Home position on a CGE PRO question?
1 reply to this topic
#1 George P Dunham
George P Dunham
  • Loc: Pinecliffe,CO USA
Posted 12 September 2012 - 03:15 PM
I have noted that my "home position" function is not doing what I expect it to do. I would assume that if I slew to a particular place I want the scope to park and then set the home position, the scope should always slew to that position when I bring up home position and select "goto". The few times I've set it have given me odd results. If I don't cycle the power, it will goto home when this command is used. But if power is cycled, it will goto home in some other position, in other words, it isn't working. Am I missing something?
#2 wolfman_4_ever
wolfman_4_ever
  • Loc: El Segundo, Ca, So. Cal
Posted 15 September 2012 - 06:36 PM
What version of firmware are you using?
I use the home position all the time..
