LNtech 300 shrink down & wired remote control
35 replies to this topic
#1 ccs_hello
ccs_hello
Posted 16 September 2012 - 08:35 PM
Just got the LNtech LN300R 960H NTSC video cam. This toy is using Exview HAD II type-1/3" ICX672AKA CCD.
Here is the inside on the main board.
There are 3 cords connect to the back board.
4 PIN cable: it's for lens control. For practical purpose it's not useful in our field. It will be removed.
3 PIN cable: 12V Power (RED), Ground (BLACK), and RS170A Video out (YELLOW).
2 PIN cable: to handle top-down-left-right-center buttons, using resistor matrix. <-- Black-White cord
Some interesting circuit observations:
1) 2-wire control (I'll show a DIY, posts #4-#11). No need to bother RS485 type of control.
2) RJ-11 DSP/CPU is used
3) AD9943 10-bit A/D AFE
4) JRC's NJM2274 (Y + C combiner) to form composite video output. In another word, this camera can send out S-video, if a slight change is made.
5) probably 74AC07 (JRC again) to drive lens-drive signals
6) IR-cut output (to drive a solenoid to mechanically move-in/move-out IR-cut filter) is unpopulated and is optional.
In post #12, I'll describe my general observations on its image accumulation part of design and software-based image summing.
Clear Skies!
ccs_hello
#2 ccs_hello
ccs_hello
Posted 16 September 2012 - 08:39 PM
Here is the cable you can find for board camera. I happend to have one. Black jack is for 12V power. Yellow is the coax video out.
Clear Skies!
ccs_hello
#3 ccs_hello
ccs_hello
Posted 16 September 2012 - 08:40 PM
Does this cam look smaller?
(Still have to handle the 5 buttons...)
#4 ccs_hello
ccs_hello
Posted 16 September 2012 - 08:44 PM
Remote control handbox
- project box
- 5 push button switches
- 4 resistors
15KOhm (Top)
27KOhm (Right)
56KOhm (Bottom)
6.8KOhm (Center) i.e., 6k8
0 Ohm for (Left) i.e., no resistor required
#5 ccs_hello
ccs_hello
Posted 16 September 2012 - 08:46 PM
Push-button switches mounted
Left is "Top" switch.
#6 ccs_hello
ccs_hello
Posted 16 September 2012 - 08:48 PM
5 switches share the common contact. This is one of the 2 leads used for that (Black-White cable).
Left side is "Bottom" push button.
Bottom side is "Left" push button.
#7 ccs_hello
ccs_hello
Posted 16 September 2012 - 08:50 PM
Now with 4 resistors and one "jumper wire" soldered in into one single junction.
They (4 resistors and one direct-wire) form the other lead for the two-wire control cable.
The mounting method is "fly wiring", a vacuum tube era technique :) :).
#8 ccs_hello
ccs_hello
Posted 16 September 2012 - 08:52 PM
The control wires (2 of them) are soldered and coming out from the bottom side of the box.
The control box is done.
Clear Skies!
ccs_hello
#9 ccs_hello
ccs_hello
Posted 16 September 2012 - 08:55 PM
End result
(3 pictures)
The coupling is a 2" with a focal reducer built-in.
(My previous project, described here in CN.)
Clear Skies!
ccs_hello
#10 ccs_hello
ccs_hello
Posted 16 September 2012 - 08:56 PM
The BLACK-WHITE cord connects to the 2-wires comming out of the control box.
#11 ccs_hello
ccs_hello
Posted 16 September 2012 - 08:57 PM
Side view.
#12 ccs_hello
ccs_hello
Posted 16 September 2012 - 10:04 PM
Now on the camera's behavior:
As expected, this cam is tuned mostly for automated operation without human intervention. In another word, have to try hard to defeat camera's CPU making decision and override your input.
Another thing is that this camera takes time to initialize, also the picture update cam be long, after the image is acquired. I.e., Do not expect immediate display when an image acquisition period ends.
If need to have a predictable result, do not use any setting starts with "A", e.g., AGC. (Automatic Gain Control.)
Actually SENSE-UP is too smart (cam does thing other than your input on that field's setting).
AGC is rather crazy, in addition to signal gain, on as needed basis, it will also do software image summing.
The SENSE-UP in this camera's design is also software image summing.
The only one that does image accumulation (true long exposure) is the ELECTRIC-LENS setting (up to 1024x).
But in this setting, do not turn on AGC. It will once again messing up the long exposure.
Clear Skies!
ccs_hello
  • ziggyboo likes this
#13 Whichwayisnorth
Whichwayisnorth
  • Loc: Southern California
Posted 17 September 2012 - 12:36 PM
I have the same camera and I just wanted to say thank you so much for this thread. I need to duplicate your control box.
Please keep us updated on what you discover. I only had the camera out one night and it seemed to work well.
#14 Teabagger
Teabagger
Posted 17 September 2012 - 02:54 PM
disregard
#15 James Cunningham
James Cunningham
  • Loc: Maryland
Posted 18 September 2012 - 06:09 AM
I just got an e-mail from Jock who sells these cameras. He sent me 2 photos of a remote control cable. Here they are:
#16 James Cunningham
James Cunningham
  • Loc: Maryland
Posted 18 September 2012 - 06:10 AM
Here is the other one:
#17 ccs_hello
ccs_hello
Posted 18 September 2012 - 07:40 AM
Jimmy
The cable set is cables only.
The board you've shown is not LN300.
The cable would work but IMHO is overkill for LN300R.
Clear Skies!
ccs_hello
#18 barbarosa
barbarosa
  • Loc: 37┬░50'N
Posted 18 September 2012 - 02:14 PM
ccs_hello
The S-video out possibility is really interesting. :goodjob: You can bet that I will follow this thread closely.
#19 ccs_hello
ccs_hello
Posted 18 September 2012 - 04:59 PM
Example of this cable (post #2) can be found in fleabay linkie or search there keyword "BNC DC Power Jack to 3 Pin Connector Cable".
$2 shipped to US. Good price!
Note: I have not seen the actual cable so I am just guessing. The polarity (cable colors) must be correct or big trouble.
P.S. adding a 100mA in-line fuse on the power side (RED wire) is highly recommended.
Clear Skies!
ccs_hello
#20 James Cunningham
James Cunningham
  • Loc: Maryland
Posted 19 September 2012 - 07:07 AM
It looks like all this cable does is extend the video connection and the power connection. Nothing for remote control.
#21 ccs_hello
ccs_hello
Posted 19 September 2012 - 07:36 AM
Jimmy,
The cable bundle you've shown has 4 connectors. (pigtail only)
Only two are used in LN300, the "OSD Control" (AD Key) is used for remote control (blue-white pair).
Clear Skies!
ccs_hello
#22 Whichwayisnorth
Whichwayisnorth
Posted 19 September 2012 - 09:34 AM
Could you list which resistors you used? I was looking at the photos and I can only make out one or two clearly. I am not familiar enough with them to know automatically.
Also because the pictures are top-down I can't tell if contacts are touching or not.
#23 mclewis1
mclewis1
    Thread Killer
  • Loc: New Brunswick, Canada
Posted 19 September 2012 - 12:50 PM
see #5424460 above
#24 Whichwayisnorth
Whichwayisnorth
Posted 19 September 2012 - 02:17 PM
see #5424460 above
Ah gotcha. I was just looking at the pictures.
I think a trip to radio shack is in order.
#25 ccs_hello
ccs_hello
Posted 19 September 2012 - 05:18 PM
I painted the wires to show the lower layer (black) and upper layer (red).
Again, Left side is "Bottom" push button.
Clear Skies!
ccs_hello
