Which Ascom driver for HEQ6PRO
3 replies to this topic
#1 Jason1970
Jason1970
Posted 17 September 2012 - 04:48 PM
Hello
I'm trying to connect my SynScan to my laptop.
I do have the RJ11 cable.
I am trying to find out which ascom driver I should use.
I have checked Ascom website but non seem obviours to me.
Can someone help me locate these?
Thank you
Jason
p.s Im assuming I require an Ascom driver for this....
#2 scirocco1
scirocco1
  • Loc: Cluj,Romania
Posted 18 September 2012 - 05:15 AM
Hello,
You need a Serial->USB converter, plug it into the synscan's rj11 port (you have the connecting schema in your manual). Afterwards you must put your synscan in pc-direct mode. Install ASCOM 6.1 (http://download.asco...latform6SP1.exe) and EQMOD and you will be (hopefully) able to connect to your mount.
Or instead the Synscan + USB/serial adapter, you can buy an eqdir adapter.
#3 rmollise
Posted 18 September 2012 - 06:43 AM
Hello,
Uh...not really. To just control the mount through the HC with a computer you do NOT have to put it in PC Direct. That is ONLY for EQMOD.
OP: You want the Celestron driver. Install it and you will find one of the mount choices given in the chooser will be Synta (right at the end).
#4 scirocco1
scirocco1
  • Loc: Cluj,Romania
Posted 19 September 2012 - 04:28 AM
yes, sorry, my bad (i always work with eqmod).
