608 bearings for CGEM worm
9 replies to this topic
#1 orlyandico
orlyandico
  • Loc: Singapore
Posted 14 September 2012 - 01:41 PM
So I snagged an Aeroquest worm off the other site for a low price, I thought, what the heck.
Major problem, my periodic error (which was bad enough at +/- 25") has gotten worse! at +/- 34"
Maybe I shouldn't have put those allegedly "ABEC-5" skate bearings in there... (that I removed from a pair of skates)
Anyway I don't feel like putting back the stock CGEM bearings - which are lousy anyway.
My question is, what bearings do I use to replace them? I see the SKF part number 608-2RSH. But how different is this from say a 608-2ZJEM? do I need those exact bearings?
Also there are these pricey "full ceramic" bearings - will these do me any good?
#2 brokenwave
brokenwave
  • Loc: Scottsdale, AZ
Posted 14 September 2012 - 03:27 PM
Ed Thomas at Deep Space Products could help you out,
He has a DYI Hyper Tune kit available, if that is something you were interested in.
#3 DaveJ
DaveJ
  • Loc: NE Ohio
Posted 15 September 2012 - 07:54 AM
"DYI" = "Do Yourself In" :grin:
#4 orlyandico
orlyandico
  • Loc: Singapore
Posted 15 September 2012 - 10:40 AM
Yeah looks like I've done that.
Found some NKF "Japan" bearings and put them in. The periodic error is just as bad, maybe even a bit worse (probably within uncertainty limit).
Looks like it's lapping time. Toothpaste will probably do...
#5 Mert
Mert
  • Loc: Spain, Pamplona
Posted 15 September 2012 - 10:58 AM
Do you have some sort of log-file to analyze the
mount's basic periods??
Typically the bearings influence but not in the amount
you have written!
Maybe you have put too much pre-load on the bearings??
I don't know the CGEM but likely mecanically it is not
too different from an EQ6.
Just my 2 :penny: worth :gramps:
#6 orlyandico
orlyandico
  • Loc: Singapore
Posted 15 September 2012 - 11:17 AM
I have a bunch of logfiles.
Looks like it's not the bearings and it's not the Aeroquest worm.
It's the wretched 8/3!!!
On my original worm, the fundamental was 29" according to PECPrep (agrees with my old PEMPro run) and the 8/3 was 19" for a total PE of 42"
With the Aeroquest worm, the fundamental is 16" (much better!) but for some reason the 8/3 has ballooned to 24" (now making it larger than the fundamental) for a total PE of.... 40"
So much for that.
The Aeroquest worm does have a quantifiable improvement, but the 8/3 can't be helped. I don't even know if lapping the worm would do any good...
#7 Mert
Mert
Posted 15 September 2012 - 01:07 PM
Do you have the layout of the CGEM gearing?
That is from the stepper-gear - X - X - Worm - Wormwheel.
How many teeth on the wormwheel? ( 180 ?? )
When you state 8/3 what do you mean?
This could be helpful analyzing with PECPrep.
Also some logfile of 5 cycles would help!
Right now I'm off to do some imaging tonight ( I hope )
#8 orlyandico
orlyandico
  • Loc: Singapore
Posted 15 September 2012 - 01:12 PM
Mert, the CGEM has a very well known 8/3 harmonic (2.667X or a period of roughly 179 seconds = 479 / 2.667) due to the layout of the gears in the servo -
http://tech.dir.grou...EM/message/7441
Some CGEM's have a small 8/3 term (8") and some have a large term like mine. This cannot be corrected by PEC because it's out-of-phase with the fundamental (and the CGEM only has 88 PEC cells).
#9 Alph
Alph
  • Loc: Melmac
Posted 15 September 2012 - 01:54 PM
Where can we find them?
#10 orlyandico
orlyandico
  • Loc: Singapore
Posted 16 September 2012 - 01:17 AM
here ya go Alph...
stock gear, Meade DSI (9.6x7.5 um pixels), Vega, 432mm FL
https://dl.dropbox.c...ega_DSI_Z70.txt
Last night, also Vega, also 432mm FL, with the Aeroquest worm
https://dl.dropbox.c...0_Aeroquest.txt
Last night, Altair, with the Aeroquest worm
