Portable observatories
17 replies to this topic
#1 Zeta_Reticuli
Zeta_Reticuli
Posted 16 October 2012 - 01:21 AM
I am thinking about constructing a portable observatory using PVC pipes and tarps. Does anyone have pictures or links to portable observatories so I can get ideas on how to construct one? There is a review of Cover Your Astro portable observatory on this site. However, it seems the plans are no longer available for sale. I think I can contrcut that observatory just by looking at pictures.
Cover your astro:
http://esmithonline....observatory.JPG
I like the design. The crossbar across the opening will probably annoy me. Maybe I can contruct it without the crossbar???
I could always just construct panels. It may be simpler. Here is an example:
http://www.boulderas...tory_panels.jpg
Any links, suggestions, or more pictures will be very helpful. I just want something transportable that I can take to my dark sky site to block wind, dew, and ground light.
#2 nikao
nikao
Posted 16 October 2012 - 06:40 AM
Why not buy something like this? It's so cheap you can hardly save any money building it yourself I guess..
http://www.ebay.co.u...cafaeb88&_uhb=1
#3 YetAnotherHobby
YetAnotherHobby
  • Loc: Central CT
Posted 16 October 2012 - 07:13 AM
I have a set of PVC & canvas panels similar to your picture and they do a great job of blocking light and gentle breezes. They are roughly 4 feet across, and I have 12 of them, which gives me enough room to maneuver around the scope.
The crossbar to maintain an opening is a pain due to its height, but you have to somehow link the two ends of the panel chain together for stability. Those panels are equally adept at blocking light and catching the wind, although if you could somehow guy them to the ground that would eliminate the need for attachment.
#4 csa/montana
csa/montana
    Den Mama
  • Loc: montana
Posted 16 October 2012 - 09:24 AM
For light block panels, see this sticky; and scroll down:
Light Block panels
An observing tent is also available:
Link
#5 MisterBill
MisterBill
  • Loc: Geezerville aka S.FL, MILE 264
Posted 16 October 2012 - 07:36 PM
Cover your astro has moved to:
http://www.oocities....a01/buildit.htm
EDIT: Sorry, I think this might be dead.
Bill
#6 Retsub
Retsub
  • Loc: Houston,Tx.
Posted 16 October 2012 - 11:58 PM
Zeta: Look around for Joe Gafford in Denver,Co. He built something like the first pic and has used it for years. I can't get to my stuff right now or I would help more. *BW*
#7 mrlovt
mrlovt
  • Loc: Smyrna, TN
Posted 17 October 2012 - 09:37 AM
You can move the "header" across the opening upwards, into the "ceiling", and move the observing window to the opposite side. Removing that pipe completely will leave the structure wobbly, especially if you use lower-diameter PVC. I wouldn't do this with anything less than 1.25" high-pressure (lighter and stiffer) PVC.
#8 Mike E.
Mike E.
  • Loc: Moonstone Observatory
Posted 17 October 2012 - 05:50 PM
Have a look on Yahoo Groups for the "Questar Users Group".
See "Folding Observatory by Ron Ravneberg", its on the last page of "photo albums"; 10 detailed photos, a nice panel setup. :cool:
Sorry, I can't seem to post a link.
#9 Snaproll
Snaproll
  • Loc: Green Bay
Posted 17 October 2012 - 06:20 PM
My first one was a modified deer hunting blind, one of those popup things.
#10 Zeta_Reticuli
Zeta_Reticuli
Posted 17 October 2012 - 09:52 PM
Thank you everyone for the help. I will digest all of this information!
#11 Glen A W
Glen A W
  • Loc: USA
Posted 18 October 2012 - 02:04 PM
Main thing is to keep it very simple. I once bought plans fora tarp and tubing observatory. It looked like it would take hours to assemble in the field. Enthusiasm goes fast for construction projects every time you take a scope out! good luck ! GW
#12 Phil Sherman
Phil Sherman
  • Loc: Cleveland, Ohio
Posted 20 October 2012 - 07:52 PM
I've been looking for something like this for use when I have my scope set up for a week or two at a dark site. I was looking for a place to buy one in the US and discovered that I had a brand new one, from our camping days, sitting in the hall closet!
Thanks for a great idea.
Phil
#13 EricRemy
EricRemy
  • Loc: Quebec, Canada
Posted 06 January 2013 - 10:29 PM
Here's mine.
Pannels are made of wood with black plastic 6 mil poly available at the home depot. Sections consist of two pannels connected with hinges with the pins removed. I replaced the pins with bent 4 inch nails. Price for the 6 pannels is less than 100 bucks.They are very lightweight and do the job blocking unwanted light pollution. Dimensions are 3 x 6 for the small pannels and 3 x 7 for the center one.Pannels are lightweigt and can be folded for storage.
#14 donnie3
donnie3
  • Loc: bartlesville oklahoma
Posted 06 January 2013 - 11:01 PM
eric, very nice job on the panels. im thinking about making some myself. just a few questions, what type of wood did you use and how did you secure the corners, nails, glue or other. has the panels warped, i know screen doors made of wood keeps its shape fairly well. thanks, donnie
#15 EricRemy
EricRemy
Posted 07 January 2013 - 09:57 PM
I use ordinary pine wood 2 inches by 3/4 inch strips glued together(1 1/4 inch sandwich) to make a frame that is 3 feet large by 6 feet high. I then cut out 3/4 inch wood strips that i place inside the frame to hold the poly in. I use staples to hold it in place and this also allows me to apply tension to the plastic to get rid of wrinkles.I store them in a shed so I did not apply any kind of finish. This is a temporary solution until I buid a rolloff observatory. Hope this helps.
#16 donnie3
donnie3
Posted 07 January 2013 - 10:47 PM
eric, thanks very much. i would like to observe on my driveway but all the boogieman lights and street lights makes it almost impossible. with the light panels it might be possible. thanks again, donnie
#17 norton67
norton67
  • Loc: Michigan
Posted 10 January 2013 - 04:29 PM
Yep thats mine now but works great.
#18 Bill Cowles
Bill Cowles
    MacGyver
  • Loc: Utah
Posted 11 January 2013 - 12:26 PM
Mine is a portable "Outhouse". :smirk:
Bill
