JUPITER - November 02, 2012 - Variable seeing
21 replies to this topic
#1 Freddy WILLEMS
Freddy WILLEMS
  • Loc: Hawaii, Honolulu
Posted 06 November 2012 - 12:42 AM
Again a bit better seeing today,
Some outbreak visible and two bright beacons following the GRS.
The dark spot above the GRS seems to have an inner core with a darker ring around.
Freddy
#2 Freddy WILLEMS
Freddy WILLEMS
Set 2
#3 Freddy WILLEMS
Freddy WILLEMS
Posted 06 November 2012 - 12:43 AM
Set 3
#4 Freddy WILLEMS
Freddy WILLEMS
Posted 06 November 2012 - 12:44 AM
Set 4
#5 Freddy WILLEMS
Freddy WILLEMS
Set 5
#6 Freddy WILLEMS
Freddy WILLEMS
IR Sets
#7 Freddy WILLEMS
Freddy WILLEMS
Posted 06 November 2012 - 12:45 AM
Set 6
#8 Freddy WILLEMS
Freddy WILLEMS
Set 7
#9 Freddy WILLEMS
Freddy WILLEMS
Posted 06 November 2012 - 12:46 AM
Set 8 Green images
#10 cheapersleeper
cheapersleeper
  • Loc: Sachse TX
Posted 06 November 2012 - 02:20 AM
They sure do look varaiable. Seems that seeing was changing by a lot. Thanks for posting.
Brad
#11 DesertRat
DesertRat
  • Loc: Valley of the Sun
Posted 06 November 2012 - 05:08 AM
Superb compilation Freddy! Those closeup cutouts are great. When you had good seeing is was really good. Some of the best IR and color channels I've seen. Well done!
Glenn
#12 Rankinstudio
Rankinstudio
  • Loc: Southern UT
Posted 06 November 2012 - 08:57 AM
Nice set of images!
#13 alacane
alacane
  • Loc: Madison, AL / Huntsville, AL
Posted 06 November 2012 - 12:47 PM
Wow! nice...I just moved up to a DMK21AU618. I'll have to get a IR 742 for my wheel.
#14 mikotoy
mikotoy
Posted 06 November 2012 - 05:23 PM
I am incredibly envious and thank you for the inspiration to keep at it.
Amazing images and like alacane, I'm going to pick of an IR 742 for my wheel as well.
#15 Freddy WILLEMS
Freddy WILLEMS
Posted 06 November 2012 - 06:09 PM
It's becoming more and more a full time job, processing it all, good and bad, every single capture hold a lot of valuable information for the researchers. So that's why I keep up imaging...
#16 mikotoy
mikotoy
Posted 06 November 2012 - 07:41 PM
I have a seemingly stupid question captain obvious question (total newbie here). When you image in RRGB are you performing two passes with the R wavelength with the intent of increasing the amount of detail visible in the final image?
I'm also presuming the same with the IR sequence. It is not placed in front of the visible wavelengths to aid in stabilization of the image, but in fact as a part of the sequence for detail acquisition.
#17 Freddy WILLEMS
Freddy WILLEMS
Posted 06 November 2012 - 08:58 PM
No... mot that complicated, you just use winjupos and ad the extra R or IR (Image) to the RGB group, you can combine 4 channels in winjupos ! Just plain easy combining... no extra ..
I just like to play with different filter combinations and combining in Winjupos..
#18 alacane
alacane
Posted 07 November 2012 - 10:25 AM
Thanks Freddy, I just assumed :foreheadslap: ....I'll have to try Winjupos to see the difference between that and PS.
How long are you imaging each channel? Do you use the derotate feature in winjupos?
#19 Freddy WILLEMS
Freddy WILLEMS
Posted 07 November 2012 - 01:16 PM
Around 90s - 120s / channel and Yes derotated in WinJupos
Love that program !
#20 mikotoy
mikotoy
Posted 07 November 2012 - 04:12 PM
I unfortunately have not had much luck with WinJupos, but I do attribute that to my inexperience with it and seeing conditions in my area.
It is very easy to use and its capabilities are quite powerful.
One question though: Do you perform any processing prior to combination of derotated wavelengths in WinJupos?
#21 Freddy WILLEMS
Freddy WILLEMS
Posted 08 November 2012 - 12:19 AM
No I do not, the only thing I do is running the R G B in Registax to apply wavelets wavelets and then combine/running in WinJupos..
#22 claytonbigwood
claytonbigwood
  • Loc: Adelaide, South Australia
Posted 08 November 2012 - 06:25 AM
Nice work Freddy :waytogo:
You are a machine :)
