Universal Astronomics Unistar - Tripod ideas?
15 replies to this topic
#1 seattlepete
seattlepete
  • Loc: Uh...seattle.
Posted 12 September 2012 - 10:47 AM
I have a Unistar Deluxe. I've had two others in the past that I used with an Atlas tripod. I got rid of the Atlas tripod and am now looking for ideas on a new tripod.
Weight is not an issue...I want a rock solid foundation. No Meade Field Tripods though.
If anyone has a good solid tripod idea, I would appreciate it. I will be using my 120ED and eventually a C9.25.
#2 spencerj
spencerj
  • Loc: Londonderry, NH
Posted 12 September 2012 - 03:07 PM
A wooden surveying tripod works well. I got mine from Universal Astronomics years ago, but there are plenty of suppliers. They are heavy/solid enough and wood is a good material for dampening vibration. I have always been happy with mine even with my 20+ lbs MN66 mounted on my Unistar.
#3 Adam Taylor
Adam Taylor
  • Loc: Arizona
Posted 12 September 2012 - 04:49 PM
Pete, do tell. I thought these were good tripods?
#4 seattlepete
seattlepete
Posted 12 September 2012 - 05:13 PM
I hear they are...I just don't have the field tripod adapter for the mount...I have 3/8ths and 5/8ths posts but not the big wide one for that tripod!
#5 Adam Taylor
Adam Taylor
  • Loc: Arizona
Posted 12 September 2012 - 07:26 PM
I agree with Jason, a surveyor's tripod would be a good match. I've always fancied this one. Heard good things too.
#6 Scott in NC
Scott in NC
    Refractor Fanatic
  • Loc: NC
Posted 12 September 2012 - 07:29 PM
I use a Universal Astronomics heavy-duty wooden surveyor's tripod for mine, and have been very pleased with its stability.
#7 crazyqban
crazyqban
  • Loc: Miami, Florida
Posted 12 September 2012 - 10:36 PM
I had one of those, good for only a small scope (60-80mm). Bigger scopes don't fare too well on it, at least not for me. I had a pretty loaded Takahashi Sky 90 on a Teegul mount and I was not happy with the tripod performance. I went out and got a Televue Gibtaltar tripod which worked much better.
#8 Phil Wheeler
Phil Wheeler
  • Loc: 3 miles WNW of Celestron
Posted 12 September 2012 - 10:47 PM
I have a fairly old Bogen-Manfrotto 475 which works well with several of Larry's mounts I own. In fact I purchased it from Larry. It has very effective spreaders for stability and a stable crank-up center pillar. It's my favorite tripod, though not the most portable.
A thought: Why not call Larry for a recommendation?
#9 seattlepete
seattlepete
Posted 13 September 2012 - 12:50 AM
I'm actually going to send the mount back to him for an encoder install so I wont need the tripod for a bit...I still have my atlas at my sister's house and can get it back if I want it....I might just end up that way....I used it with that tripod with my C9.25 and it worked great....we'll see..thanks for the ideas!
#10 Texas
Texas
Posted 13 September 2012 - 06:47 AM
Another vote for the surveyor's tripod. Works great with mine.
#11 SteveG
SteveG
  • Loc: Seattle, WA
Posted 13 September 2012 - 12:11 PM
I have the UA surveyors tripod. It completely changed the stability of my mount. Rock solid - damp time less than 1 second. I can lean against it while viewing. Handles my 120 ED with ease.
#12 Jeff Bennett
Jeff Bennett
  • Loc: Clayton, California
Posted 13 September 2012 - 12:13 PM
I use my Unistar Deluxe on a Disc Mount tall tripod meant for the DM6. With my SV115 it is a very stable combination (using the tray that serves as a very rigid spreader), noticeably better than the Oberwerke heavy surveyors tripod (which did lack a decent spreader).
The main drawback to the DM tripod is that the legs are fixed length, which makes it a little more cumbersome for travel.
Jeff Bennett
#13 seattlepete
seattlepete
Posted 14 September 2012 - 06:59 PM
Thanks for all the ideas. My unistar will be going back for encoders so I have another 3-4 weeks to decide on the tripod.
I'll look into all these combos.
Thanks again!
#14 Bill Barlow
Bill Barlow
  • Loc: Overland Park KS
Posted 14 September 2012 - 07:20 PM
I currently own four UA mount/tripod combinations..from the duel clamping Unistar deluxe attached to a Celestron CGE tripod to the Unistar light attached to a UA light surveyor tripod. All are excellent. The 40 pound CGE tripod is used with a C14 while the smaller combination is used with a SV 102ED.
I have a Meade field tripod with the UA adapter plate and use it with scopes from a C9.25 to a Meade 12 ACF. It is a very stable setup, more so than the UA heavy duty wooden surveyors tripod, which I also owned a few years back. I would also recommend a call to Larry to discuss your options..good luck.
Bill
#15 Rich_W
Rich_W
  • Loc: Philadelphia, PA
Posted 14 September 2012 - 08:24 PM
I've used a heavy duty wooden surveyor tripod and a Meade field tripod with my Unistar Deluxe and both have been good. Most rock solid set up I have is the Unistar on a G11 tripod. Larry has an adaptor and it's a great set up.
#16 seattlepete
seattlepete
Posted 14 September 2012 - 08:39 PM
Bill
Wow..I know you have posted that you've used the Unistar with your 12" but the C14? Wow.
I used my older ones with a C9.25 and a C11 for a bit.
I think these are by far the best alt/az mounts for the price...just have loved every one I've owned.
