' veil images that I thought looked good. It's a pretty difficult target to get 'right'.
The problem I'm having is most of the nebula signal is in the Ha frame. The signal is barely above the noise floor in the RGB frames. I gave it one more shot. This time with some fairly extreme stretching and other tweaks on the individual frames before combining them.
Can't say I like it any better than the first one I did.
#104 mcbbcn
mcbbcn
  • Loc: Portland, OR
Posted 21 November 2012 - 08:53 PM
Hi Mike,
When I said 'wrong', I may have been a bit harsh. Let's say, it's not what I was expecting, but in the realm of colors, it's like flavors, everybody is right.
It seems that on your next tried, the color mapping is more in tune with red for Ha, and blue for oxygen...It's a bit too saturated but it sounds like you're going down the right path.
It's a very tricky nebula to process, and it took several trial & errors on my side to get it right, so I'm not surprise is challenging on your side.
...that is why, I was also quite surprise with Ivo's result. He said that he used most of the default settings, so that blew my mind away. I'm sure he has an edge given that he is written Startools, and probably he knows better than anybody else how makes this tool tick in the best possible way.
Thanks again for giving my nebula a try, and seriously, if you saw some of my early processing on this object, you'll feel pretty good about the results you're getting.
Clear skies!
M.
#105 Ivo Jager
Ivo Jager
    Vendor ( Star Tools )
  • Loc: Melbourne, Australia
Posted 21 November 2012 - 10:42 PM
Hi All,
The trick is to process luminance separate from the colour data.
To help you on your way, here is a quick description on how I processed the luminance part of the image. I'll post the remainder of the steps later when I can find some more time.
First I created a new synthetic luminance master by creating a weighted average of all the signal that we collected across the different bands (Ha 110m, R:30m, G:30m, B:30m). By doing this, we create a new master that makes optimal use of the photons captured to bring out detail and reduce noise.
Unfortunately the way to do this is currently not very elegant in StarTools (or anywhere else as far as I know). This will change in 1.4 with a revamp of the LRGB module.
Load R, indicate that data is NOT linear ("This image has already been stretched") even though it clearly is.
Then, in the Layer module, open G, set blend to 50%, Copy, Paste->Bg, open B, set blend to 33%, Copy, Paste->Bg, open Ha, set blend to 55%.
What we're doing here is progressively creating a luminance master; first we have a 50/50 mix of R and G, then we have a 66/33 mix of (R+G) and B (so we effectively end up with 33% R, 33% G and 33% B) and finally we have a mix of 45/55 of (R+G+B) and (Ha). Why use 45% of the RGB luminance and mix it with 55% of Ha? That's because the R+G+B signal constitutes 90 minutes of exposure time and the Ha constitutes 110m exposure time. So of the 200 minutes of total exposure time for this object, 90 minutes was allocated to R+G+B (90/200=0.45) and 110 minutes was allocated to Ha (110/200=0.55).
Now that we have our new synthetic luminance signal, we can start processing it for maximum detail. We will introduce colour at a later stage.
First thing I do is let StarTools know that what we have now is 'trackable' linear data. With that knowledge it will be able to give us enhanced results. To let StarTools know, I click the Track button.
So let's see what we got! I launch the Autodev module which automatically does a global stretch, allocating dynamic range in the best possible way for the detail in your image. As long as 'tracking' is on, global stretches in StarTools are non-permanent and you can redo them whenever you like - even if you have already done other stuff to your image such as local stretching, sharpening, deconvolution, etc.
We can immediately see two things; the image needs cropping (due to stacking artefacts) and there is a faint gradient present. I 'Keep' the stretched image and launch the Crop module. I settle for some values that centre the nebula and get rid of the artefacts. I also make sure I keep track of the values as I need them later on to crop the color data in the exact same way (you can write them down, or you could just look the up in the StarTools.log processing log file).
Parameter [X1] set to [52 pixels]
Parameter [Y1] set to [173 pixels]
Parameter [X2] set to [3027 pixels (-321)]
Parameter [Y2] set to [2168 pixels (-328)]
Next, I get rid of the gradient, by using the Wipe module.
