sky view pro trouble
8 replies to this topic
#1 droid
droid
    rocketman
  • Loc: Conneaut, Ohio
Posted 08 November 2012 - 06:11 PM
Some stupid questions if I might. I put a 4 inch f/8 refractor on my Sky View Pro last night, while trying to sight in Jupiter , I used the slo-mo cables, get it in the center let go of the slo-mo cables, an watch it spin back wards and gone.
My first thought was balance, so I rebalanced everything, andthe same thing.
Is there a way to tighten this mount up enough to stay put when you let go of the cables???
#2 beatlejuice
beatlejuice
  • Loc: Hamilton, ON,Canada
Posted 08 November 2012 - 07:00 PM
If it is slipping after you tighten both clutches then there is definitely something amiss.
Eric
#3 droid
droid
    rocketman
Posted 10 November 2012 - 08:11 AM
wow , no one here has taken apart a sky view pro?
#4 rmollise
Posted 10 November 2012 - 09:38 AM
Taking this simple mount apart is not the place to start. The place to start is with, as Eric says, CHECKING YOUR CLUTCHES.
#5 EXT64
EXT64
  • Loc: Virginia Tech, VA, USA
Posted 10 November 2012 - 10:47 AM
Which axis is slipping (RA or DEC)?
#6 droid
droid
    rocketman
Posted 10 November 2012 - 05:11 PM
The declination axis, even just rebalanced it dead perfect, tweaked the slow motion cable, and watched it spring back.
#7 EXT64
EXT64
Posted 10 November 2012 - 07:52 PM
Wow, the declination axis on mine is pretty stiff when loaded up.
Are you the first owner of this mount or did you acquire it used. From the factory I'm not sure I've ever heard people have problems with it being too loose (usually they think they are too sticky).
#8 droid
droid
    rocketman
Posted 10 November 2012 - 08:55 PM
I'm the second owner, and it actually springs back, though there is one spot where it will drop.
tweek the cable it moves, when you let it go it springs back.
#9 EXT64
EXT64
Posted 10 November 2012 - 10:58 PM
Well, I am pretty baffled. When I got my SVP (used) I did think about doing some work on it; however, it turned out it didn't need it so I didn't. Still I learned a bit about the inner mechanics. This site ( http://www.andysshot...om/SVPmods.html ) might be of some help.
