Lx55 GEM
3 replies to this topic
#1 James Cunningham
James Cunningham
  • Loc: Maryland
Posted 25 September 2012 - 05:33 AM
Is the CNP always in the exact same place relative to where your are? I ask this because I set up my scope in the exact same position each time I go out. In fact, I have glued washers to my concrete driveway and the points of the tripod fit right into the washers. If I get a good polar alignment and then move the scope inside, when I come out again and the scope is facing the exact same position, will I still have a polar alignment? I would still do my usual 3 star alignment but do I still have to move the mounts adjustment? I could "Park" the scope before I shut down to make sure that it really was facing the exact same position. Thanks.
#2 Geo.
Geo.
  • Loc: Upstate NY
Posted 25 September 2012 - 09:27 AM
CNP does not move, but the pole star does. I doubt that once moved your setup can be replaced with enough accuracy to maintain exact polar alignment, but your gotos should be fine.
#3 TALK2KEV
TALK2KEV
  • Loc: Oklahoma
Posted 01 October 2012 - 05:35 PM
James
I do the same thing I just use a black sharpie marker and if you haven't set up for a different observing site ie your Azimuth and Latitude hasn't been changed and your tripod is at the same height, you will be close just not nailed. This is also a good for a solar event and make it where you can set up your equipment in the day light. Just don't expect it to be great with out some more fine tuning.
#4 MawkHawk
MawkHawk
  • Loc: SE Michigan, USA
Posted 01 October 2012 - 07:09 PM
And the ground itself can move as it cools and warms or dries or gets wet.
