Best Lightweight Mount for Imaging
28 replies to this topic
#26 orlyandico
orlyandico
  • Loc: Singapore
Posted 23 October 2012 - 01:07 AM
actually I saw that EM11 guiding graph on the wlcastleman site.
frankly for $4325 I am not blown away. I know its not a valid comparison but I am getting better results than that, today. Albeit my mount weighs 35lb.
if that's the best one can get under 20 lbs I feel its not really worth buying the Tak. I suspect an iEQ30 can come close to that while costing less than 1/3 as much.
and the Tak polar scope is irrelevant to me. I can't see Polaris.
#27 core
core
  • Loc: Mostly in Norman, OK
Posted 23 October 2012 - 02:06 AM
Getting back to the SXW/SXD with the NexSXD board:
SXW head 15 lb
SXD head 19 lb
Tripod 12 lb
Cwt 4 lb
That's a total of 31 lb for my SXW stock setup. Because of the way it is designed (drive and electronics act as counter weight, I can mount a C6 on it and it will balance with a 4 lb cwt only half way out. It'll even manage a C8 with a single 4 lb cwt right at the end.
You could probably shave off the weight a little by cutting down the tripod columns, and make it fit in a standard luggage to boot - or iirc there's a chap in Hong Kong or Japan (?) that sells a custom plate to mount the head onto Manfrotto bowl heads (also has Tak adapter iirc) - then go for a lighter weight CF tripod.
I'm still dipping my toes into imaging with a Astrotrac Travler setup, and will get a NexSXD board when I'm ready to go up in focal length and duration.
#28 Patrick
Patrick
  • Loc: Franklin, Ohio
Posted 23 October 2012 - 08:23 PM
+/- 7 is Tak EM11 class. A lot of folks use PHD to measure periodic error and forget to turn off the guiding output. Made this same mistake and thought my GP was +/- 10 which made me really happy until... another mistake I've made is forgetting to account for declination when measuring the PE.
Here's the PE graph. I was not using PHD Guiding...my GP2 does not have guiding capability. :)
Edit: For the record, I used K3CCDTools to record the data and PEAS to create the chart.
Patrick
#29 andysea
andysea
  • Loc: Seattle, WA
Posted 23 October 2012 - 10:02 PM
You might have answered your own question. Perhaps the IEQ30 is the mount that you're looking for. I Have a friend who uses the IEQ45 and he is very happy with it. The craftsmanship is not at Tak level but ultimately performance is what counts the most.
I love my Rob Miller tripod but a portable pier might be better suited for your imaging latitude.....Those Vixen mounts look good tho!
