question on trails on stars with a C11
28 replies to this topic
#1 dr.who
dr.who
Posted 16 October 2012 - 10:41 AM
Sorry to post but I now have a case of the worries. And thank you in advance for advice!
Ok. Was talking to my friend, who has been in the hobby going on 50 years, who got me into this hobby and was explaining to him what I was seeing in my C11 regarding stars.
They look like a wind is blowing from one side so there is a small trail on the other side like one would see from smoke out of a moving ship or the like.
He said he hoped it was just that the mirror wasn't cooled down enough (I had the CAT cooler on for 45 minutes and the OTA was in the unheated garage) but there was a possibility there was a problem with the mirror...
Could it be a mirror problem? And if so how do I tell?
#2 Patrick
Patrick
  • Loc: Franklin, Ohio
Posted 16 October 2012 - 11:43 AM
I gather that these aberrations are moving? The only things I know of that would cause movement would be either an uncooled optic or bad seeing conditions. It sounds like you've ruled out the uncooled scope. Have you tried rotating the eyepiece and diagonal to see if the image moves? Are you viewing over a house or other building that's putting out heat? Do you have any problems with your eyes?
Patrick
#3 dr.who
dr.who
Posted 16 October 2012 - 03:06 PM
Thank you Patrick. It looks like wind blowing on one side of the star with the other side having little trails like tails.
As to viewing over a house etc...
This was constant for all stars including Vega which was near zenith when I was looking. Though I was on a brick driveway with a asphalt street within a few meters.
I did not move the EP or diagonal but will try that.
My eyes are 20/20 and I have no other issues with them...
#4 Stelios
Stelios
  • Loc: West Hills, CA
Posted 16 October 2012 - 03:25 PM
Sounds like collimation is extremely off to me.
#5 MikeBOKC
MikeBOKC
  • Loc: Oklahoma City, OK
Posted 16 October 2012 - 03:43 PM
Suggest you center a fairly bright star and defocus on both directions to see iff the "donut" ring pattern is symmetrical. If not you have a collimation issue. There are lots of resources on the web to explain CST collimation, which should get yourt scope in the pink if that is indeed what is happening.
#6 wolfman_4_ever
wolfman_4_ever
  • Loc: El Segundo, Ca, So. Cal
Posted 16 October 2012 - 04:16 PM
+1
#7 dscarpa
dscarpa
  • Loc: San Diego Ca.
Posted 16 October 2012 - 05:53 PM
That's exactly what stars look like in my C-9.25 when it needs to be collimated. It's a bit of of pain though not hard to do. The problem is you need good seeing or a rather expensive cat collimating device to do a good job. I'm careful carrying my cats around that's for sure. Unless it gets a pretty hard wack my C-9.25 holds collimation really well. It's only needed it a few times in the 4 years I've had it. David
#8 Doc Bob
Doc Bob
  • Loc: Maryland, USA
Posted 16 October 2012 - 06:19 PM
Dr Who,
You're out of collimation! or perhaps the diagonal is out of sorts - or the eyepiece is off!
Bob
#9 dr.who
dr.who
Posted 16 October 2012 - 11:37 PM
Gentlemen,
Thank you!
I did defocus and there was a bit of a shift on one side but it wasn't outrageous... Is just say one or two lines of the many lines (air gaps? other word of it) between the bright parts of the image enough to cause this? As in it's out of collimation but not badly?
Sorry don't know the words to describe it and its frustrating...
#10 Jared
Jared
  • Loc: Piedmont, California, U.S.
Posted 17 October 2012 - 12:17 AM
Draw a picture of what you are seeing (in focus as well as on Eire side of focus), then post a picture of your drawing.
It sounds like coma resulting from poor collimation.
#11 Starhawk
Starhawk
    Space Ranger
  • Loc: Tucson, Arizona
Posted 17 October 2012 - 12:21 AM
SCTs reward collimation nazis. Get to really high power, such as with a 3mm eyepiece or a barlowed 6mm, and collimate to get a PERFECT concentric bullseye pattern in-focus.
When you back off to normal observing magnification, prepare to be amazed.
-Rich
#12 dr.who
dr.who
Posted 17 October 2012 - 12:48 AM
Thank you again!
Based on what you are all telling me it looks like a collimation issue. Something for the next star party as I am not keen on doing this myself for the first time nor do I see investing in that $400+ Hotech SCT collimation tool.
I found a photo that captures it somewhat...
#13 Bob Griffiths
Bob Griffiths
    Getting Grouchy
  • Loc: Frederick Maryland
Posted 17 October 2012 - 07:58 AM
Thank you again!
From reading your posts here and also on the Astronomy Forum (the avatar on that forum makes me think its you..lol) I HONESTY can't figure out why you are hesitant to collimate the scope yourself..
IT IS NOT ROCKET SCIENCE ..