I use the default values and I bump up the dark anomaly setting a little, just in case the are some dead pixels (though I didn't see any).
Parameter [Dark Anomaly Filter] set to [2 pixels]
I do as the Wipe module suggested when I launched it and re-do the global stretch. I use the Autodev module for that (though if you wanted to, you could use the Develop module as well). Things look good. The gradient and artefacts are gone.
AutoDev's job is to find the histogram curve that gives the best possible trade-off between detail and brightness (i.e. 'dynamic range allocation'). It's exactly what you would be doing playing with curves and checking histograms in traditional software packages, only Autodev is infinitely faster and better at it than you are. :)
Our image has some fine background noise, which AutoDev actually tries to bring out, assuming it is real detail. To tell Autodev not to bother with the fine noise, we can actually tell it to ignore details that are finer than a specific amount of pixels. I select a value of 1.5.
Parameter [Ignore Detail <] set to [1.5 pixels]
We can immediately see the noise becomes less visible, as Autodev no longer allocates dynamic range for it.
I'm happy with this result, so I click 'Keep'.
Next I launch the Deconvolution module, to see if it thinks our signal is good enough to make any enhancements. I define a preview area and play a bit with the 'Radius' parameter. I don't bother with a star mask just yet, though it's pretty obvious I'm going to need one. After a bit of playing around, I settle for a radius of 2.0 pixels and can't see any improvement beyond 10 iterations. You'll notice that deconvolution in StarTools is not only blazingly fast, it simply refuses to introduce noise and seems to magically 'know' which detail it can enhance and where to back off because it would only introduce noise and artefacts. To make a long story short - you don't need to create detail protection masks or elaborate luminance masks for the Decon module to do its job properly and effectively.
What we do need however is a star mask. Fortunately, that's not hard to do either. I click Mask, Auto, the 'Stars' preset and the 'Do'. Out comes a mask.
I click 'Shrink', 'Grow' and 'Grow' to make sure that small detail noise is not accidentally selected and that stars are well covered by green mask pixels. I'm happy so I click 'Keep'.
Oops! StarTools has picked up a mistake I made - we need an *inverse* star mask (e.g. something that has 'gaps' where the stars are so that they *don't* get treated by the decon module). I launch Mask again, and correct my mistake by clicking 'Inverse', after which I 'Keep' the result and am returned to the Decon module.
It's a huge improvement - the ringing artefacts are gone. I can see, however, some spurious other pixels around some stars that don't seem to belong there.
They are caused by the de-ringing algorithm which, unlike those in other deconvolution algorithms, still makes an attempt to coalesce singularities and sharpen up stars with an alternative algorithm. It's a typical case of 'Your Mileage May Vary'. You can use the Mask Fuzz parameter (which makes the mask we created appear 'fuzzy'/'blurry' to StarTools algorithms) to control how much of the non-deconvolved image is blended in. I our case, I settle for 3 pixels, as opposed to the default 8 pixels.
Next I click 'All' to apply the deconvolution settings to the whole image and not just the preview I define earlier.
I'm happy with this, so I click Keep.
Next, I'm going to use some local dynamic range optimisation to bring out the nebula further by launching the HDR module.
I just use the default settings which performs an equalisation of local dynamic range, effective taming too bright regions (of which we have little) and enhancing detail in dark regions (of which we have lots). The only parameter I change is the 'Most Affected Detail Size' (to 178 pixels). This parameter specifies the rough size of 'things' in your image that should be affected most by the enhancement. It helps HDR find the right areas in your image that require enhancement and ensures the enhancements look natural. Don't be too concerned about noise being exacerbated - StarTools 'tracking' feature is keeping track of it in the background and will deal with it later. I'm happy and, once again, 'Keep' the result.
We still have that mask active we made earlier for the Decon module. We might as well put it to good use. This time I'm going to do some Wavelet sharpening with it, making sure that stars are not affected as much. I launch the 'Sharp' module and click 'Next'.
