Millennium Star Atlas
5 replies to this topic
#1 pjglad
pjglad
Posted 07 November 2012 - 11:32 AM
I recently acquired the Millennium Star Atlas and the transparent overlays. Overlay 2 contains a variety of circles ranging from 1/4 of a degree to 3 degrees. I have a CPC800 and a CPC1100 plus the following Tele Vue EPs:
Ethos 8
Ethos 10
Ethos 13
Ethos 17
Ethos 21
Nagler 31
Is there a formula I can use to figure out which EP maps into a specific circle size? Thanks.
#2 turtle86
turtle86
    Pooh-Bah Everywhere Else
Posted 07 November 2012 - 12:01 PM
Try the Televue Eyepiece Calculator:
http://www.televue.c...d=89&plain=TRUE
#3 pjglad
pjglad
Posted 07 November 2012 - 05:40 PM
Also, I have a Stellarvue F50 Finderscope. Which circle does that map into?
#4 Rick Woods
Rick Woods
  • Loc: Inner Solar System
Posted 07 November 2012 - 09:17 PM
Figure out what the FOV is for the finder, and use that circle (or add one that size). It all depends on the TFOV of each EP/finder.
#5 pjglad
pjglad
Posted 07 November 2012 - 09:33 PM
Rick, I'm confused. The TFOV is 5.75 degrees and the magnification is 9X. So are you implying that the circle size is greater than the unaided eye Telrad 4 degree circle on overlay 1? Thanks.
#6 Rick Woods
Rick Woods
Posted 08 November 2012 - 12:42 AM
Yes. Unless I'm missing something here, 5.75 degrees is 5.75 degrees, no matter what you're seeing it through. The 4* circle describes 4 degrees as seen on the MSA charts. Get another piece of plastic and make a circle proportionately larger than the 4* circle, and that'll show the same area on the charts that you'd see in your finder. The true FOV size is the common factor.
Degrees is degrees! :)
