ETX 80 issue
18 replies to this topic
#1 tjay
tjay
  • Loc: just outside of Toronto
Posted 13 October 2012 - 03:28 PM
I'm trying to disassemble my ETX 80 to fix a problem with the rear port. I screwed a t-thread adapter on, and I can't get it off now, as the threads for the rear port just turn with the t-thread adapter.
Here's a picture of the rear port with the t-thread adapter:
I started trying to disassemble the base so that I could remove the tube, and hopefully take the separate the back end of the tube from the rest of the scope so I could fix the issue.
However, I can't the white plastic thing in the following picture off:
Any tips on how to get this thing off?
If anybody has any other suggestions for getting at the threads for the rear port, I'd also appreciate though.
#2 Stew57
Stew57
  • Loc: Silsbee Texas
Posted 13 October 2012 - 04:21 PM
The white thing unscrews. The rear port staks are always a problem. I fixed mine with a few drops of super glue. You could also leave it in place and get a thread cap.
#3 tjay
tjay
Posted 13 October 2012 - 04:37 PM
Thanks for the reply Stew57.
I'll give unscrewing it a try..
#4 tjay
tjay
Posted 13 October 2012 - 05:01 PM
Well, that worked (thanks again Stew57), but I still can't figure out how to get the focuser apart from the back half of the tube. I've removed the three screws in the focuser, plus the nut on the end of the threaded rod that actually does the focusing, but I still can't get the focuser off.
Anybody have any more pointers?
Here are the two pieces I'm trying to get apart now:
#5 Stew57
Stew57
Posted 13 October 2012 - 08:05 PM
Try Weasners ETX site. There was some disassembly pics there. You have to take the focus shaft loose and the screws out of the back. It has been awhile since I had mine apart. What are you trying to fix?
#6 tjay
tjay
Posted 13 October 2012 - 11:13 PM
Mark, thanks for replying again.
I have removed the rear screws and the focuser shaft with the front half of the tube, but the tube just slide a little bit and then catches on something.
I'm trying to get to the inside of the metal insert with the threads for a back cell so that I glue it in place and eventually get the t-thread adapter off.
#7 Stew57
Stew57
Posted 13 October 2012 - 11:40 PM
I got mine off by prying the etx threaded part back increasing the friction between it and the tube a bit and turning the t-thread adapter at the same time. A hair dryer to heat up the adapter some may help also. Wish I had taken pictures of mine all apart.
Here you go
http://www.weasner.c...e/70atguide.htm
http://www.cloudynig...28/Main/2010728
http://www.weasner.c...epair_Guide.pdf
#8 tjay
tjay
Posted 14 October 2012 - 11:46 AM
Thanks Mark. I've found that there is one remaining screw behind the focuser knob, and I can't quite get allen key in there to loosen it.
Did you take your focuser knob off? I'm going to try to see if I can do what you did to get the t-adapter off.
#9 Stew57
Stew57
Posted 14 October 2012 - 12:28 PM
yes the focus knob came off.
#10 tjay
tjay
Posted 14 October 2012 - 12:36 PM
I got the t thread adapter off! I used some super glue from the side with where the focus knob it, and got behind by removing the little cover at the back. I figured I had not much to loose as I needed to glue the threaded portion in place anyways.
I've now just finished adding some more superglue around the edge of the threaded portion. I'll let that sit for bit before I trying to reassemble everything...
Thanks for your help so far Mark! It's very much appreciated.
#11 Stew57
Stew57
Posted 14 October 2012 - 01:15 PM
Glad you got it!
Some mods I did to my ETX80
http://www.cloudynig...hp?item_id=2794
#12 tjay
tjay
Posted 14 October 2012 - 02:20 PM
Thanks Mark.. That certainly is one tricked up ETX-80.
After reassembly, I'm getting a motor failure. The scope moves find in the altitude direction, but not at all in azimuth. I suspect I've either got the azimuth clutch too tight, or not tight enough.
#13 Stew57
Stew57
Posted 14 October 2012 - 06:09 PM
Does the motor work while trying to slew?
#14 tjay
tjay
Posted 14 October 2012 - 10:26 PM
It sounds like the motor is running, but the scope doesn't move. I'm trying to figure out how to troubleshoot the issue when I can't see inside the base.
I suspect that the worm is actually turning the gear, but the gear isn't locked to the shaft properly for some reason.
#15 Stew57
Stew57
Posted 14 October 2012 - 10:39 PM
Snap the bottom cover off and see if the gear is turning.
#16 Stew57
Stew57
Posted 14 October 2012 - 10:48 PM
If the gear is turning it is the clutch. When I assembled mine (before the bearing mod) I would screw the white castle nut, set the washer looking nut with the cutouts on the castle nut, then thread the bolt into it. Putting the bolt in and threading everything from the bottom usually doesn;t work well. You can remove the lever off the bolt on top and tighten the bolt to improve the clutch action. when you get it working put the lever back on or you can leave it off and never use the clutch. I opt for never using the clutch and just move with the controller.
#17 tjay
tjay
Posted 15 October 2012 - 10:48 PM
Hmm, I can't seem to figure out how to do that. I've undone the screws that hold the bottom to the steel plate in the base, but I can't seem to get the cover off while leaving the gear in place.
#18 Stew57
Stew57
Posted 15 October 2012 - 11:16 PM
Tghere is a small round button cover see your pic above showing the white castle nut. You can see if the gear is turning through the space next to the clutch fingers.
#19 tjay
tjay
Posted 18 October 2012 - 05:58 AM
Thanks Mark, I'll give that try.
