Oberwerk Wooden Tripod
7 replies to this topic
#1 m00nless
m00nless
Posted 11 November 2012 - 10:38 AM
Is it possible to attach an equatorial head (for example a Celestron CG-5) on an Oberwerk Wooden Tripod? Is there an adapter available to allow this?
#2 Jim7728
Jim7728
  • Loc: Stoop Landing Observatory, NYC
Posted 11 November 2012 - 11:04 AM
Universal Astronomics might have such an adapter, but you need to call.
That said, the CG-5 2" steel leg tripod(if you have it) is more stable than the Oberwerk wooden tripod which I consider to be medium duty tripod.
#3 m00nless
m00nless
Posted 11 November 2012 - 11:22 AM
Do you know if the CG-5 tripod is available to purchase new?
#4 hottr6
hottr6
  • Loc: 7,257', Magdalena Mtns, NM
Posted 11 November 2012 - 11:25 AM
I thought the Oberwerk tripod was a "surveyors" class tripod? If so, and it is like my wood surveyor's tripod, it is much better than the S/S tube-tripod that came with my CG5-clone. I sold the S/S tube-tripod. Here is an older thread about the Oberwork and CG5 head: Click here
I have the UA adapter and it works well, although it is overpriced for what it is.
#5 hottr6
hottr6
Posted 11 November 2012 - 11:32 AM
The downsides of the surveyors tripod is that it is a lot heavier, and without a leg brace, is very, very awkward to carry. However, when I use it with my 'fracs and the legs are extended, I can easily hoist it on my shoulder.
http://www.youtube.c...h?v=PRyMyudmdiQ
#6 Jim7728
Jim7728
Posted 11 November 2012 - 12:20 PM
That's definitely a Surveyors tripod that Oberwerk use to sell. I have the original Oberwerk wooden tripod and a cosmetically updated Jarrah version.
You'll have to call your favorite Celestron dealer and see if they will sell or order you one, could cost you $299 or more.
The Vixen HAL 130 tripod(GP/GPD2) version, load wise,is a rough equivalent to CG-5, but is more portable due to the collapsible spreader and is compatible with the CG-5 head( least mine is) and seen them for $249.
The Oberwerk wooden tripod may still be an option as long you don't use a big ota that can cause more vibration than the tripod can effectively dampen.
#7 Jim7728
Jim7728
Posted 11 November 2012 - 12:30 PM
BTW, Universal Astronomic does sell a heavy duty surveyors tripod that Larry can convert to use with the CG-5 head.
http://universalastr...WOOD_TRIPOD.JPG
#8 bobhen
bobhen
Posted 11 November 2012 - 02:27 PM
I use just such a combination. I purchased an adapter from Universal Astronomics and mounted my CG5 non GOTO mount to the Oberwerk wooden tripod. The Oberwerk tripod is lighter but still holds my CG5 mount and my Tak 120 just as steadily as the standard steel CG5 tripod. The Oberwerk also collapses cleaner. And because it’s wood, it’s easier to handle in cold weather. I’ve been using that combination for 3 years and would not go back to using the standard steel tripod. I think it looks better too.
Bob
