Jupiter & Io from Arizona - 30Oct 12 - good seeing
19 replies to this topic
#1 DesertRat
DesertRat
  • Loc: Valley of the Sun
Posted 01 November 2012 - 09:46 PM
Io was transiting Jupiter this night. The best seeing so far this season, I'd give it a solid 7.5/10. The definition was good enough I had to align for the planet and the moon & shadow separately and then merge the two.
This is a north up view resized up to 1.25X.
Captured with a Flea3 using FireCapture 2.1.
Comments or questions welcome. Thanks for looking!
Glenn
#2 Az Frank
Az Frank
  • Loc: Tucson Arizona
Posted 01 November 2012 - 10:53 PM
No doubt Glenn one of your best! What great detail!Great work on processing all the key details! I guess I missed a potencial great seeing opportunity.
#3 Kecktastic
Kecktastic
  • Loc: Broken Hill NSW Australia
Posted 01 November 2012 - 11:05 PM
Another super image Glenn, a ripper in every respect.
Regards
Trevor
#4 ToxMan
ToxMan
  • Loc: Tucson, Arizona, USA
Posted 01 November 2012 - 11:24 PM
The NEB looks a lot like the GRS wake. Lots of activity to look over. Simply gorgeous.
#5 claytonbigwood
claytonbigwood
  • Loc: Adelaide, South Australia
Posted 02 November 2012 - 03:44 AM
A stunning shot Glenn :thewave: :thewave:
#6 Mike Phillips
Mike Phillips
  • Loc: Swift Creek, NC - 35.682 N, 78.743°W
Posted 02 November 2012 - 08:47 AM
Wonderfully balanced image Glenn!
#7 Sunspot
Sunspot
  • Loc: Surprise, AZ
Posted 02 November 2012 - 09:20 AM
Excellent in every way.
Paul
#8 DesertRat
DesertRat
Posted 03 November 2012 - 04:36 PM
Thanks guys! Much appreciated. I must hasten to add that at least 95% of the result is due to a higher power!
Here is a later image in IR. Io is really bright at the longer wavelengths posing a problem in processing both planet and moon without Io saturating. I think this is the best compromise.
Thanks for looking!
Glenn
#9 BKBrown
BKBrown
  • Loc: Northern Virginia, USA
Posted 03 November 2012 - 04:52 PM
Terrific image Glenn, one of the better ones so far this apparition I think. Just loads of great detail there...
Clear Skies,
Brian :waytogo:
#10 lcd1080
lcd1080
  • Loc: Maryland, USA
Posted 03 November 2012 - 05:09 PM
Glenn, when you said that at least 95% of your result was due to a higher power I quickly glanced up at the image caption to see if you boosted the focal ratio with a higher power barlow; then I thought, "oh he means THAT higher power" :rainbow: I'm sure you're going to want to print this one for framing; it's truly superb.
Pete
#11 Sunspot
Sunspot
  • Loc: Surprise, AZ
Posted 03 November 2012 - 05:24 PM
Glenn,
Truly amazing and a processing technique I wish I knew how to do.
Paul
#12 DesertRat
DesertRat
Posted 03 November 2012 - 05:43 PM
Thanks guys!
Pete, yes that is what I meant, and thanks for making me laugh! Of course the 95% figure is far too conservative!
Paul, I played with wavelets a lot to get this. I unchecked level 1 as shown below. Why it helped to give definition across Io without saturating the heck out of it I don't know. Normally I play with the Sharpen control (in addition to denoise) usually turning them down to something like .060, 080 etc. And when I resize up to 2.5X (Jupiter) or 4X (Mars) I start by setting the initial layer to 2.
For each outing I end up with a slightly different scheme in wavelets. Hence my wavelet directory has many entries - so appending the date, filter and magnification is useful for the next time to give a closer starting point.
Glenn
#13 DesertRat
DesertRat
Posted 04 November 2012 - 08:46 PM
Seeing was still pretty good at the time of this RGB image.
This is my first attempt at WinJupos derotation of RGB images. I only used 3 images, but the definition seems to be improved across the face of the planet. After composing in WinJupos, I still found that I had to do a minor color alignment. Is that the experience of any others out there?
Thanks for looking!
Glenn
#14 oldstargazer
oldstargazer
  • Loc: Western Oklahoma
Posted 04 November 2012 - 09:34 PM
That is such a great image! I could be wrong and probably am but it looks like you got two moons on the planet. You can kind of see it on this last image and even better on the first with what looks like its shadow also on the planet. In both shots it is almost directly above the bigger one on the other dark band.
#15 Space Cowboy
Space Cowboy
  • Loc: Cheshire, UK
Posted 07 November 2012 - 04:18 AM
Fantastic resolution Glenn!
#16 Eddgie
Eddgie
Posted 07 November 2012 - 09:25 AM
This last image is one of your very best! You are getting to be a top notch planetary imager. And you don't even live on an island!
#17 martus
martus
  • Loc: Czech Republic
Posted 07 November 2012 - 11:15 AM
Glenn beautiful images !
regards,
martus
#18 rik ter horst
rik ter horst
  • Loc: Zuidwolde, the Netherlands
Posted 07 November 2012 - 04:04 PM
This last one is just awesome! I love the way you process your images! Not too much, just enough and smooth.... Great!Cheers,
Rik
#19 Daniel Chang
Daniel Chang
  • Loc: Hong Kong
Posted 07 November 2012 - 07:23 PM
Fantastic !
#20 DesertRat
DesertRat
Posted 07 November 2012 - 08:18 PM
Thanks everyone for your generous comments.
Ralph - only one moon shown here. But Jupiter is a stormy planet and spots break out all the time.
Glenn