Bob G
#14 dscarpa
dscarpa
Posted 17 October 2012 - 10:14 AM
Your scope doesn't look like it's out of collimation that all much. Someone posted a pictorial guide to collimation showing which secondary screw to turn and which way. I have it but can't post a picture. Mayby someone else can. David
#15 dr.who
dr.who
Posted 17 October 2012 - 10:26 AM
Hi Bob. That would be me on both sites. ;)
It isn't so much that I am hesitant as it is not something I have done before and thus better to use the old medical school method of "see one, do one, teach one" in my mind. Plus it's an excuse to force myself to go to the Star Party1 :)
Cheers dscarpa. I have a technical and theoretical understanding of how to do it I just have never done it so I am succumbing to a case of nerves I guess. But then again this weekend or next I will probably get a case of the "He who dares, Wins!" and just go out and try it... ;)
#16 Kevdog
Kevdog
  • Loc: Desert Hills, AZ
Posted 30 November 2012 - 10:29 AM
That's exactly what my Meade LT8 did when I first got it. And just this week the C11 I picked up used.
Yes, SCT collimation is scary when you haven't done it. I was worried I'd screw something up. But it's not as hard as you think.
There are some very good links here with some great pictures that explain what to do.
http://www.cloudynig...1623446/page...
The best hint I found (which was mentioned above) was to place your finger on one of the screws of the secondary and look through the eyepiece. If the obstruction of your arm is on the same side that the shadow is leaning to, you've found the screw to adjust. Turn it a bit (small adjustments, especially given your picture) one way and see if it gets better or worse. If worse, turn it the other way.
Also just make sure the screws don't get loose. You want to prefer to tightnen (but not too tight) rather than loosen. If you need to tighten one and it's too tight, slightly loosen the other two.
My C11 was sooooo bad that the shadow of the secondary was way off to one side. I still need to do the fine tuning yet as the air wasn't still enough the other night. Just got the scope on Tuesday.
#17 dr.who
dr.who
Posted 20 December 2012 - 03:10 PM
Thank you Kevdog. If the weather holds tonight and tomorrow my project will be to setup the C11 on the CGEM, align, stick it on Polaris, and go to town. That is a great tip regarding what screw to focus on with the finger!
#18 Asbytec
Asbytec
    Guy in a furry hat
  • Loc: Pampanga, PI
Posted 20 December 2012 - 07:14 PM
Yea, go for it. It's easy. When a scope is out of collimation, it will flare the stars to one side. As others said, I'm sure mis-collimation is what you're seeing. You really gotta get collimation down sooner or later. Why wait?
After you get the hang of it, collimate closer to focus. Personally, I find it easier with just one or two rings showing - a very slight turn of the focuser. Then check the in-focus pattern. De-focus just a bit and repeat until in-focus looks perfect.
#19 dr.who
dr.who
Posted 24 December 2012 - 05:22 PM
Cheers Norme. So far though the nights (Thursday, Friday, and Saturday) I have open to do the collimation have ALL been cloudy! :lol: Must be because of that Binoviewer and ES 11mm 82* EP I bought to use in them! :lol: Hopefully tonight after Mass...
#20 Asbytec
Asbytec
    Guy in a furry hat
  • Loc: Pampanga, PI
Posted 25 December 2012 - 01:11 AM
Good luck, Dr Who, on the weather. Gotta check mine.
Merry Christmas. Nice presents. :)
#21 JamesL
JamesL
  • Loc: Pacific,MO
Posted 25 December 2012 - 11:02 AM
my c8 has little spikes on the stars to one side and colimation looks pretty close but not perfect so maybe I will tinker with colimation screws too, what the hey!Just have to wait until the snow storm rolls through first.
#22 dr.who
dr.who
Posted 26 December 2012 - 12:52 AM
Yeah. Welcome to my world James. Save it's clouds and rain instead of snow... :)
Must be because I was looking at a ultra light Dobsonian from Hubble Optics... Just looking mind you not actually buying...!
#23 dr.who
dr.who
Posted 08 January 2013 - 02:20 PM
Update-
Went to my local star party last weekend (they moved the date of this one so as not to conflict with the other one's at actual dark sites) with a artificial 5 point star, my C11, and a Philips head to try to get a decent collimation and have help in case I cocked it up.
Of course I had also stopped by my local shop and bought some things which meant CLOUDS! :)
Had help doing the collimation against the artificial star so hopefully the ride home didn't jostle things too much and tonight I plan to setup and test against a real star... I hope this was just a case of slight collimation problems and not a problem with the optics!
#24 dr.who
dr.who
Posted 11 January 2013 - 06:33 PM
Update part II-
Views were still somewhat mushy. So I opened a ticket with Celestron. Fortunately they are only about 30 miles from my house so I drove down to them today. They put the scope on the bench to test it...
Pinched optics and a missing rubber gasket[1] which they fixed on the spot for me.
They were also nice enough to collimate it for me. So if the weather holds I am going to be looking through it tonight to see if there is a difference per their directions and if not I am to bring it back to them.
So for those who have had bad experiences with their tech support... All I can say was from the guy on the phone to the receptionist to the tech who worked on the scope they were very very friendly courteous and helpful.
Dr.Who
[1] described to me as a rubber ring ergo why I call it a gasket on the focuser to make it turn smoother which explains the tightness in the focuser as well
#25 JamesL
JamesL
  • Loc: Pacific,MO
Posted 11 January 2013 - 08:07 PM
I hope they fixed it. Is it better now?