I modify the mask slightly by clicking 'Shrink' twice, so that pixels that are in the neighbourhood of stars aren't affected as much by the sharpening. I set Mask Fuzz to 4 pixels so non-sharpened and sharpened areas transition smoothly. I also 'overdrive' the sharpening a little by setting Amount to 150%. Finally I set 'Small Detail Bias' to 90%. This important and unique feature acts as an arbiter when different scales try to enhance the same pixel. In such a case, 'Small Detail Bias' looks at what both proposed modifications bring to the table and decides who gets priority based on how it will affect the image. Increasing 'small detail bias' gives a progressively bigger weight to decisions in favor of small detail enhancement. It is an important feature that makes wavelet sharpening much more useful and controllable, as opposed to other implementations.
Also notice that StarTools wavelet sharpening implementation (as is the case with nearly every other module in StarTools) never clips your data, no matter how crazy the parameters you choose.
The Added detail definitely makes a difference. I'm happy with that and I 'Keep' the result.
I'm a big fan of one particular module in StarTools, which is called the 'Life' module.
It was written as a way to manipulate super structures (such as whole nebulae and galaxies) and give the user control over their presentation. Especially in wide® field images, busy starfields can be terribly distracting from the object that is really the centrepiece of your image. Such objects seem 'buried' under stars. The Life module can push back the star fields and bring out the nebula, drawing the eye to what your image is really about.
Other uses for the Life module are the complete reconstruction and re-synthesis of super structures that were lost due to heavy-handed HDR processing (the infamous 'flat' PixInsight look) or lost and irrecoverable from background noise.
The choice is yours a this point to apply it or not.
Either way, we'll need a mask that is fully set instead of the partially set mask that we have now (Mask, Clear, Invert, Keep).
For this image, I chose to use it to push back the star field and 'Isolate' the nebula. For this I used the Isolate preset with default values, but used a strength of 50% to make the effect a little more subtle.
I perform one last step before final noise reduction and that is the 'Contrast' module. It helps even out contrast across large parts of the image. It's a cousin of the Wipe module, but created especially for psychovisual medium-to-large scale dynamic range optimisation. I use the default values with 'Dark Anomaly Headroom' at 100%, Dark Anomaly Filter at 2 pixels.
Now it's time to switch off tracking and let StarTools perform its unique, extremely targeted noise reduction. During the setup phase, I just use the default values and click 'Next'.
Straight away, StarTools does a great job of getting rid of all the background noise.
Really, it's up to taste on how you would like to trade-off the rest of the noise in the image against the retention of detail. I finally settled on;
Parameter [Scale 1] set to [100 %]
Parameter [Scale 2] set to [100 %]
Parameter [Scale 3] set to [85 %]
Parameter [Scale 4] set to [50 %]
Parameter [Scale 5] set to [50 %]
Parameter [Color Detail Loss] set to [50 %] (irrelevant as this is not a colour image)
Parameter [Brightness Detail Loss] set to [35 %]
Parameter [Structural Emphasis] set to [3 pixels]
Parameter [Edge Repair Strength] set to [10 %]
Parameter [Noise Tracking Influence] set to [150 %] (overdrive StarTools' decision to noise-reduce pixels, based on noise propagation levels it observed throughout our processing)
And that's our luminance frame!
To be continued...
#106 mcbbcn
mcbbcn
  • Loc: Portland, OR
Posted 21 November 2012 - 11:00 PM
Ivo,
That was just amazing. You're an artist & by sharing this approach, I'm sure we (amateurs) can take processing to the next level with StarTools...& just because you took the time to do all of that sharing, I'm going to get my license of StarTools & seriously, I can't wait for version 1.4 now... :jump:
Thank you for doing that. I just became a fan of your creation too.
See you on the processing path my friend! ;)
M.
#107 Ivo Jager
Ivo Jager
Posted 22 November 2012 - 12:20 AM
Thank you for your kind words and support Miquel. I believe we are all artists here on this forum - the crux is having the ability to express and articulate our creativity.
