GSO Dob knob coming loose
4 replies to this topic
#1 maxwolfie
maxwolfie
Posted 13 September 2012 - 10:40 PM
I have an 8" GSO Dob, I have a problem where if I rotate the Dob counter-clockwise, it will bring the tension handle with it and hence make the scope very sloppy and difficult to use. Rotating it clockwise is not an issue as it will essentially tighten it rather that loosen it.
Does anyone have any ideas for a quick fix?
#2 dodgerm37
dodgerm37
  • Loc: N.E Ohio, USA
Posted 14 September 2012 - 09:45 AM
maxwolfie, If there is a roller bearing under the tension knob it may need cleaned and a LITTLE lubrication. If the bearing is not moving freely it will cause the knob to loosen when the base rotates in that direction. Bob
#3 maxwolfie
maxwolfie
Posted 16 September 2012 - 06:00 AM
Thanks Bob, the whole thing is brand new though so I'm thinking perhaps I've put it together wrong?
#4 maxwolfie
maxwolfie
Posted 04 October 2012 - 02:56 AM
It turns out that for some reason the ball bearings were cutting a "race" into the washers, which I guess is causing a lot of binding.
Are there any options for a complete tension knob/bearing replacement? Don't really want to stuff around with it.
#5 maxwolfie
maxwolfie
Posted 05 October 2012 - 02:19 AM
Bump :)