The best astrophotographers that I know are good because they give a unique personality to their images (Ken Crawford and Marc Aragnou on Photoshop), frame things in interesting and new ways (Rogelio Bernal on PixInsight), or just throw conventions out of the window to find something new (Mike Sidonio on AstroArt, Fred Vanderhaven on Photoshop).
What all these guys have in common is that they are creatives first, computer operators second.
It's a pity when creativity is held back, or enthusiasm for our wonderful hobby is tempered, just because the means to express that creativity poses a challenge in itself.
Software like StarTools is, unfortunately, a necessary evil. My contribution is trying to make things as painless as possible for those who hate processing, while making things more enjoyable for those who love teasing out that last bit of signal that they know is there, because behemoths like the HST have shown us.
The learning never stops and it doesn't matter when you jump on the train; the field is moving so fast that, as far as I am concerned, we are all perpetually 'amateurs', myself included. :p
#108 mcbbcn
mcbbcn
  • Loc: Portland, OR
Posted 22 November 2012 - 12:47 AM
Well said! :)
#109 Renae Gage
Renae Gage
Posted 22 November 2012 - 03:38 AM
I'll be a StarTools customer when it supports 64 bit Mac. Tried the 32 bit version and it wasn't worth it, frankly.
#110 TimN
TimN
  • Loc: Ontario, Canada
Posted 22 November 2012 - 09:23 AM
Ivo - Very well said.
Eric - Ivo recently made some changes that seem to have improved the MAC 32 bit. Have u tried it lately?
Mcbbcn - I image at my cottage in Northern Ontario where I keep my desktop that I use for processing. I'm currently in the city - Toronto area - where I only have a tablet and an old old laptop so I couldn't try your image. However, it seems you got the information that you needed. Gald it worked out.
#111 lawrie
lawrie
  • Loc: Okanagan Valley
Posted 22 November 2012 - 11:47 AM
I downloaded the program to give it a try, But I can seem to load an image. The program is trying but nothing is happening ????? Just spinnung it's wheels.
The comp has an i7 with 8gb of ram, so it isn't the laptop.
#112 Renae Gage
Renae Gage
Posted 22 November 2012 - 01:25 PM
Yup.
#113 mcbbcn
mcbbcn
  • Loc: Portland, OR
Posted 22 November 2012 - 01:56 PM
I just installed StarTools 1.3 beta in my i7 6Gb of RAM, 64 bit, Windows Ultimate and I was able to open a .fit file image just fine.
I would suggest that if you have problems, you may want to specify your OS version, the version of StarTools that you downloaded and the type of image that you are trying to open. Also, I noticed StarTools provides a support contact form in their website, so that could help speed up the resolution of your issue. If it gets resolved, please share the resolution in this post, so we can all learn.
Thank you,
M.
#114 lawrie
lawrie
Posted 22 November 2012 - 02:10 PM
I don't think it can open a .tif file.
#115 Ivo Jager
Ivo Jager
Posted 22 November 2012 - 06:42 PM
Hi Eric and Lawrie,
Thanks for chiming in.
As Miquel suggested, could you could tell me the version of StarTools and OS version?
An example of a troublesome image would be greatly beneficial.
A very patient RangerTim has been helping me beta test on MacOSX (Lion) and things should be stable as of 1.3.180. To make sure it is still stable, I tested the latest as of this writing (1.3.186) on a Mac Mini, running OSX Lion, with i7 and 8Gb (which ran StarTools insanely fast I might add!).
For example, the data that Miquel has been so kind to share with us should process just fine on MacOSX and if you see otherwise please let me know.
StarTools should read uncompressed, IBM PC byte order, 8, 16 or 32-bit TIFF files. It should throw an error (and not hang) if anything is amiss. Again, if you see otherwise please let me know.
#116 mcbbcn
mcbbcn
  • Loc: Portland, OR
Posted 23 November 2012 - 12:06 AM
Well, I just had my first go at StarTools, and I can't tell you how much fun it was.
Now, I get what Ivo says about allowing you to focus more on the overall composition.
The following it's an HaRGB image. I did 70% of the processing in StarTools, then Pixinsight for Calibration and a few image tweaks, and then PS.
It's a fairly show exposure from a high light polluted location, still, I'm quite satisfied with the result.
R - 15min
G - 15min
B - 15min
Ha - 45min
Enjoy it!
M.
#117 lawrie
lawrie
Posted 23 November 2012 - 12:34 AM
Hi Ivo.
I tried v1.3.186 of startools on an i7 quad,8gb ram, 64 bit machine. It opened a fit file just fine but not a tiff file.
Also I was reading your post from earlier, and was going to try it but the layers module (along with those around it were greyed out.
#118 Ivo Jager
Ivo Jager
Posted 23 November 2012 - 01:50 AM
Part 2; adding colour to our image.
This is fortunately a little bit easier. If you haven't done so, save the new luminance master first.
Next, launch the LRGB module which we'll use to create an RGB composite (though without luminance!).
Click 'Red', 'Green' and 'Blue' to load the respective channel data until you end up with a (linear) color image.
Noet that I do not include Ha in the red channel - for a 'natural' color, I refrain from Ha touching the color balance. Remember though that it has, however, had a huge influence on the luminance, so any Ha detail will definitely be visible.
I keep everything at the default settings and hit 'Keep'. Normally, you would input the filter ratios here (color filter don't all have the same permeability), but since we don't knwo them for this data we'll make corrections by eye later.
First I'm going to crop the image to exactly the same area as we did for the luminance.
In this case;
Next I hit Auto Develop to see what we have. I'm greeted with some sort of green bias signal. Fortunately this should be no match for Wipe - I cancel and run Wipe with the default settings.
I run Autodev again and things look a lot better - I can see our nebula, but I can also spot some faint discolorations - some red, some green, some blue. These are the hall marks of so called 'dark anomalies' - pixels that have an anomalous dark value due to severe noise or CCD defects. The discolorations are caused by Wipe backing off upon seeing the dark anomalies and mistaking them for real background value pixels, whereas really they are much darker than the real background.
I hit cancel to exit AutoDev, click 'Undo' to undo Wipe and launch Wipe again. This time, I'm going to increase the Dark Anomaly Filter setting. This will filter out any (smallish) dark anomalies before presenting the data to Wipe for evaluation. I try 7 pixels and keep the default settings for the rest of the image.
I run AutoDev again to evaluate the results. That's better! I set Ignore Detail to 3 pixels to avoid AutoDev allocating dynamic range to noise.
Notice also that Wipe helped us here getting close to an ideal color balance. It does that by assuming that the background is neutral.
Next I save the image to its own TIFF file.
It is now time to combine Luminance and (prepped) RGB - once more I launch the LRGB module and load the luminance file for 'Luminance' and load the RGB file we just created 3 times for R, G and B.
Our nebula is now colored, but color noise was introduced. To reduce the color noise, I up RGB blur a little (1.8) - a trick that depends on the fact that the human eye is much less sensitive to color blurring than it is to luminance blurring.
Now it's time to get the color balance right. For that I launch the Color module. To start off with, I bump up the saturation by 300%. You don't have to go with a high saturation if you don't want, but it does help gauging color balance while modifying your color in the color module.
The colour balance I first do by eye - we know that the star color should vary between red, via range and yellow to blue and that their distribution is roughly equal. Therefore, I try to find values for Red, Green and Blue ratio that give me that sort of look. I think the values of R 1.0, G 1.1 and B 1.1 give me a good color balance. However, as I was processing on a non-color calibrated laptop I cannot be sure that what I am seeing is going to be what other people will be seeing. Luckily there is a tool in StarTools that provides a sanity check for those without a color calibrated screen. By Clicking the 'Max RGB' button in the top right, the view changes to show which channels are dominant. If your image is too red, pixels that are supposed to be 'neutral' (such as the background) will show mostly red. If your image is too green they will show mostly green. If, however, your image is well calibrated, these neutral pixels will alter between red, green and blue. I find that I pushed the green too much and could use a little more blue, so I back off the green to 1.03 and up the blue to 1.12.
Lastly, I set Cap Green to 'To Yellow'. We're making use here of a the fact that very little objects in space are predominatly green when imaged in RGB. If we do encounter a predominantly green pixel and we are absolutely certain we got the color balance right, then we can assume that this pixel predominantly green because of noise in our measurement. Therefore we can cap the predominantly green pixel to the max value of red or blue, so that it no longer is predominantly green. Finally, I click 'Keep'.
As a double sanity check, I let Wipe be the final arbiter of my color calibration. I keep the default settings but set Dark Anomaly Filter to 7 (as we found out before). I also set 'Cap Green' to Yellow once more for good measure. I see Wipe make barely any difference (except for some final gradient removal), so I was close!
Now I'm going to sharpen the nebula one last time.
In order not to sharpen the stars any further, I'm going to make a star mask. I set 'Exclude Color' to 'Purple (Red + Blue)' and 'Filter Sensitivity' to a less sensitive 10.
When done I click 'Shrink' and 'Grow' 4x until stars are well selected. Finally I click 'Invert'.
In the Sharpen module I set Mask Fuzz to 6 pixels, small detail bias to 96% and set scale 1 to 0 in order not to sharpen any fine noise. Finally, I let it sharpen both Luminance (brightness) *and* Color by setting Channels to 'Brightness & Color'. I 'Keep' the result.
As a final step, I run the Isolate preset in the Life module to push back the stars and 'isolate' the nebula. I will not only enhance the nebula, but also its apparent color as I increase the saturation (125%) of the super structure.
Season to taste!
The final result is not exactly like the processed version I sent Miquel, but it's close and easier to reproduce.
#119 Ivo Jager
Ivo Jager
Posted 23 November 2012 - 01:53 AM
Hi Ivo.
Some modules are greyed out when Tracking is active (as they interfere with StarTools' ability to make sense of the information it can derive from your data).
So, when you load the data with the intent of creating a new synthetic luminance master, do as outlined in the tutorial above; "indicate that data is NOT linear ("This image has already been stretched") even though it clearly is."
Hope this helps!
#120 mcbbcn
mcbbcn
  • Loc: Portland, OR
Posted 23 November 2012 - 03:06 AM
Ivo,
Thanks for sharing the rest of the processing. I'll re-process the Heart nebula with the new steps. Thank you so much!
M.
#121 mcbbcn
mcbbcn
  • Loc: Portland, OR
Posted 23 November 2012 - 03:55 AM
Hi Lawrie,
I thought I would lend you a hand.
I have a very similar system than yours. If you upload the .tif file that you're having challenges with to box.net or dropbox, I'll be happy to download it into my system and see if I can open it. At least that will help us narrow down the issue.
Thank you,
M.
#122 mcbbcn
mcbbcn
  • Loc: Portland, OR
Posted 23 November 2012 - 11:00 PM
I went ahead and reprocess the Heart Nebula using Ivo's method for luminance and color, and this is the end result. I find his approach balances colors better & gets more contrast.
M.
#123 mcbbcn
mcbbcn
  • Loc: Portland, OR
Posted 26 November 2012 - 11:39 PM
Hi Friends,
I wanted to share my Heart nebula processed by Ivo using StarTools. I was blown away. Keep in mind that this is a 45min. Ha exposure with 15min. for each color (RGB) taken from a Bortle 8 sky like Portland Downtown which is where observatory is located. Pretty amazing!!!
If you want to see the full image, you can get it @ http://astrogab.ning...to/heart-nebula
M.
#124 CounterWeight
CounterWeight
  • Loc: OR CA
Posted 27 November 2012 - 04:45 AM
Wow, that really pulled out the data, very impressive result - especially from our city! (I have renamed it Cloudyopolis, am in SE part of city 'close in') Congrat's :waytogo:
#125 NeilMac
NeilMac
  • Loc: MedHat, AB, Canada
Posted 27 November 2012 - 11:44 AM
Nice colours !!
